Oh FFS.... An oil question...
- Has thanked: 2288 times
- Been thanked: 2673 times
Re: Oh FFS.... An oil question...
Right now it has my custom blend 12 1/2 - 42 1/2 in it...
1 quart of 20/50 & then bring it up to capacity 10/40, Mobil1.
- Has thanked: 602 times
- Been thanked: 4528 times
I was advised to use mineral 20w50 to run mine in and then go to 20w50 semi Castrol once it was run in by a friend who builds race engines for a living, I think fully synthetic would be a bit thin for a roller bearing crank and also a waste of money.
I had some laying around. It's not going to be in there long.Le_Fromage_Grande wrote: Thu Apr 16, 2026 10:07 pm I was advised to use mineral 20w50 to run mine in and then go to 20w50 semi Castrol once it was run in by a friend who builds race engines for a living, I think fully synthetic would be a bit thin for a roller bearing crank and also a waste of money.
Seen a lot of people saying to stick 20/50 GTX in it... which is odd as several years ago Castrol changed the formula & stated "don't use this new version in your motorcycle".. but apparently a bunch of people do.
Over here people just dump in a quart of ATF to dislodge all the snarge* shortly before an oil change, drive maybe 20 miles.Supermofo wrote: Thu Apr 16, 2026 1:38 pm A lot of people just don't bother with services from looking at this![]()
I've done it with old Ford 390 V8's, but just let it idle for 20 minutes or so. The issue is all that crap potentially blocking the pick up in the oil pan and/or the filter etc.
* USAF term for a mix of snot & garbage
I'll be sticking some Motul 5100 in it after 1000 miles or so. Peace of mind is cheap.
Many years ago I pulled into a Shell gas station in Santa Monica on a Z1 or KZ, at another pump was the rattiest XS1100 I've ever seen. Rider looked like an extra from Mad Max having a bad day.
He walks over to me & says "Could ya spare a couple of bucks for a quart of Motul?"
Great line, cracked me up, I gave him $5.
Bigjawa
- Has thanked: 225 times
- Been thanked: 969 times
It doesn't help that a lot of places don't take oil out from underneath, they suck it out via the dipstick tube. Ford/Pug 1.6 diesels die if you do that.Skub wrote: Thu Apr 16, 2026 12:38 pm According to a mate in the car trade,they see lots of wagons with the top end sludged up. It seems especially prevalent among car drivers who piddle about at a maximum of 2k on the tacho. The damn things need a good thrashing at least now and again.
Long intervals between oil changes won't help sludge issues either.
The only bike I use fancy oil in is the K12, the Boxers get cheapo 20w50 mineral.
- Has thanked: 245 times
- Been thanked: 1228 times
- Contact:
Fully synthetic in 1955 Triumph.
What was the question?
I hope no-one’s trying to ride around without any Synerlec!
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
- Has thanked: 20857 times
- Been thanked: 13672 times
On holiday a few years back, we met a guy who was a land rover tech, and he said the same thing. He had a LR Ingenium 2.0 with 180k miles which had never had any engine problems. He said its because he does 6k oil changes. The LR schedule is 20k oil changes!Skub wrote: Thu Apr 16, 2026 12:38 pm According to a mate in the car trade,they see lots of wagons with the top end sludged up. It seems especially prevalent among car drivers who piddle about at a maximum of 2k on the tacho. The damn things need a good thrashing at least now and again.
My old neighbour was an AA man who had many sorry tales of cars. He said all modern diesels choke themselves to death with town use. He also reckoned the only diesels he'd put faith in were ones made in the 90s and early 2000s!
