Energy bills
Has thanked: 1814 times
Been thanked: 1163 times
Re: Energy bills
Dodgy69 wrote: Sat Jul 22, 2023 5:10 pm My mate is going full electric...We can't make gas but we can make electricity, so he's replacing all his rads with infrared wall panel type rads. Apparently they heat objects and furnishings rather than space. With good insulation he reckons they work well.
Solar panels and a battery to get through the dark hours. Initial outlay about 12k, going by some sparky he's been talking to. Insulation in key, but it's definitely food for thought as gas is the winter killer on bills.
I live in Spain with year round sunshine. In the winter I switch over to bottled gas for hot water, I've just taken out the log burner and installed a pellet burner and I have two bottles had heater things. Gas bottles have the price pegged by the government, they're just over 15 euro at the moment.
Admittedly my daily charge window is only about four hours in mid winter, the sun goes round the mountain. Because of the height of the sun panels generally half what they do in winter. I can survive a few cloudy days with no problems. Your mate using only electric won't survive a cloudy morning without resorting to mains if he's trying to heat the house, water, cook etc.
Has thanked: 10261 times
Been thanked: 6885 times
Re: Energy bills
We looked at solar panels, but too much outlay.
Even for our big place with the pool, leccy bill is only 110€ a month.
40 of that is the fixed bit.
Gonna take a lot of years to pay us back.
Has thanked: 2549 times
Been thanked: 2285 times
Re: Energy bills
I did a quick and dirty calculation for our place a few days ago.
About 15 year payback for solar panels, about 30 years for an air source heat pump.
Sorry, the planet will need to look out for itself.
Re: Energy bills
I've been to Gran Canaria and Tenerife in last 6 months.
Saw literally hundreds, maybe thousands of giant turbines.
Our island only has about 15.
If they don't care, why should I?
Has thanked: 6185 times
Been thanked: 5087 times
Re: Energy bills
Yorick wrote: Sat Jul 22, 2023 7:20 pm Our island only has about 15.
Any idea 'why'?
Has thanked: 2550 times
Been thanked: 6240 times
Re: Energy bills
I don't think I'd like to ever go full gas or full electric simply cause I wouldn't like to bet on the price of either in the long term!
Re: Energy bills
Not many choices for me, the only utility I have is mains water.
Re: Energy bills
What's your pressure like and how much are turbines? ;)
MyLittleStudPony
Has thanked: 614 times
Been thanked: 405 times
Re: Energy bills
Post by MyLittleStudPony »
Cousin Jack wrote: Sat Jul 22, 2023 7:09 pm I did a quick and dirty calculation for our place a few days ago.
You can take the savings and leave the next generation to pay for it. On top of the saving you've already taken.
Re: Energy bills
Joking aside, be careful how far you take the "someone else's problem" viewpoint eh? 99% of your lifestyle, if you've vaguely western based, relies on someone else doing something for you :D
Re: Energy bills
Mr. Dazzle wrote: Sat Jul 22, 2023 8:08 pm What's your pressure like and how much are turbines? ;)
I assume that was meant for me?
Water pressure is a bit pants, it's drinking water but there's not enough pressure to pipe it directly to the house. It fills a 1000 litre tank in an old underground water deposit that would leak it all away if filled (hence the tank). There is an on demand pump which gives me 3 bar in the house.
There's zero chance of running a wind turbine. I'd never get the license required for it and my bit of the mountain is quite sheltered.
Re: Energy bills
I was just taking the piss, I had visions of you sticking a water turbine on the end of your hosepipe ;)
Actually...no idea how much power you could get from that. Get me a calculator! :lol:
Re: Energy bills
Might be a bit quicker now.
My gas boiler is about 10 years old, so is likely to peg out sooner or later.
I've considered installing an air source heat pump, but it would require more than removing the boiler involve installation of a huge tank (currently combi boiler). Unlikely to be an equivalent cost to a boiler replacement.
Re: Energy bills
Horse wrote: Sat Jul 22, 2023 7:24 pm
Any idea 'why'?
Politics. And Endesa, the leccy gas burning company has some influence, apparently.
Has thanked: 1346 times
Been thanked: 1722 times
Re: Energy bills
Mussels wrote: Sat Jul 22, 2023 5:20 pm
In winter when the sun is weak and he needs more energy for heating where is the electricity going to come from?
It is probably possible in a purpose designed building but a big hurdle for me is ventilation, I think the numbers are always based on not having any.
In the energy efficient buildings I've worked on its more based on ventilation control rather than not having any.
Airtight (ish) building with a heat recovery unit to use outgoing warm air to heat incoming cold air.
To be fair these buildings have generally been designed to be efficient from the outset and arent leaky wind tunnels. Even ones designed to be good still need pretty much all the tradesmen onboard with sealing it up well (even the sparks and plumbers need to up their fucking game a lot cos theyre bad for cutting holes in the vapour control layers and not sealing em up) and usually its better to airtest before it's plasterboarded then on completion to check that the plumbers and sparks havent forgotten something then cut loads of holes in the joint to get cables or pipes through.
The trick seems to be get tradesmen who're interested in the result and keep hold of em cos they're few and far between.
Has thanked: 1745 times
Been thanked: 2084 times
Re: Energy bills
Water meter fitting tomorrow. 🙂👍
Re: Energy bills
Dodgy69 wrote: Thu Jul 27, 2023 3:29 pm Water meter fitting tomorrow. 🙂👍
Water bills are funny here.
Something like
20 m3 = 50c per unit
30 m3 = 90c
40 m3 = 1.20
50 m3 = 3.50
Generally about 40 units.
But if we have a bad month with problems with pool etc, the bills double.
Re: Energy bills
12 months here is £536. Neighbour got meter fitted, bills down to 26 instead of 44 ish a month. Similar usage.
Re: Energy bills
Mine is around 6 euro a month.
Ant
Has thanked: 39 times
Been thanked: 227 times
Re: Energy bills
Post by Ant »
What we've all decided to do is, all but one neighbour goes on a water meter, then we'll all share the one non metered outside tap and go fucking wild.
