Descaling a kettle??
- Has thanked: 1926 times
- Been thanked: 1728 times
Re: Descaling a kettle??
Vinegar or citric acid will do it
Or as you are up a French mount, some cheap as chips Spar cola.
Any acid will break it down quite quckly ....
- Trinity765
- Has thanked: 3138 times
- Been thanked: 3188 times
They could use a stove top kettleZRX61 wrote: Sun Dec 07, 2025 3:55 pmThat's because 110v kettles take a week to get *almost* to the boil. Expats bring 240v kettles from the UK, put a clothes drier/welder plug on them to run them at 220v.KungFooBob wrote: Sun Dec 07, 2025 11:18 am Do what the septics do, boil your water in the microwave![]()
- Been thanked: 9495 times
- Been thanked: 2727 times
I didn't think the Americans knew how to boil water. Based on my trying to find a decent cup of tea over there.KungFooBob wrote: Sun Dec 07, 2025 11:18 am Do what the septics do, boil your water in the microwave![]()
- Has thanked: 19569 times
- Been thanked: 4950 times
When I was up hte mountain I didn't need the descale the kettleMr Moofo wrote: Sun Dec 07, 2025 5:11 pm Vinegar or citric acid will do it
But I'm not sure I can bring myself to buy any kind of cola !!
Not sure it's worth it - no probs with my coffee machine so unless the ducati jobbie makes a decent cup of Yorkshire Tea, not worth the money !!!KungFooBob wrote: Sun Dec 07, 2025 6:13 pm Get one of these instead...
https://ducati.cuisine-barista.com/
- Has thanked: 781 times
- Been thanked: 1072 times
Still slow unless they have a decent induction hob.Trinity765 wrote: Sun Dec 07, 2025 5:36 pmThey could use a stove top kettleZRX61 wrote: Sun Dec 07, 2025 3:55 pmThat's because 110v kettles take a week to get *almost* to the boil. Expats bring 240v kettles from the UK, put a clothes drier/welder plug on them to run them at 220v.KungFooBob wrote: Sun Dec 07, 2025 11:18 am Do what the septics do, boil your water in the microwave![]()
Do you want a cheap way to descale it or not?Noggin wrote: Sun Dec 07, 2025 7:46 pmWhen I was up hte mountain I didn't need the descale the kettleMr Moofo wrote: Sun Dec 07, 2025 5:11 pm Vinegar or citric acid will do it
Any acid will break it down quite quckly ....![]()
- Felix
- Has thanked: 714 times
- Been thanked: 2038 times
- Has thanked: 8035 times
- Been thanked: 5693 times
Or get a Brita water filter instead. I use one for all the water that goes in the kitchen kettle and the (now abandoned*) coffee machine.
Unfortunately, at £3.50-£4.00 a filter (if you use actual Brita filters) - a filter lasts a month - it's not the cheap solution that was requested.
*Gone back to filter coffee.
- Trinity765
I have always lived in a hard water area and as far as I am aware it's not dangerous just annoying.
Mr Moofo wrote: Sun Dec 07, 2025 10:58 pmDo you want a cheap way to descale it or not?Noggin wrote: Sun Dec 07, 2025 7:46 pmWhen I was up hte mountain I didn't need the descale the kettleMr Moofo wrote: Sun Dec 07, 2025 5:11 pm Vinegar or citric acid will do it
I am considering that - mostly for the coffee machine. I suspect the cheapest option will be citric acid for the kettle - cos it doesn't need doing "that" often, it's just a smidge annoying when there's bits of scale in the bottom of the mug!! I always used to leave the last little bit of tea because of that, just out of practice cos haven't had to worry about it for so long being up highCount Steer wrote: Mon Dec 08, 2025 8:07 amOr get a Brita water filter instead. I use one for all the water that goes in the kitchen kettle and the (now abandoned*) coffee machine.
Me too. It's not any kind of danger or risk I'm thinking of, it's purely the annoyance of getting scale in that last mouthful of teaTrinity765 wrote: Mon Dec 08, 2025 9:33 am I have always lived in a hard water area and as far as I am aware it's not dangerous just annoying.
We live in a hard water area and my approach is multi-stage:
1. Make sure the kettle has a mesh filter in front of the spout so you don't get the bits going though
2. Get a little iron wool ball thingy to chuck in the kettle to attract the limescale. Got from La Range for a quid or so
3. Use the Oust stuff that the Count mentioned. Not only is it 100% effective at making the kettle like new, but fun too to see how close you can get to exploding the water out of the kettle without quite doing it.
4. Not give too much of a shit.
Zimbo
- Has thanked: 101 times
- Been thanked: 158 times
We live in a hard water area and I descale the kettle weekly, I use Kilrock descaler that I buy in Savers, works brilliantly. Boil kettle half full, transfer to sink, tip some descaler in and try to judge how much to add to get it to foam to the top but not actually over, leave five minutes, rinse, back to new again.
The manufacturers can dress this up however they like, it's still just citric acid.Zimbo wrote: Mon Dec 08, 2025 5:59 pm We live in a hard water area and I descale the kettle weekly, I use Kilrock descaler that I buy in Savers, works brilliantly. Boil kettle half full, transfer to sink, tip some descaler in and try to judge how much to add to get it to foam to the top but not actually over, leave five minutes, rinse, back to new again.
As with most "branded" items, they're not inventing new chemical elements. They're just rebranding existing well known agents as often as not making them worse with colourings, perfumes and dilutions.
Having said that if WD40 (paraffin) ever did make an aftershave, I'd be first in the queue.
I'd be lost if they invented an aftershave that smells like WD40 or CastrolR
Done before Christmas, but still a shiny inside on the kettle
Fanx boyz for being my mumsnet type advisors
Which method did you use in the end??Noggin wrote: Fri Jan 02, 2026 8:12 am Done before Christmas, but still a shiny inside on the kettle![]()
Fanx boyz for being my mumsnet type advisors![]()
I got some citric acid from Amazon (couldn't be arsed to deal with people in an actual pharmacie!) - looked up the amount needed for a kettle and reduced by a third (cos my kettle is teeny tiny!) and boiled it, left it to coolCount Steer wrote: Fri Jan 02, 2026 9:27 amWhich method did you use in the end??Noggin wrote: Fri Jan 02, 2026 8:12 am Done before Christmas, but still a shiny inside on the kettle![]()
Wiped out with a kitchen scourer thingy (wiped, not scrubbed!) and all done
Taff
- Has thanked: 334 times
- Been thanked: 1191 times
I just noticed this morning that our water supply has changed again
Every now and then the water changes flavour a bit and the kettle stops furring up - that's come to an end
water = a rock smoothie according to Hannah Fry
