Using EVs for home storage has been mentioned here several times, but I didn't the tech was already installed.Mike1976 wrote: Tue Nov 11, 2025 11:33 am Elon Musk et.al. are way ahead of you. His worldwide fleet of battery storage "tankers" are on wheels...
Wonder how many people realise modern electric vehicle (EV) charging points support bidirectional charging (also known as Vehicle-to-Grid or V2G).
Great idea though.
Hang on lads, I've had an idea...
- Has thanked: 7585 times
- Been thanked: 5912 times
Re: Hang on lads, I've had an idea...
Buckaroo
- Has thanked: 1047 times
- Been thanked: 1105 times
IKR but the maths insist the idea is a no brainer. Appx 1.7 million EVs with say, 75kWh storage each equates to 125 GWh of stored capacity.Horse wrote: Tue Nov 11, 2025 5:16 pmUsing EVs for home storage has been mentioned here several times, but I didn't the tech was already installed.Mike1976 wrote: Tue Nov 11, 2025 11:33 am Elon Musk et.al. are way ahead of you. His worldwide fleet of battery storage "tankers" are on wheels...
Great idea though.
That's almost two days worth of a nuclear power station running at full chat. Once you see that, you just know someone must have a cunning plan. If I owned an EV, I'd be checking the fine print...
- Has thanked: 781 times
- Been thanked: 1068 times
If I could spare half of my EV battery for the grid to use as it pleases then I bought the wrong EV. I'd have a powerwall in my garage just for my use as I doubt the leccy companies would ever make it cost effective to effectively rent them my capacity.Mike1976 wrote: Tue Nov 11, 2025 8:03 pmIKR but the maths insist the idea is a no brainer. Appx 1.7 million EVs with say, 75kWh storage each equates to 125 GWh of stored capacity.Horse wrote: Tue Nov 11, 2025 5:16 pmUsing EVs for home storage has been mentioned here several times, but I didn't the tech was already installed.Mike1976 wrote: Tue Nov 11, 2025 11:33 am Elon Musk et.al. are way ahead of you. His worldwide fleet of battery storage "tankers" are on wheels...
Great idea though.
If feed in tarrifs also cut the standing charge in half then I'd consider sharing, the suppliers are also becoming the customer so why not?
If I were a betting man I'd bet there will be that option, rake in a share of feed in tariff (unless you have your own export meter and license etc.).Mussels wrote: Tue Nov 11, 2025 9:52 pm If I could spare half of my EV battery for the grid to use as it pleases then I bought the wrong EV. I'd have a powerwall in my garage just for my use as I doubt the leccy companies would ever make it cost effective to effectively rent them my capacity.
Plus of course the option to rent out your car as a self driving taxi while you don't need it.
Makes me wonder if AI is smart enough yet to find a free parking spot you could just send the thing off to.
I'm so glad I didn't grow up in that world. I reckon we've seen the best of the British roads...
- Has thanked: 2271 times
- Been thanked: 2654 times
Already an issue in Califailure....Mike1976 wrote: Tue Nov 11, 2025 8:03 pm That's almost two days worth of a nuclear power station running at full chat. Once you see that, you just know someone must have a cunning plan. If I owned an EV, I'd be checking the fine print...
- Has thanked: 2844 times
- Been thanked: 3495 times
I'm probably thinking nonsense here, infact highly likely, but, is it possible to buy a solar panel and basically plug it into a house/garage socket and reverse your digital meter and therefore produce free lecky. ???
- Pirahna
- Has thanked: 2996 times
- Been thanked: 1741 times
No. You need some bits of kit in between the panel and the socket.Dodgy69 wrote: Mon Dec 08, 2025 3:08 pm I'm probably thinking nonsense here, infact highly likely, but, is it possible to buy a solar panel and basically plug it into a house/garage socket and reverse your digital meter and therefore produce free lecky. ???
The output from the panel will be in DC, the voltage will be variable depending on how much sunlight is reaching the panel. My panels are 48v, 500w. To make some sense of this the output from the panels is routed through a charge controller then an inverter, mine is an integrated unit. What you do with the output from the inverter is up to you. Mine is split between DC to a battery bank and AC to the house. When the sun goes, or there's not enough power coming from the panels, the batteries take over.
- Cousin Jack
- Has thanked: 2980 times
- Been thanked: 2513 times
I wouldn't be relying too much on it to cook the Sunday roast.
Our Coastwatch hut is off-grid, so we have solar panels; a wind turbines and some fair sized batteries. We also only operate during the day, so any wind power at night goes straight to the battery. Even with all that we struggle at times to run 3 radios, a router, a radar and a CCTV. An electric kettle is impossible.
If you really want to live off-grid you need to invest in some serious fuck-off kit.
- Pirahna
I've got more panels and batteries on order. Because of my position on the side of a hill in a forest, I struggle in the winter. I can survive a couple of overcast days but am struggling by the end of day three. I'm going to take it from 8 to 18 panels (500w) and double the battery from 10 to 20kw/h. That's another €4000 worth of kit. That should get me through an overcast week, or let me use the electric kettle and air fryer.Cousin Jack wrote: Mon Dec 08, 2025 4:46 pm
Grid electric isn't an option.
What about a small nuclear reactor.Cousin Jack wrote: Mon Dec 08, 2025 4:46 pm I wouldn't be relying too much on it to cook the Sunday roast.
- Cousin Jack
Never thought of that. Do Amazon sell them?Dodgy69 wrote: Mon Dec 08, 2025 7:43 pmWhat about a small nuclear reactor.Cousin Jack wrote: Mon Dec 08, 2025 4:46 pm I wouldn't be relying too much on it to cook the Sunday roast.
If you really want to live off-grid you need to invest in some serious fuck-off kit.![]()
- Has thanked: 20806 times
- Been thanked: 13610 times
So you're €8k into it so far? How long before you realise that investment or is it simply Hobson's choice? IIRC you said you wouldn't be there that long and would move into a town in a few years or have i got that wrong?Pirahna wrote: Mon Dec 08, 2025 5:01 pmI've got more panels and batteries on order. Because of my position on the side of a hill in a forest, I struggle in the winter. I can survive a couple of overcast days but am struggling by the end of day three. I'm going to take it from 8 to 18 panels (500w) and double the battery from 10 to 20kw/h. That's another €4000 worth of kit. That should get me through an overcast week, or let me use the electric kettle and air fryer.Cousin Jack wrote: Mon Dec 08, 2025 4:46 pm
- Pirahna
My nearest grid electricity is perhaps a kilometer away. There's no guarantee the electricity company would connect me even if I wanted to. If they said yes, the cost of the connection would make solar look like a low cost option. So it's solar or nothing.Taipan wrote: Tue Dec 09, 2025 10:46 amSo you're €8k into it so far? How long before you realise that investment or is it simply Hobson's choice? IIRC you said you wouldn't be there that long and would move into a town in a few years or have i got that wrong?Pirahna wrote: Mon Dec 08, 2025 5:01 pmI've got more panels and batteries on order. Because of my position on the side of a hill in a forest, I struggle in the winter. I can survive a couple of overcast days but am struggling by the end of day three. I'm going to take it from 8 to 18 panels (500w) and double the battery from 10 to 20kw/h. That's another €4000 worth of kit. That should get me through an overcast week, or let me use the electric kettle and air fryer.Cousin Jack wrote: Mon Dec 08, 2025 4:46 pm
So, although costly initially, it will have added value to the place?Pirahna wrote: Tue Dec 09, 2025 1:16 pmMy nearest grid electricity is perhaps a kilometer away. There's no guarantee the electricity company would connect me even if I wanted to. If they said yes, the cost of the connection would make solar look like a low cost option. So it's solar or nothing.Taipan wrote: Tue Dec 09, 2025 10:46 amSo you're €8k into it so far? How long before you realise that investment or is it simply Hobson's choice? IIRC you said you wouldn't be there that long and would move into a town in a few years or have i got that wrong?Pirahna wrote: Mon Dec 08, 2025 5:01 pm
I reckon a home wind turbine kit would be generating well here atm. 🌪
