From what the 2nd gen app seems to want to collect - I think Sonos scoop up a huge amount of user data (presumably for marketing purposes). I couldn't believe the info the app said it needed when I tried to install it. It got deleted very quickly, the first gen app still works fine.KungFooBob wrote: Wed Jun 05, 2024 4:21 pm I thought the Sonos speakers themselves used their own version of wireless and only used the internet proper for downloading to a single speaker that shared it all to the others?
- Has thanked: 10903 times
- Been thanked: 3950 times
- Yambo
- Has thanked: 512 times
- Been thanked: 1403 times
gremlin wrote: Wed Jun 05, 2024 3:31 pm According to BT, I get 36mbps, 24/7. No breaks in service. Must be mistaken, sir.
Yet these are the figures from the BT Wholesale speed test they insist is is accurate and the only one they recommend.![]()
Who wrote the program, Fujitsu?
- gremlin
- Has thanked: 1095 times
- Been thanked: 5834 times
Similar results from all speed tests, i.e anywhere from 32mbpd down to big, fat zero. BT will only accept the results from their one, mind. And even then, tell you it's not true.Rockburner wrote: Wed Jun 05, 2024 4:18 pmIs that from their own systems?Mr. Dazzle wrote: Wed Jun 05, 2024 4:14 pm Whether or not 36 is enough probably depends on what you're paying for![]()
They took us off our 150 contract 'cause it wasn't available any moreAmazing what you can get down a glass thread with a few flashes of light.
What do you get from speedtest.net?
Time to get shot of them.gremlin wrote: Wed Jun 05, 2024 4:59 pmSimilar results from all speed tests, i.e anywhere from 32mbpd down to big, fat zero. BT will only accept the results from their one, mind. And even then, tell you it's not true.Rockburner wrote: Wed Jun 05, 2024 4:18 pmIs that from their own systems?Mr. Dazzle wrote: Wed Jun 05, 2024 4:14 pm Whether or not 36 is enough probably depends on what you're paying for![]()
May or may not help though right? Possible the infrastructure is the same whoever who go with.
- Has thanked: 19438 times
- Been thanked: 4936 times
How easily does a wire failRockburner wrote: Wed Jun 05, 2024 4:17 pm They only failover at a broken connection over the wires.
- Has thanked: 3629 times
- Been thanked: 2492 times
If its 1970s era telecoms wires there is a good chance it is aluminium rather than copper, ally is notorious for getting incredibly brittle with age. There is a telecoms cabinet in Newhaven which has ally cabling into and out of it, the techs hate opening it as there is a good chance that the act of opening or closing the doors will put additional faults on the lines running through the cabinet.
- Has thanked: 20754 times
- Been thanked: 13583 times
Got caught bunking work today.
I was supposed to go onsite today but frankly I couldn't be arsed, so i decided to wfh instead. I had a couple of people coming in to see me but easily rescheduled them. But, I forgot I had a teams meeting with my Head of Dept and a couple of people from other depts. No problem, i'll just wing it and use back ground blur! It was all going swimmingly until my French bulldog decided to jump on my lap and see who i was talking too!
Busted!
- gremlin
Got VM coming around next week to survey Chez Gremlin to see if they can run a cable into the property. As long as it comes down the south drive and into the servant quarters, via the trout lake, there shouldn't be a problem.Rockburner wrote: Wed Jun 05, 2024 5:10 pmTime to get shot of them.gremlin wrote: Wed Jun 05, 2024 4:59 pmSimilar results from all speed tests, i.e anywhere from 32mbpd down to big, fat zero. BT will only accept the results from their one, mind. And even then, tell you it's not true.Rockburner wrote: Wed Jun 05, 2024 4:18 pm
They did come around some years back. The bloke knocked at my door, we went outside and he told me how much road they'd have to dig up to get the cable to the front of my property. Then the amount of drive they'd have to lift to run the cable to the front. Then the faff of how to get it to the right room in the house. He looked at me, shrugged and said, 'I'd stick with Sky if I were you, mate'
I had a conversation with BT that went like this :gremlin wrote: Thu Jun 06, 2024 9:30 amGot VM coming around next week to survey Chez Gremlin to see if they can run a cable into the property. As long as it comes down the south drive and into the servant quarters, via the trout lake, there shouldn't be a problem.Rockburner wrote: Wed Jun 05, 2024 5:10 pmTime to get shot of them.gremlin wrote: Wed Jun 05, 2024 4:59 pm
me: "What sort of connection can I get at this address?"
BT: "Hmm, well - the address is over 4km from either of the nearest exchange boxes, and there's no fibre provision listed*, so you're likely to get about 2Mbs at best, regardless of what contract we offer"
me: "Is there anything we can do about getting a better connection?"
BT: "Move."
me: "..... "
* The kicker to that statement: there's a fucking fibre exchange less than 100 yards from the house (the fibre lines for the villages to the south of us run down our road), but because there's only 4 addresses in the postcode we're at the very bottom of the OpenReach list for provisioning.
- gremlin
I asked the BT guy when they could arrange fibre at my property. After looking it up, he said, 'Yes, we're in your area. It'll be done by 2026'.Rockburner wrote: Thu Jun 06, 2024 9:48 am
* The kicker to that statement: there's a fucking fibre exchange less than 100 yards from the house (the fibre lines for the villages to the south of us run down our road), but because there's only 4 addresses in the postcode we're at the very bottom of the OpenReach list for provisioning.![]()
- Sunny
- Has thanked: 3510 times
- Been thanked: 1661 times
When we moved here (having been on Virgin all-you-can-eat cable directly to to the house at the last place) the best we could get was 7Mbs.
Fibre was due to get to the cabinet three months later, it ended up arriving 6 months later, and now we get a heady 20Mbs.
Mostly thanks to the fact that there's still a mile of copper between the cabinet and our house.
It's surprisingly not that bad - fine for work video calls and streaming etc.
It's only really noticeably a PITA when you want to upload something sizable - I think our upload speed is 0.5Mbs give or take
The moat around your castle and the ramparts were likely a hindrance too.gremlin wrote: Thu Jun 06, 2024 9:30 am Got VM coming around next week to survey Chez Gremlin to see if they can run a cable into the property. As long as it comes down the south drive and into the servant quarters, via the trout lake, there shouldn't be a problem.
- Has thanked: 625 times
- Been thanked: 9424 times
- Cousin Jack
- Has thanked: 2963 times
- Been thanked: 2505 times
I took a ferry from Mevagissy to Fowey. And back.
Sadlonelygit
- Has thanked: 94 times
- Been thanked: 796 times
Fitted a pelmet/curtains me and swmbo made for some friends bridal suite at their chambre D'hote/ gites business, then got asked 'can you fit a dishwasher?'
So this pm was spent pulling out the old machine and refitting the new. Only real issue was the door was integral, so spent more time lining it up than fitting the machine!
Sadlonelygit
Have you looked into starlink.gremlin wrote: Thu Jun 06, 2024 10:01 amI asked the BT guy when they could arrange fibre at my property. After looking it up, he said, 'Yes, we're in your area. It'll be done by 2026'.Rockburner wrote: Thu Jun 06, 2024 9:48 am
Several people this side of the channel I know have it and are far happier with it than orange fibre, which is notoriously flaky in the country side.
- Been thanked: 2720 times
Had a day without the electric, SSE are putting a new pole and transformer for a new mobile phone mast. Lots of small jobs done too, new flex on the hob, not just T&E, finished moving the washing machine, made a temporary shelf and rail for my overalls to go where the washing machine was, and did a bit of shed stuff.
But I've never been to me...
- Has thanked: 2258 times
- Been thanked: 2638 times
Apparently I lit a fire under the right ass at my Dr's office.
A month ago I was prescribed a med...
Went to chemist to pick it up. They tell me they can't fill it because whatever.
This morning I call my insurance carrier, they tell me to call the State office
Call made, "we haven't seen anything about that med for you" & point the finger at my Dr
I drop by to light the fire.
Explained that he needed to get his shit sorted after a fucking month. Reception gal said she's on it.
I got a call from his office on the way home.
I then get FOUR more calls at home, one after the other so close together that the phone rang with the next call immediately after I hit the *end call* button.
Shit sorted
Then I get a call from the chemist a couple of minutes after those four "We're ordered the med & will call again when it's ready for pick up"
Then I get ANOTHER call right after that from the Dr's office again.
Shit sorted
