Apologies - not kept up with the thread, but just an update on my life with the Leaf.
Yesterday, spur of the moment trip to Llandrindod Wells to pick up some parts, 48 mile round trip from my house.
50 miles showing on the charge, but this basically tells you there's no way you'll do 50 miles on it.
No problem I thought...
There is a BP Pulse rapid charger in Llandod, half mile from my destination. 20 minute splash n dash and job jobbed.
Checked Zap Map, last used an hour ago.
Got to the charger to come home, screen is frozen on the charger so can't begin. Call the helpline number on the unit, helpful lady reboots the charger, which takes 5 mins.
After the reboot, screen comes to life, game on..
Open the Pulse app to start a charge, poor signal so slow.
I have £3.90 i=credit, but you need £5 minimum to start a charge, so I have to top it up, again slow.
Credit added, plug in, try to charge, error.
Try again, in case it's a glitch. Same error.
Call Pulse again. Was told the Chademo charging side of the unit must be faulty, but they're being fazed out for CCS, and they don't plan on fixing Chademo points as a result.
CCS side was working, so that's why Zap Map said the unit's operational..
So, I realistically don't have enough charge to crawl home, but I can stop in Rhayader and use one of the four fairly new Dragon Charge points en route.
These are 22 kilowatt AC. My Leaf (2016) can only charge at 7 kilowatts maximum on AC. So - it takes 4 hours to charge fully at this rate, which by the book gives you 120 miles. Day was very cold, which the batteries hate, so you're looking at 80 miles. So, my splash and dash, to add 20 miles to be on the "safe side" will take an hour
Rolling up to the charger, the car tells me I don't have sufficient charge to get home. Plug in to the Dragon charger, green light on top of 3 out of the 4 says working, OK.
Plug in, app never works, so scan the QR code and go the the website. Find a charger near me finds the inop. unit next door, but not mine, so can't start a charge
Call the helpline number on the unit.. helpful man checks it out, and as I have a Dragon account, with enough credit, he can start a charge remotely for me.
I then wait for the battery to creep up to 30 miles, to cover my 12 mile trip home (an hour).
Just coming towards home, car shows 12 miles left..
48 mile round trip, 3 stressful, hours
I drive it like a Chelsea Pensioner, make good use of the regeneration system, always on eco mode (restricted power) and wrap up warm so I don't need the heater.
So basically, the day is nigh when the car becomes a shopping trolley. Great investment.
Then
