Yeah,loads of Kawasakis used the flap and still do, as a tool to beat noise regulations. I think that's all it ever did on most bikes anyway.
Technology used by only a small number of manufacturers
- Has thanked: 9688 times
- Been thanked: 9704 times
Re: Technology used by only a small number of manufacturers
- Has thanked: 7727 times
- Been thanked: 2401 times
I'm pretty sure no-one else (manufacturer-wise) has used 'Telelever' front suspension. (Yes - invented by A Brit - Hossack IIRC - but BMW are the only manufacturer who used it).
Isn't that a 4-stroke version of the 'Power-valve' in 80s/90s 2-strokes though? I can't remember if the RD350LC had one, but the RGV250 certainly did.
Or the ill-fated Yamaha GTS.Rockburner wrote: ↑Wed Mar 31, 2021 1:11 pm I'm pretty sure no-one else (manufacturer-wise) has used 'Telelever' front suspension. (Yes - invented by A Brit - Hossack IIRC - but BMW are the only manufacturer who used it).
The Yamaha GTS was a hub-center-steered bike, NOT Hossack/Telelever.Skub wrote: ↑Wed Mar 31, 2021 1:14 pmOr the ill-fated Yamaha GTS.Rockburner wrote: ↑Wed Mar 31, 2021 1:11 pm I'm pretty sure no-one else (manufacturer-wise) has used 'Telelever' front suspension. (Yes - invented by A Brit - Hossack IIRC - but BMW are the only manufacturer who used it).
There's quite a few different 'funny-front-ends' fyi.
One of the Pre-war German manufacturers did a small, simple 2-stroke which used the rear swing-arm tubing as the exhaust pipe, but I'm damned if I can remember the name.
found it.
https://en.wikipedia.org/wiki/Imme_R100 ... r_view.jpg
found it.
- Has thanked: 532 times
- Been thanked: 7239 times
It's different to a proper hossack setup as it uses sliding tubes.Rockburner wrote: ↑Wed Mar 31, 2021 1:11 pm I'm pretty sure no-one else (manufacturer-wise) has used 'Telelever' front suspension. (Yes - invented by A Brit - Hossack IIRC - but BMW are the only manufacturer who used it).
Dyson and his amazing vortex powered vacuum cleaner. He spent half of his life trying to get manufacturers interested in the technology, they were only interested in selling brand specific bags.
It caught on eventually, after Dyson defied the odds and bet the farm on doing it himself...
IIRC he made a considerable fortune early on suing those arrogant enough to blatantly copy his design after refusing to even consider it initially.
- Has thanked: 2611 times
- Been thanked: 6015 times
The irony being that cyclonic separators had been around in industry for decades!
I got it wrong:KungFooBob wrote: ↑Wed Mar 31, 2021 1:20 pmIt's different to a proper hossack setup as it uses sliding tubes.Rockburner wrote: ↑Wed Mar 31, 2021 1:11 pm I'm pretty sure no-one else (manufacturer-wise) has used 'Telelever' front suspension. (Yes - invented by A Brit - Hossack IIRC - but BMW are the only manufacturer who used it).
Hossack =/= BMW DuoLever
SaxTrac =/= BMW Telelever. (IIRC)
DuoLever (Hossack) 'looks' a bit like the old Girder forks, with 2 'swing-arms' but the steering stem is in a different place in the assembly (and other differences).
Telelever is a single swingarm with a ball joint that moves the steering pivot to directly above the wheel and uses the sliding tubes simply to provide steering inputs.
Ah. Didn't know there were differences.Rockburner wrote: ↑Wed Mar 31, 2021 1:16 pm
My very first powered two wheeler, a Peugeot Speedfight 2 just like this (but without rim tape), had a SSSA at the front steered from the 'hinge' of the swingarm.
Maybe the only modern bike with 3 stud wheels too?
The top yoke is also on a ball joint... I only discoverd this when I removed the forks and it flopped over to one side.Rockburner wrote: ↑Wed Mar 31, 2021 1:31 pmI got it wrong:KungFooBob wrote: ↑Wed Mar 31, 2021 1:20 pmIt's different to a proper hossack setup as it uses sliding tubes.Rockburner wrote: ↑Wed Mar 31, 2021 1:11 pm I'm pretty sure no-one else (manufacturer-wise) has used 'Telelever' front suspension. (Yes - invented by A Brit - Hossack IIRC - but BMW are the only manufacturer who used it).
Isn't that essentially a 'trailing link' setup? any pics of it with it's clothes off?Mr. Dazzle wrote: ↑Wed Mar 31, 2021 1:35 pmMy very first powered two wheeler, a Peugeot Speedfight 2 just like this (but without rim tape), had a SSSA at the front steered from the 'hinge' of the swingarm.
- Has thanked: 626 times
- Been thanked: 4070 times
This could get a bit long, Yamaha's original YPVS consists of a cylinder with a cut out in that rotates near the exhaust port and effectively lowers the exhaust port to boost mid range, RGV powervalves do the same thing but work differently, they have a blade that goes up and down, before this Suzuki and Honda used a valve to open and close a chamber in the exhaust to boost mid range power, this what the original Yamaha EXUP valves do, I think the later ones work differently.Rockburner wrote: ↑Wed Mar 31, 2021 1:13 pmIsn't that a 4-stroke version of the 'Power-valve' in 80s/90s 2-strokes though? I can't remember if the RD350LC had one, but the RGV250 certainly did.
Desmo type valve gear was used on the Honda CB450 Black Bomber in the 1960s, it probably copies the Ducati set up of the time.
Which one - Duo or Tele?KungFooBob wrote: ↑Wed Mar 31, 2021 1:35 pmThe top yoke is also on a ball joint... I only discoverd this when I removed the forks and it flopped over to one side.Rockburner wrote: ↑Wed Mar 31, 2021 1:31 pmI got it wrong:KungFooBob wrote: ↑Wed Mar 31, 2021 1:20 pm
Duo (K1200R/K1200S/K1600GT) is 2 ball joints yes,
Tele (R1100XX, R1150XX, R1200GS/RT, R1250GS/RT) is 1 ball joint and a 'normal' yoke in a (irc) plain (possibly ball) bearing like a 'normal' top yoke.
The Tele on my K1200RS, the top yoke is defo on some kind of ball joint.
https://www.realoem.com/bmw/enUS/showpa ... Id=31_0499
That's very interesting and I am perfectly happy to be corrected.KungFooBob wrote: ↑Wed Mar 31, 2021 1:45 pm The Tele on my K1200RS, the top yoke is defo on some kind of ball joint.
I've never taken out both of the fork tubes at the same time before - so I thought the top-yoke was simply on a bearing. It does make a lot of sense for it to be a ball joint though.
A lot of these images make it look like a stem bearing.
(from here https://motoress.com/rider/bmw-teleleve ... -leverage/)
https://www.bmwmotorcycles.com/en/disco ... lever.html
I've added a link to the parts fiche on realoem, if you drill through the part number you can see it's the exact same part number as the lower ball joint.Rockburner wrote: ↑Wed Mar 31, 2021 1:47 pmThat's very interesting and I am perfectly happy to be corrected.KungFooBob wrote: ↑Wed Mar 31, 2021 1:45 pm The Tele on my K1200RS, the top yoke is defo on some kind of ball joint.
The Saxtrac has a ball joint where the steering head would be, no idea about the BMWs, I've never looked at one close up.
Actually more of a spherical bearing in a cage.
Last edited by Le_Fromage_Grande on Wed Mar 31, 2021 1:52 pm, edited 1 time in total.
