Energy bills
irie
Has thanked: 1482 times
Been thanked: 411 times
Re: Energy bills
Post by irie »
Still appears that 12+ month duel fuel fixed price deals are, with the exception of Shell Energy, restricted to existing customers.
Has thanked: 1745 times
Been thanked: 2084 times
Re: Energy bills
Hot water setting down to 40° 🙂👍
Has thanked: 1874 times
Been thanked: 2170 times
Re: Energy bills
Will be moving from a 3 bed to a 4 bed with two extra rooms, larger study and separate dining room. More to heat and more to power. Works out at around £100 a month more, ceilings are higher as well, so more space to heat in that aspect as well. At least it does have fairly decent DG windows and doors.
Re: Energy bills
Hot water setting raised to 45°, received complaints. ☹👎
Has thanked: 6185 times
Been thanked: 5087 times
Re: Energy bills
the_priest wrote: Sun Sep 24, 2023 2:55 pm Will be moving from a 3 bed to a 4 bed with two extra rooms, larger study and separate dining room. More to heat and more to power. Works out at around £100 a month more, ceilings are higher as well, so more space to heat in that aspect as well. At least it does have fairly decent DG windows and doors.
Check for cavity & loft insulation.
I've no idea about grants, or payback periods, for either (especially after Sunak's announcement). Wall insulation made a good difference for, reducing draughts in particular.
Hoonercat
Has thanked: 339 times
Been thanked: 327 times
Re: Energy bills
Post by Hoonercat »
Install ceiling fans to push the heat back downwards in winter. They work a treat :thumbup:
Re: Energy bills
Now then...Martin Lewis is telling us, now is the time to fix, cap just gone up 10%. Go on the compare sites and check.
Cap changes every 3 months, fix is for 12 months. So you might win for a while but could lose later in that year.
I checked mine and a current fix would save me £8 a year, I won't bother. 🤷‍♂️
Has thanked: 808 times
Been thanked: 4793 times
Re: Energy bills
Hoonercat wrote: Sun Sep 24, 2023 7:07 pm
Failing that, put your sofa on a stack of pallets.
You're welcome. :thumbup:
