Tool purchases
- Has thanked: 2942 times
- Been thanked: 1883 times
Re: Tool purchases
Not sure if this was the wisest buy, you'll find out tomorrow after I attempt to remove the rear calliper bolts from the naughty X-Trail.
- Has thanked: 143 times
- Been thanked: 497 times
Re: Tool purchases
Hope you’ve got sufficient clearance, I regularly have to do the two spanner trick to get enough leverage to shift calliper bolts as I don’t have an impact gun and never seem to have enough room to get a breaker bar in.
- Has thanked: 15957 times
- Been thanked: 10248 times
Re: Tool purchases
I simply cannot imagine working on a vehicle without using one of these now. One of the best things I've ever bought. Removing the 19 x 8mm bolts from the Tmax engine casing was literally done in a minute or so. Fab things!
- Has thanked: 9829 times
- Been thanked: 10145 times
Re: Tool purchases
Yep. Every home should have one.
- Has thanked: 6378 times
- Been thanked: 4755 times
Re: Tool purchases
Ooh. Want. Is that the DTW700/701?
Q? Are standard sockets ok with them? According to the blurb you need to use impact grade sockets - never knew there was such a thing.
- Been thanked: 7530 times
Re: Tool purchases
Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
Re: Tool purchases
Mine are all shiny ones.KungFooBob wrote: ↑Mon Oct 25, 2021 4:09 pm Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
Re: Tool purchases
My impact ones are black, like Boris Johnson's soul.Count Steer wrote: ↑Mon Oct 25, 2021 4:18 pmMine are all shiny ones.KungFooBob wrote: ↑Mon Oct 25, 2021 4:09 pm Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
Re: Tool purchases
So I'd need to buy some more sockets? That's a and aLe_Fromage_Grande wrote: ↑Mon Oct 25, 2021 4:24 pmMy impact ones are black, like Boris Johnson's soul.Count Steer wrote: ↑Mon Oct 25, 2021 4:18 pmMine are all shiny ones.KungFooBob wrote: ↑Mon Oct 25, 2021 4:09 pm Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
Re: Tool purchases
Standard sockets are fine,just squint a bit when you fire the trigger.Count Steer wrote: ↑Mon Oct 25, 2021 4:03 pm Q? Are standard sockets ok with them? According to the blurb you need to use impact grade sockets - never knew there was such a thing.
- Has thanked: 2248 times
- Been thanked: 1242 times
Re: Tool purchases
I've seen impact sockets give up too, not a pretty sight. Heavy use though..Skub wrote: ↑Mon Oct 25, 2021 5:45 pmStandard sockets are fine,just squint a bit when you fire the trigger.Count Steer wrote: ↑Mon Oct 25, 2021 4:03 pm Q? Are standard sockets ok with them? According to the blurb you need to use impact grade sockets - never knew there was such a thing.
Re: Tool purchases
Dunno which one it is. I have 3 of them! 2 Fakitas and one genuine! Yes and impact drive should use impact sockets and I do with my 240v Clarke CEW1000 but with this, I've been using my Teng 1/4 drive sockets with a step down adaptor. I used it to take all the hinges out of some furniture I was breaking up. It just rattles out the screws better than a drill with a screwdriver bit in. No wonder all the trades use them.Count Steer wrote: ↑Mon Oct 25, 2021 4:03 pmOoh. Want. Is that the DTW700/701?
- Has thanked: 218 times
- Been thanked: 689 times
Re: Tool purchases
Black and single hex? My life is almost complete...Le_Fromage_Grande wrote: ↑Mon Oct 25, 2021 4:24 pmMy impact ones are black, like Boris Johnson's soul.Count Steer wrote: ↑Mon Oct 25, 2021 4:18 pmMine are all shiny ones.KungFooBob wrote: ↑Mon Oct 25, 2021 4:09 pm Aren't 'impact grade' the black ones in the tool box that no ones uses because the shiny ones are much nicer?
- Has thanked: 1346 times
- Been thanked: 1722 times
Re: Tool purchases
Got this a while ago, think it was about fifteen quid secondhand.
Torque screwdriver.
Torque screwdriver.
- Has thanked: 836 times
- Been thanked: 1239 times
Re: Tool purchases
I always prefer impact sockets, they have six points rather than twelve so great for removing difficult nuts without mangling them.
Re: Tool purchases
Sometimes, you can get six point sockets with thin walls for tight spaces and impact sockets usually have pretty thick walls so not so good when its tight.
Although impact sockets for rattle guns.
- derek badger
- Has thanked: 769 times
- Been thanked: 1135 times
Re: Tool purchases
Just took a punt on three of these (untested) for £12.50!demographic wrote: ↑Mon Oct 25, 2021 7:01 pm Got this a while ago, think it was about fifteen quid secondhand.
Torque screwdriver.
1 x Red Torquemaster Standard: (8 ozf in - 36 lbf-in) (600 gmf cm - 40 kgf cm) (6 - 406 c N m).
1 x Red Torquemaster Standard: 8 oz-in to 36 lb-in. Left & Right Hand
1 x Green Torquemaster Minor: 3 oz-in to 12 lb-in.
