114 Fat Bob FXFBS
- Has thanked: 6264 times
- Been thanked: 4614 times
Re: 114 Fat Bob FXFBS
£130!
What's it made from, triple refined angel's ear wax?
- Has thanked: 2325 times
- Been thanked: 3380 times
I presume that's a lifetime supply?
Or do Harley insist on you using their very own Milwaukee-mined, blended and blessed lubricants? I can't imagine that the specification is particularly special, I mean what's peak revs on an H-D?
- ChrisW
- Has thanked: 2729 times
- Been thanked: 1920 times
- Has thanked: 532 times
- Been thanked: 7242 times
It's not a unit construction engine, I imagine there'll be one type of oil for the engine, one for the gearbox and another for the clutch.
So not as easy or as cheap as just buying 4l of 10W40 Semisynth.
Three Hole Change!
It's not a porno, it's how you service a Harley.
https://2lanelife.com/blogs/bike-tips-m ... change2022
- ChrisW
Hence the she-wee and assorted paraphernalia!KungFooBob wrote: ↑Fri Jan 06, 2023 7:03 pm Three Hole Change!
- MrLongbeard
- Has thanked: 579 times
- Been thanked: 2289 times
I wish.mangocrazy wrote: ↑Fri Jan 06, 2023 6:45 pm I presume that's a lifetime supply?
No they don't but any other brand is coming out at the same cost give or take
4 qts in one hole, 1 qt in another and 2 qts in another
Same oil (20w50) for engine and trans, so why they are separate chambers god knows, different oil for the primary, I could've knocked off 40 quid by not going for the synthetic stuff, but mehKungFooBob wrote: ↑Fri Jan 06, 2023 6:58 pm It's not a unit construction engine, I imagine there'll be one type of oil for the engine, one for the gearbox and another for the clutch.
I've started using Smith and Allan oils, they're an independent refiner/blender and their prices are substantially lower than those of the widely-advertised competition. They have a bewildering variety of lubricants covering all manner of applications, but this is a link to their motorcycle offerings:
https://www.smithandallan.com/motorcycle-oils
- Has thanked: 467 times
- Been thanked: 232 times
Hang on a minute, this is a tractor engine, not some hyper car. Get yourself down to the local farmers market, they'll have what you need for dead cheap.KungFooBob wrote: ↑Fri Jan 06, 2023 6:58 pm It's not a unit construction engine, I imagine there'll be one type of oil for the engine, one for the gearbox and another for the clutch.
Hadn't seen those; I've used oils from this group https://www.westwayoils.co.uk/mangocrazy wrote: ↑Fri Jan 06, 2023 7:19 pm I've started using Smith and Allan oils, they're an independent refiner/blender and their prices are substantially lower than those of the widely-advertised competition. They have a bewildering variety of lubricants covering all manner of applications, but this is a link to their motorcycle offerings:
Any of those would be fine for a Harley engine - it's not as if they're tuned to the nuts or built to high tolerances.
Absolutely - all the old jokes about Harley-Ferguson and Massey-Davidson spring to mind...westers151 wrote: ↑Fri Jan 06, 2023 8:16 pmHadn't seen those; I've used oils from this group https://www.westwayoils.co.uk/mangocrazy wrote: ↑Fri Jan 06, 2023 7:19 pm I've started using Smith and Allan oils, they're an independent refiner/blender and their prices are substantially lower than those of the widely-advertised competition. They have a bewildering variety of lubricants covering all manner of applications, but this is a link to their motorcycle offerings:
I'm sure that the usage I'm going to put my bikes to do not need mega-expensive branded oils. I'm also fairly sure that the stuff that Smith & Allan sell will be equivalent to the more expensive branded options. The only bike that I'll use pukka branded stuff for is the Duke 690, as that has a tiny sump capacity and works its oil hard; everything else will get S & A...
Bit unfair on the later HD engines like the Milwaukee-Eight. Sure it's not hugely stressed but it's not exactly a ditch pump either.
It's a Harley engine, nothing about them are high tech.Count Steer wrote: ↑Fri Jan 06, 2023 9:45 pm Bit unfair on the later HD engines like the Milwaukee-Eight. Sure it's not hugely stressed but it's not exactly a ditch pump either.
- MrLongbeard
Thank god.westers151 wrote: ↑Fri Jan 06, 2023 10:23 pm
I want an engine that I can strip in my garage with basic tools, not that I'll ever need to unless I fancy dropping in a new cam (actually on the cards) or going big bore 131ci.
- Has thanked: 626 times
- Been thanked: 4072 times
It's got more moving parts than my 4 cylinder Kawasaki, seems a bit over complicated to me.MrLongbeard wrote: ↑Fri Jan 06, 2023 10:57 pmThank god.westers151 wrote: ↑Fri Jan 06, 2023 10:23 pm
- Has thanked: 7727 times
- Been thanked: 2401 times
Ooooo they do a CR40mangocrazy wrote: ↑Fri Jan 06, 2023 7:19 pm I've started using Smith and Allan oils, they're an independent refiner/blender and their prices are substantially lower than those of the widely-advertised competition. They have a bewildering variety of lubricants covering all manner of applications, but this is a link to their motorcycle offerings:
I love the smell of Castor-based oils in the morning - smells like victory...
- MrLongbeard
Well that was 10 minute job that turned into 4 hours, bastard design monkeys making me take the tank off just to plug stuff in beside it.
Hey ho, shifter peg, grip and cruise control fitted
PXL_20230219_104718161 by MrLongbeard, on Flickr
PXL_20230219_105858596 by MrLongbeard, on Flickr
PXL_20230219_131616193 by MrLongbeard, on Flickr
- MrLongbeard
Hopefully this is just a knackered battery rather than anything else like the starter shitting itself
