The Triumph
Has thanked: 2098 times
Been thanked: 2561 times
Re: The Triumph
Right ignore what I said about resting and not doing any work on the bike.... this is my way of resting and I was bored, the sun was shining and I just wanted to get on with it. Rear subframe on the way out.
New to me shock put in temporarily
Drag link bearings are all shot and falling out! No wonder it felt rather rubbish. Replacement shock will make a difference, but the bearings need replacing. Got a special hardened set on the way and lots of seals and sleeves. £110 later for just that bit.... but it is necessary.
Been thanked: 15500 times
Re: The Triumph
That's the new shock?
Re: The Triumph
Yes, but I have to clean that whole area out. I just put it in the bike to get it moveable again. Photo of old shock coming just now...
Re: The Triumph
Old rear shock...
Re: The Triumph
New one has been given a good wipe with ACF50 as well. So will hopefully last a bit better than the last one. This is destined for the bin.
Big Red
Has thanked: 3 times
Been thanked: 81 times
Re: The Triumph
Post by Big Red »
Can I ask what is the advantage of using the abba stand the other way around? as the handle is usually on the l/h side with the supporting legs of the stand pointing forward.
It looks like you fitted it from the r/h side.
Re: The Triumph
The ground slopes away, so it was safer using Abba stand in that direction in this instance. On a flat surface it would be the other side. :-)
Druid
Has thanked: 352 times
Been thanked: 1107 times
Re: The Triumph
Post by Druid »
The suspension linkage bearings are a weak point on these. They don't apply much grease at the factory and even though they are a service item - every 3 years/18000 miles- they are often ignored. One of the first things I did to mine was to clean and grease the bearings and fit new seals
Re: The Triumph
Druid wrote: Tue Mar 08, 2022 7:31 pm The suspension linkage bearings are a weak point on these. They don't apply much grease at the factory and even though they are a service item - every 3 years/18000 miles- they are often ignored. One of the first things I did to mine was to clean and grease the bearings and fit new seals
I did these on the BMW straight off. They were in decent enough nick. Sadly my earlier Triumphs were also rubbish with lack of grease etc. But, at least it will be done and make a good difference!
A_morti
Has thanked: 412 times
Been thanked: 824 times
Re: The Triumph
Post by A_morti »
the_priest wrote: Tue Mar 08, 2022 5:03 pm Drag link bearings are all shot and falling out!
Yep, very common fault. The bearings live *right there* in the spray from the rear wheel.
Googled pic:
What's really fun is that (unless it's been done before) the bolt at the bottom of the shock link won't come out without removing the exhaust headers off the bike. More common to cut it off and put a new one in from the other side, since that avoids touching potentially-troublesome exhaust studs and replacing exhaust gaskets. Apart from that, getting the long bolt out of the swingarm can be an absolute swine of a job, since it corrodes and seizes in the sleeve.
Good luck!
Hairybiker84
Has thanked: 69 times
Been thanked: 108 times
Re: The Triumph
Post by Hairybiker84 »
I took my headers off but getting the old gaskets out was hard work.
Re: The Triumph
Yes that is going to be the nightmare job. I don’t feel like taking the headers off as the nuts look to be troublesome and sometimes things should be left alone. I will sort the drag links and take it from there.
Hairybiker84
Re: The Triumph
Cutting the bolt would be the way for me, the headers where definitely a bit risky and my bike had done nothing like the miles yours has (and led a pampered life with only the original purchaser and then his nephew as previous owners to me). I've still got the special tool for the steering stem nut if yours has the holes in it? You're welcome to it if you haven't got one.
A_morti
Re: The Triumph
Post by A_morti »
However you go at it, I'd suggest go straight for the big guns. Smack it a good few times with a big hammer to loosen any corrosion. If you have heat, use it. Do these things on your first try before rounding the bolt due to trying without them.
Hairybiker84 wrote: Wed Mar 09, 2022 12:00 pm I've still got the special tool for the steering stem nut if yours has the holes in it? You're welcome to it if you haven't got one.
It's a really useful thing. Don't recommend to do what I did before getting one - trying to use the wrench from a grinder. Its pins were the right offset, but weren't long enough to get a good purchase, so it slipped and scratched the nut and top yoke.
Has thanked: 779 times
Been thanked: 3221 times
Re: The Triumph
A_morti wrote: Wed Mar 09, 2022 9:45 am Apart from that, getting the long bolt out of the swingarm can be an absolute swine of a job, since it corrodes and seizes in the sleeve.
I remember that dance with my 1050.
Smack it through with a hammer until the shoulder shows, put spanner on shoulder and lever, keep adding spanners as more shoulder shows and keep levering, if it binds solid put a spanner between 2 spanners and hit with hammer slowly forcing the bloody thing out, repeat until out or you run out of spanners
Re: The Triumph
Hairybiker84 wrote: Wed Mar 09, 2022 12:00 pm Cutting the bolt would be the way for me, the headers where definitely a bit risky and my bike had done nothing like the miles yours has (and led a pampered life with only the original purchaser and then his nephew as previous owners to me). I've still got the special tool for the steering stem nut if yours has the holes in it? You're welcome to it if you haven't got one.
I have the funny nut tool for the steering stem. One of the things I bought from a fellow flogging off all his Triumph bits and pieces.
I'll have to get a new bolt for that bottom joint as if I cut the old one off, ah well, may as well do it properly. Thankfully the nut moves fine and I will be able to get the bolt shifting as it is spinning freely at the moment.
Re: The Triumph
This not not fun. Top sleeve is corroded in place. Need a M15 bolt to ease it out. Time to shop around. Also the bottom bearings and sleeves are shot. The one sleeve is rusted in solid. The other came out as the needle bearings had fallen out. Still, going to have to keep trying.
Re: The Triumph
the_priest wrote: Fri Mar 18, 2022 3:50 pm Need a M15 bolt to ease it out. Time to shop around.
Have a look at that bolt at the back end of the swing arm, the one you have to loosen to adjust the eccentric do dad for chain tension
Re: The Triumph
MrLongbeard wrote: Fri Mar 18, 2022 3:59 pm
Yup, that is the one. No movement. Going to soak it with PlusGas and try again. Ordered more bearings. Got 10% off, so worth it, pays for the delivery. M14, typo error.
Re: The Triumph
I was gonna say...you can get M15s, but they're gonna be a damned sight rarer than M14s!
