The costs of the network provider, eg Western Power Distribution, which actually owns and maintains the wires to your house, plus (I think) the costs of the meter provider (who is usually different again).Dodgy knees wrote: ↑Sat Mar 19, 2022 10:31 am What is the standing charge part of our bills supposed to justify.
Energy bills
- Cousin Jack
- Has thanked: 2551 times
- Been thanked: 2285 times
Re: Energy bills
- Has thanked: 164 times
- Been thanked: 308 times
Re: Energy bills
I've just realised that if I was using the same amount of oil and electric that I was a few years back I'd be looking at paying £19,500 for it this year.
No wonder I've stocked up on a fair bit of wood and got the insulation a bit better sorted!
- Has thanked: 6376 times
- Been thanked: 4753 times
Re: Energy bills
According to t'papers, 23% of electricity is used by stuff on stand-by and/or keeping their little lights shining. Can't be right can it? Maybe overnight. Possibly. Apparently phone chargers and all the other things with transformers in the plug draw current even when not charging. (Do they?).
Looks like granny was right to switch everything off at the socket every night.
- Has thanked: 6188 times
- Been thanked: 5087 times
Re: Energy bills
How many 'smart' meters, with little display screens all plugged into the mains, have been distributed?
- Been thanked: 6244 times
Re: Energy bills
Transformers presumably have inductive losses in them even when they're not outputting anything useful. The 240V side is always "on" isn't it.
I'm gonna have an experiment! My little smart meter reads down to 10s of Watts I believe, I wonder if it can pick up the effect of me turning phone chargers off.
Mrs D and I don't tend to turn our work computers off at night, we probably should. We just turn the screens off. Every morning our smart meter shows we burned about 20p over night. I kinda assumed it was the fridge but it warrants thinking about.
Re: Energy bills
AndMr. Dazzle wrote: ↑Thu Mar 24, 2022 9:31 am
Phone chargers, tv, bt tv box (or whatever), wifi router, oven and microwave clocks, alarm clock, toothbrush charger, gas boiler ... all sitting, sipping little bits of electric!
Re: Energy bills
I'm going to do an experiment. We had a pond pump installed recently - it runs 24/7 I'm going to see if I can save what it costs by a) switching stuff off b) replacing the last few halogens with LED bulbs - which I already have and was using as the halogens failed.
I should put a timer on the pump and turn it off at night, but it's tricky to get a timer in the all-weather socket box. Probably needs a bigger box fitting.
- Has thanked: 1746 times
- Been thanked: 2085 times
Re: Energy bills
I wonder if the meter itself uses power. I fancy a little experiment myself.
Re: Energy bills
If it's creating power, order another 1,000 and harness the output.Dodgy knees wrote: ↑Fri Mar 25, 2022 7:15 am I wonder if the meter itself uses power. I fancy a little experiment myself.
Re: Energy bills
I'm currently paying £100pcm direct debit for my gas and leccy. By way of reference, in the period 24 Feb/24 March I used £98 worth.
I logged in this morning to find that Bulb have arbitrarily increased my DD to £158pcm. My first response is "Fuck off, you can't just do that" (presumably I'm wrong there, 'cause they did ) followed by "I only used £98 in February and it's getting lighter/warmer now".
Obviously the prices are going up, but that seems quite cheeky. Was struck me as really cheeky though is that the system won't let me manually change my DD back down to anything less than £144pcm. This is "to stop you building up lots of debt in winter". That's great and everything, but in Feb I used £98 and in January it was £102 so in summer I'd expect to be several tens of pounds "up". I've spent the last few years doing £60pcm DD and always being in credit. That was pre price increase though of course.
Still pondering what to actually do
- Been thanked: 7530 times
Re: Energy bills
You need a smartplug, they're usually a lot more compact than the mechanical rotary timers... just as long as it's within Wi-fi/Zigbee range of your router/gateway.Count Steer wrote: ↑Thu Mar 24, 2022 10:05 am I'm going to do an experiment. We had a pond pump installed recently - it runs 24/7 I'm going to see if I can save what it costs by a) switching stuff off b) replacing the last few halogens with LED bulbs - which I already have and was using as the halogens failed.
Then you can also set the schedule from your mobile or tell alexa to turn it off, etc..
Re: Energy bills
Cheers. I didn't realise they were that much smaller. I've got Hive so will investigate that. It's unlikely that the signal from the main router will reach, but I put in a booster/relay to reach the cabin which will. May be an issue operating off that though as it appears as a slightly different address type thingy. Not sure if Hive type devices will operate off a subsidiary?KungFooBob wrote: ↑Tue Mar 29, 2022 9:12 amYou need a smartplug, they're usually a lot more compact than the mechanical rotary timers... just as long as it's within Wi-fi/Zigbee range of your router/gateway.Count Steer wrote: ↑Thu Mar 24, 2022 10:05 am I'm going to do an experiment. We had a pond pump installed recently - it runs 24/7 I'm going to see if I can save what it costs by a) switching stuff off b) replacing the last few halogens with LED bulbs - which I already have and was using as the halogens failed.
Re: Energy bills
Is the Hive Wifi or does it connect to a separate gateway device that plugs into your router?
If it's the latter it's probably Zigbee, which will need either an additional gateway or Zigbee booster.
- Has thanked: 340 times
- Been thanked: 327 times
Re: Energy bills
The price cap is increasing by 54% on April 1st. As you say, you'll be using less now that spring is here but it will still cost you more per month than last year, and a lot more once next winter arrives.Mr. Dazzle wrote: ↑Tue Mar 29, 2022 9:07 am I'm currently paying £100pcm direct debit for my gas and leccy. By way of reference, in the period 24 Feb/24 March I used £98 worth.
Re: Energy bills
If people can submit meter reads on-line, now's the time to do it. Wouldn't want them charging this month's energy at next month's prices eh?
Re: Energy bills
Mine aren't....and won't be while I have a choice.
Re: Energy bills
Have all the suppliers agreed on a shared standard for them yet?
It used to be that your smart meter became dumb if you changed supplier.
- irie
- Has thanked: 1482 times
- Been thanked: 411 times
Re: Energy bills
Ours isn't either, and also won't be while we have the choice ...
- irie
Re: Energy bills
Try to change it down in a few small steps, could be a threshold level thingy.Mr. Dazzle wrote: ↑Tue Mar 29, 2022 9:07 am I'm currently paying £100pcm direct debit for my gas and leccy. By way of reference, in the period 24 Feb/24 March I used £98 worth.
