What is your assembly goo-goo muck of choice?
Has thanked: 10967 times
Been thanked: 3999 times
Re: What is your assembly goo-goo muck of choice?
mangocrazy wrote: Sat Feb 07, 2026 7:21 pm John just got back to me - this is what he said:
I genuinely would recommend the Ducati “grey” sealant (prob made by three bond) no problem to use on mag cases it releases quite easily, cleans off easily and it works
I've seen the Ducati Threebond compound on eBay, but I'd be slightly surprised if it was any different to vanilla TB. But it's OK on mag cases, which is good.
Which actual Threebond product is it? (Their website has quite a few products....)
Has thanked: 2557 times
Been thanked: 4167 times
Having had a look on Threebond's website in this section: https://threebond-europe.com/products/b ... esistance/
I'd say that 1184 sounds the closest match to your requirements. This is the spec for it:
1184 Synthetic rubber, semi-drying liquid gasket Rubber type, elastic type, excellent gap filling ability and LPG resistance Typically used as motorcycle crank case sealant, for various flange and threaded applications with good gap fill for large clearance Grey 9.5 Pa.s -40 to +150°C
But that's just my best guess. YMMV.
Been thanked: 4529 times
Rockburner wrote: Sat Feb 07, 2026 10:28 pm
Just buy it through Ducati, then you know you've got the right stuff
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
Being a miserable old codger I use wellseal. It works perfectly and stays soft so easy to dismantle. If there's also a paper gasket involved I grease one side and give a very thin coat of wellseal on the other.
Been thanked: 2730 times
There's a joke about 90% of Red Hermatite manufactured is still in existence and blocking an oilway.
iansoady wrote: Sun Feb 08, 2026 12:51 pm Being a miserable old codger I use wellseal. It works perfectly and stays soft so easy to dismantle. If there's also a paper gasket involved I grease one side and give a very thin coat of wellseal on the other.
Depends how often I think it's going to be coming apart, Z1100R rocker box cover just gets greased, same for the clutch, alternator cover is stuck on with 3 bond, they tend to leak from the alternator cover.
Nobby
Has thanked: 175 times
Been thanked: 767 times
Post by Nobby »
Hansil 781
ZRX61 wrote: Fri Feb 06, 2026 10:35 pm Threebond. I managed to get P&W R2800 18cyl radials oil tight with that stuff. I was accused of sorcery.
mangocrazy wrote: Sun Feb 08, 2026 12:00 am Having had a look on Threebond's website in this section: https://threebond-europe.com/products/b ... esistance/
Sold.
