Fitting new tyres
Scuffmark
- Has thanked: 264 times
- Been thanked: 191 times
Re: Fitting new tyres
I've ridden off road bikes most of my life and removing/changing tyres goes with the hobby. Its only in the last 5 or so years that I've been changing road bike tyres though and that was only because the local fitter started charging £25 per tyre.
With road tyres hand tools wise its 2 tyre levers, 3 rim protectors, a valve core remover and tyre soap ..... A valve snake is handy if its a tube type and you can use glass cleaner ( the spray on type) as an alternative lubricant.
I use one of these as my bead breaker whether its off road or road tyres ...
https://www.ebay.co.uk/itm/Warrior-Moto ... SwwKNdlIh8
And balance them using one of these..
https://www.ebay.co.uk/itm/Red-Motorcyc ... SwCdRew4Ce
Like most things in life the more you practice the easier it gets, but i found if your having to force things when changing a road bike tyre your not using the right technique.
- Has thanked: 2556 times
- Been thanked: 4167 times
I'd just like to put it on record that I hate changing tubed tyres. They really are the devils spawn. Just had to do it on both 350LC wheels after they came back from powder coating and they both fought me every inch of the way. Plus there's always the danger you'll nip the tube and plunge yourself into an even deeper well of hurt.
Did I mention I hate inner tubes with a passion?
- Has thanked: 12607 times
- Been thanked: 8538 times
One little hint is to put some air in so it doesn't sit in the well where the tyre levers will nip it.mangocrazy wrote: Mon Jan 18, 2021 9:57 pm I'd just like to put it on record that I hate changing tubed tyres. They really are the devils spawn. Just had to do it on both 350LC wheels after they came back from powder coating and they both fought me every inch of the way. Plus there's always the danger you'll nip the tube and plunge yourself into an even deeper well of hurt.
Yes. Also I still see people struggling to get the valve stem through the rim. This is one occasion when the Haynes manuals actually get it right (I think the original method actually comes from Avon). Slightly inflate the tube and put it in the tyre. Offer the rim up so that the valve stem goes through the hole and run the securing nut on a couple of threads. Then fit the first bead followed by the send using the normal technique.
Scuffmark
Something like this makes getting the valve through the rim alot easier...
https://www.ebay.co.uk/itm/Tyre-Changin ... SwqDpfID~o
Scuffmark
At this time of year, leaving the tyre next to a radiator for a few hours to cook at gas mark 6 helps.... obviously that doesn't apply to Yorickmangocrazy wrote: Mon Jan 18, 2021 9:57 pm I'd just like to put it on record that I hate changing tubed tyres. They really are the devils spawn. Just had to do it on both 350LC wheels after they came back from powder coating and they both fought me every inch of the way. Plus there's always the danger you'll nip the tube and plunge yourself into an even deeper well of hurt.
@mangocrazy Do you have a build thread for the lc ?
But you don't need it if you do it properly. Here at around 3 minutes......Scuffmark wrote: Tue Jan 19, 2021 8:06 pm Something like this makes getting the valve through the rim alot easier...
https://www.youtube.com/watch?v=oMAMKz2C7_o
... although he'd make his life easier if he used some lubricant.
Yup, did all that. Getting the correct amount of air in the tube is critical. Too much and the tyre doesn't go fully down into the well. Too little and you run the risk of nipping the tyre.iansoady wrote: Tue Jan 19, 2021 10:03 am Yes. Also I still see people struggling to get the valve stem through the rim. This is one occasion when the Haynes manuals actually get it right (I think the original method actually comes from Avon). Slightly inflate the tube and put it in the tyre. Offer the rim up so that the valve stem goes through the hole and run the securing nut on a couple of threads. Then fit the first bead followed by the send using the normal technique.
And the tyre had been sat by a radiator for several hours prior to fitment.
A lot of the problem is that old rims (like on the LC) are so narrow and there is so little room for manoeuvre, especially when tubes are involved.
Still hate inner tubes.
I 'sort of' did a build thread on another forum that I've been a member on for years. Here's a link. Haven't updated it since about September...Scuffmark wrote: Tue Jan 19, 2021 8:24 pmAt this time of year, leaving the tyre next to a radiator for a few hours to cook at gas mark 6 helps.... obviously that doesn't apply to Yorickmangocrazy wrote: Mon Jan 18, 2021 9:57 pm I'd just like to put it on record that I hate changing tubed tyres. They really are the devils spawn. Just had to do it on both 350LC wheels after they came back from powder coating and they both fought me every inch of the way. Plus there's always the danger you'll nip the tube and plunge yourself into an even deeper well of hurt.
Did I mention I hate inner tubes with a passion?![]()
https://ridersite.com/viewtopic.php?f=35&t=13813
Scuffmark
Thanks.... Really enjoyed the read and great to see the restoration and some of the downsides and how they've been overcome... Top jobmangocrazy wrote: Wed Jan 20, 2021 12:42 pm
Scuffmark
He mentions the lube and the didn't use it till later oniansoady wrote: Wed Jan 20, 2021 10:56 amBut you don't need it if you do it properly. Here at around 3 minutes......Scuffmark wrote: Tue Jan 19, 2021 8:06 pm Something like this makes getting the valve through the rim alot easier...
There's not enough side wall flex in a motocross/ enduro tyre to fold it over the rim like that and place the valve stem into the rim. Its where I learned to skin my knuckles changing tyres.... Old habits and all that malarkey
Excellent stuff - glad you enjoyed the read. Just been re-fitting some of the powder coated bits (in addition to the wheels) that i received the other day. It's reminded me of a truism - ALWAYS re-tap any threads even if they appear to have been masked off. The same applies when getting parts back from blasting.Scuffmark wrote: Wed Jan 20, 2021 2:27 pmThanks.... Really enjoyed the read and great to see the restoration and some of the downsides and how they've been overcome... Top jobmangocrazy wrote: Wed Jan 20, 2021 12:42 pm
https://ridersite.com/viewtopic.php?f=35&t=13813![]()
