BBQ thread
Anything from pizza to pasta, from steak to cake.
Re: BBQ thread
Does it have to be a bean burger, or just a veggie burget?
If its the latter there are quite a few decent options in supermarkets now. Mrs D is veggie so we've tried quite a few. "Impossible Burgers" are pretty impressive IMO, actually better than cheap beef burgers, they even take on smoke flavour like real meat.
Most supermarkets have quite a big selection, usually in the meat aisle now!
Hairybiker84
Has thanked: 69 times
Been thanked: 108 times
Re: BBQ thread
Post by Hairybiker84 »
dayglo jim wrote: Mon Apr 12, 2021 9:26 pm Can anyone recommend bean burgers that can be put on the BBQ without falling to pieces? Planning to have some in-laws round next week and they end up with corn on the cob as our attempts at finding bean burger that hold together are doomed to failure. If anyone has a recipe that works I'd be keen to give it a go.
We make these quite regularly, you can tweak the quantity of breadcrumbs to get the consistency you want, 1/2 tsp ground coriander helps the flavour. I usually use a mix of hot and sweet smoked paprika instead of the chilli powder. Don't make them too big and make sure they are well chilled in the fridge before trying to cook them. Never made the salsa so can't comment on that, did make a mango salsa to go with them once which was good!
https://www.bbcgoodfood.com/recipes/mex ... gurt-salsa
dayglo jim
Has thanked: 23 times
Been thanked: 19 times
Re: BBQ thread
Post by dayglo jim »
It was a no show from the in-laws but they'll be back. I'll give them a go when we're back into BBQ weather.
Has thanked: 778 times
Been thanked: 3216 times
Re: BBQ thread
Keepin' it simple, but delicious;
Image2021-05-13_12-01-18 by MrLongbeard, on Flickr
Re: BBQ thread
Just arrived in time for our cancelled event! 😵‍💫
i miss you images for facebook
Zimbo
Has thanked: 101 times
Been thanked: 158 times
Re: BBQ thread
Post by Zimbo »
weeksy wrote: Mon Apr 05, 2021 8:27 am
Dodgy knees wrote: Mon Apr 05, 2021 8:20 am Clean or no clean ??? 🙂👍👎
On our new Weber the grill plate is in 2 pieces, so bring into the house after every cook and clean in soapy water. We foil line the base unit every time so it's only any escaped grease that's needing cleaning on the base with a quick wipe.
Sounds like a lot of work :-)
Mine just gets turned off when I've finished cooking.
Next time I use it I let it get up to temperature (200 deg or so) and then use one of those wire brush BBQ cleaners on the griddle, comes up clean in seconds. The grease keeps it non stick as well.
Chuck the steak / chops / sausages on, when they're done turn it off and close the lid.
About once a year it gets a clean (remove the griddle plates and burner bar, and scrape any gunk off the inside of the base and lid) and the fat drain container emptied)
Been doing it like that for seven years on the current Weber and it's still going very strong!
Re: BBQ thread
3kg brisket. On the bbq for 6 hours. I overcooked it a bit, but it went down well! 👍
derek badger
Has thanked: 1090 times
Been thanked: 1748 times
Re: BBQ thread
Post by derek badger »
Taipan wrote: Sun Jun 18, 2023 3:55 pm 3kg brisket. On the bbq for 6 hours. I overcooked it a bit, but it went down well! 👍
Looks good. Next time try wrapping it in parchment and foil for the last couple of hours. It'll keep it moist.
Ant
Has thanked: 24 times
Been thanked: 161 times
Re: BBQ thread
Post by Ant »
MrLongbeard wrote: Thu May 13, 2021 5:44 pm Keepin' it simple, but delicious;
That looks delish, really really delish. What's your secret recipe for the coating/seasoning?
Been thanked: 3504 times
Re: BBQ thread
Re: BBQ thread
Bring it over then
Has thanked: 316 times
Been thanked: 1078 times
Re: BBQ thread
Post by Silly Car »
Just bought a Ninja Woodfire, managed to get 25% off on a refurbished one via eBay, ordered yesterday, arrived via DPD today.
Tonight’s tester was burgers, chipolatas and hotdogs all for asdas ‘posh’ range, simply grilled on medium with the supplied all purpose smoker pellets, I flipped everything over after 7-8 mins, everything was perfectly cooked, still juicy, hint of smoke and burgers had a crisp edge to them even though they were still juicy on the inside.
Tomorrow will be smoking a spatchcocked chicken which is currently marinating in yoghurt & tandoori spices.
Re: BBQ thread
Re: BBQ thread
'Seasoning' up the new weber griddle pan, it doesn't need it as its enamel coated cast iron, but bacon fat never did any harm
ImagePXL_20250628_180402028~2 by MrLongbeard, on Flickr
1st 1/4 pounder smash burger going on
ImagePXL_20250628_182800737 by MrLongbeard, on Flickr
Found the cloches I bought were too big to do 2 at a time in the weber pan
ImagePXL_20250628_183033401 by MrLongbeard, on Flickr
But a spritz of water before using them soon has the cheese melted
ImagePXL_20250628_183055052 by MrLongbeard, on Flickr
I would whole heartedly recommend Morrison Salt & Pepper baps over any other cob you can get from a supermarket
ImagePXL_20250628_183200596 by MrLongbeard, on Flickr
ImagePXL_20250628_181842355~2 by MrLongbeard, on Flickr
Re: BBQ thread
Well the sun is shining so it's time to play / experiment, and break out my as yet untouched rotisserie and temp probes, so let's see how this goes
Re: BBQ thread
Re: BBQ thread
Simple batch cooking for a weeks worth of lunches
ImagePXL_20260215_112428785~2 by MrLongbeard, on Flickr
ImagePXL_20260215_121019607-EDIT by MrLongbeard, on Flickr
