Do auxiliary lights help you be seen?
- Has thanked: 2550 times
- Been thanked: 6241 times
Re: Do auxiliary lights help you be seen?
Corner reflector innit?
That's why modern military aircraft don't have their tail fins at 90°to the fuselage, it makes a very good radar reflector. They left 'em on the moon too! Corner reflectors that is, not military aircraft.
Have you ever noticed how road signs flash in time with your indicators, but nobody else's? That's cause they use the same concept, so they reflect your own indicator light back to you really well but not everyone else's.
https://en.wikipedia.org/wiki/Lunar_Las ... xperiments
https://en.wikipedia.org/wiki/Corner_reflector
- Has thanked: 7810 times
- Been thanked: 2527 times
Mr. Dazzle wrote: ↑Wed Dec 13, 2023 12:55 pm Corner reflector innit?
.... They left 'em on the moon too! Corner reflectors that is, not military aircraft.
or did they.....
- Has thanked: 6186 times
- Been thanked: 5087 times
FYI Luminance values for the figure on leftHorse wrote: ↑Wed Dec 13, 2023 10:58 am Next is of two figures in full hi-vis gear near a full chevrons & battenburg vehicle. Both vehicle and PPE use microprismatic materials.
This picture was taken using a luminance camera. The scene was lit by overhead lighting and a single vehicle's dipped beam headlamps (note that the ankle bands reflect more light than the bands higher up the PPE).
- Most of the fluorescent clothing has a luminance of about 2 cd/m2
- The reflective stripes on the upper body are about 3 or 4 cd/m2
- The reflective stripes around the ankles are about 40 cd/m2
- Has thanked: 1745 times
- Been thanked: 2084 times
We might, but no guarantee that drivers willDodgy69 wrote: ↑Thu Dec 14, 2023 6:59 pm Seen these....
https://www.ebay.co.uk/itm/374686698943 ... media=COPY
- Cousin Jack
- Has thanked: 2549 times
- Been thanked: 2285 times
No guarantees on anything, but I am inclined towards the inverse of the Swiss Cheese model. Lots of little things that MAY help increase the odds of being seen. Still no guarantee, but the odds improve, maybe only slightly but every little helps.
So I will use extra lights, retro reflective hi viz, z-line, trying to maintain a safety bubble, and anything else to hand. I would use a yellow light cover, but they don't fit.
Cousin Jack wrote: ↑Fri Dec 15, 2023 10:06 am No guarantees on anything, but I am inclined towards the inverse of the Swiss Cheese model. Lots of little things that MAY help increase the odds of being seen. Still no guarantee, but the odds improve, maybe only slightly but every little helps.
With all of them, be clear on their limitations Vs what you expect to gain.
Then ride as if none of it works
But what if some of them MAY make it worse...?
Hmm. Tis a pickle
- Cousin Jack
Tis why I have an orange hi-viz rather than yellow, my extra lights have a switch, and I actually think about when/if stuff may help.Mr. Dazzle wrote: ↑Sat Dec 16, 2023 11:19 amCousin Jack wrote: ↑Fri Dec 15, 2023 10:06 am No guarantees on anything, but I am inclined towards the inverse of the Swiss Cheese model. Lots of little things that MAY help increase the odds of being seen. Still no guarantee, but the odds improve, maybe only slightly but every little helps.
Hmm. Tis a pickle
