Page 2 of 3
Re: Need to be concerned?
Posted: Fri May 30, 2025 9:42 pm
by MingtheMerciless
Don’t force it, use a larger hammer!
Posted: Fri May 30, 2025 10:57 pm
by Buckaroo
Docca wrote: Fri May 30, 2025 8:31 pm
For fucks sake you shits- any sensible suggestions before I go to Reddit?
Panigale?
Posted: Sat May 31, 2025 5:06 am
by demographic
Bit of a gues as I don't have bar end mounted mirrors so I'm guessing its mounted like a normal bar end weight.
Is there an Allen bolt in the end of the weight? Loosen that a slightly, push the weight back in and tighten it up again.
The ones Ive seen had an expanding section of either rubber that expanded when it was shortened by the tightening of the bolt or a split metal collet shaped section that a tapered plug pulled into and expanded it.
I've no idea how it would just slide out without the mirror also moving round from the wind when it was loose though.
Posted: Sat May 31, 2025 8:10 am
by mangocrazy
Conventional (i.e. non bar-end) mirrors are also available.
Posted: Sat May 31, 2025 8:30 am
by Dodgy69
Is the gap the bar end expanding bolt thing or the handle bar. ?
Posted: Sat May 31, 2025 9:05 am
I thought Mr Longbeard had solved this?
Posted: Sat May 31, 2025 10:21 am
by Docca
So I’ve managed to tap the ring thing closer to the grip
When putting the indicator back in- I can’t tighten, it just spins and spins. Indicator still works
Posted: Sat May 31, 2025 11:58 pm
by derek badger
Angle grinder. Job done.
Posted: Sun Jun 01, 2025 12:09 pm
by Docca
Any genuine suggestions welcome. I’m stuck
Posted: Sun Jun 01, 2025 12:23 pm
by MyLittleStudPony
There may be a rubber insert in the bar with a threaded metal centre. The bolt connected to the bar end may cause this to pinch and thus grip the inside of the bar.
The bolt probably holds the bar end in place, which then holds the mirror in place.
This is a guess based on limited visibility!
Posted: Sun Jun 01, 2025 12:39 pm
MyLittleStudPony wrote: Sun Jun 01, 2025 12:23 pm
Sounds about right - you need it to be done up
a bit so that the rubber grips the inside of the bar sufficiently well to allow you to tigthen it. It's the gripping which is allowing you to turn.
Can you pull the indicator out of the bar? Can't really see how it all goes together....
Posted: Sun Jun 01, 2025 2:11 pm
by derek badger
Mr. Dazzle wrote: Sun Jun 01, 2025 12:39 pm
Docca can't pull anything out, have you seen how many kids he's got?!
Posted: Sun Jun 01, 2025 4:17 pm
by MingtheMerciless
Time for the Gas Axe.
Posted: Sun Jun 01, 2025 4:19 pm
For £500 plus expenses...
Posted: Sun Jun 01, 2025 6:11 pm
by MrLongbeard
Docca wrote: Sat May 31, 2025 10:21 am
There's your problem, you should have, and need to get the thing out and find out why it's gone wrong before jamming it back down the bar.
I'm going to guess it's a smidge tight so getting it out now might be tricky, but somewhere inside your bar the nut or expanding section that the indicator screw into have had a paddy.
Posted: Sun Jun 01, 2025 6:16 pm
by Docca
Posted: Sun Jun 01, 2025 6:18 pm
Posted: Sun Jun 01, 2025 6:26 pm
by ChrisW
KungFooBob wrote: Sun Jun 01, 2025 6:18 pm
You're missing the washer, rubber part and m8 nut.
Might still be inside the handlebar.
Posted: Sun Jun 01, 2025 6:35 pm
by Noggin
Someone must be close enough to go offer a hand ???
Posted: Sun Jun 01, 2025 6:57 pm
by MrLongbeard
ChrisW wrote: Sun Jun 01, 2025 6:26 pm
They will be they've no way of escaping, they should be on the other side of the collar he tapped back into the bar.
Best guess is the nut has gone walk about if he can't get it to engage the threaded bar on the indicator.
