NBT I've just bought my forever bike part4 , The Final Edition!
Re: NBT I've just bought my forever bike part4 , The Final Edition!
If it has damper rod forks they don't have compression damping, only rebound.
Has thanked: 20853 times
Been thanked: 13667 times
Le_Fromage_Grande wrote: Fri Feb 27, 2026 6:04 pm If it has damper rod forks they don't have compression damping, only rebound.
I remember one bike I had, but not which one, i had to drill holes in the rods before i fited the valves and then cut the spacers by the thickness of the valves,iyswim?
Taipan wrote: Fri Feb 27, 2026 5:14 pm No, there is a complete lack of compression damping on the front. Reading up on them i'm not the only one to notice it.A few people have fitted these to theirs.
https://webshop-hyperpro.com/product/st ... c-750-x-3/
Incoming..... :lol:
Taipan wrote: Fri Feb 27, 2026 6:44 pm
Yep, that's what you have to do with cartridge emulators.
Found my old Fakerapovic of my old nc750x in the shed-of-plenty! Might bung it on to see how it sounds! It’ll look a bit shite on brand new bike though, so maybe not! :think:
fuck man, that's a bit ropey.
Tis only a Honda,it'll be fine. :thumbup:
Just needs a rub with some autosol :)
weeksy wrote: Mon Mar 16, 2026 3:47 pm fuck man, that's a bit ropey.
Took it off and bunged it in the shed-of-plenty without cleaning it. :oops: It'd clean up okay for sure, but I always thought it looked too small for the bike?
asmethurst99
Has thanked: 1327 times
Been thanked: 482 times
Post by asmethurst99 »
Taipan wrote: Mon Mar 16, 2026 4:18 pm
Mines even worse and cheaperer - does improve the sound though
asmethurst99 wrote: Mon Mar 16, 2026 6:24 pm
Its a sound I miss. I might clean this one up and if it comes up clean enough, put it on and see how it sounds? Then if I like hearing it, maybe treat it to a Black Widow 300mm one as they're only £200?
Been thanked: 3504 times
Have a newun. 👍
Just clicked past 1000 miles now. Still miss cruise control. I've adjusted to the power drop from the AT though. Being on 17" wheels and a much lower CoG makes it a much easier bike in traffic. Its a very competent commuter and I cant see it going anywhere as its doing exactly what I thought it would do, and what I bought it to do. Only thing I might change it for, is if the next model they release has cruise control?
Has thanked: 12604 times
Been thanked: 8535 times
Taipan wrote: Tue Mar 24, 2026 10:33 am Just clicked past 1000 miles now. Still miss cruise control. I've adjusted to the power drop from the AT though. Being on 17" wheels and a much lower CoG makes it a much easier bike in traffic. Its a very competent commuter and I cant see it going anywhere as its doing exactly what I thought it would do, and what I bought it to do. Only thing I might change it for, is if the next model they release has cruise control?
Just clasp some mole grips to the throttle 😀
You want an Atlas Lock, they're a bit spendy for what they are and I'm sure you can probably get a Temu version for a tenner.
KungFooBob wrote: Tue Mar 24, 2026 2:10 pm You want an Atlas Lock, they're a bit spendy for what they are and I'm sure you can probably get a Temu version for a tenner.
I need actual cruise control. I go through a few average speed camera sections, and it dead handy, when you're in one, to have CC doing the work for you!
Taipan wrote: Tue Mar 24, 2026 2:22 pm
Be a proper bad-ass biker and take your plate off :obscene-birdiedoublered:
I dislike the rider modes on the bike. You have Standard, Sport, Rain (ffs who needs rain mode on a sub 60bhp bike :wtf: ) User 1 and user 2. User 1 and 2 are programmable.
So my issue is Standard mode changes gear too quickly and only has 3/4 of available power. Sport has full power, hardly any engine braking and the gear change point is extended so it changes up much later and down earlier. What I'm looking for is a combo of standard and sport, or standard with full power is actually it. So I messed around and set User 1 to be just that. I'm pleased with that. :thumbup:
What sir needs is........a manual gearbag. :thumbup:
