Cost of Living Crisis
Has thanked: 6187 times
Been thanked: 5087 times
Re: Cost of Living Crisis
Yambo wrote: Mon Nov 21, 2022 5:50 am
This is a great example of the BBC's one sided reporting. By failing to carry out the same measurements on the subject wearing different types and layers of clothing they are simply providing a worst case scenario.
Really? Even though they said:
The outfit was not a choice - the scientists needed direct access to the skin to conduct the experiment
The point, as I read it, wasn't to show any benefits from wearing additional layers as that would only have slowed the inevitable.
He's invited me to his laboratory to explore the impact of cold homes on our bodies
Been thanked: 2615 times
And he couldn't put clothes or any other covering over the sensors?
I'll admit I didn't read the article, is the conclusion that if you are inadequately clothed in a cold environment then you'll get cold?
cheb wrote: Mon Nov 21, 2022 8:04 am
No, it's about the effects that cold has on the brain and body.
I'll admit I didn't
read the article
Hoonercat
Has thanked: 340 times
Been thanked: 327 times
Post by Hoonercat »
cheb wrote: Mon Nov 21, 2022 8:04 am And he couldn't put clothes or any other covering over the sensors?
It's not really about how to keep yourself warm (though does mention extra layers etc at the end). It's more about showing people that even temps that aren't considered extreme can have an effect on the body. I'd like to have seen more info on the speed of the temp drop, from personal experience the speed at which it drops has a bigger impact on the body than the actual temp it drops to.
Has thanked: 6376 times
Been thanked: 4751 times
Didn't someone (Japan?) do response to cold tests on PoWs? Stuck them in ice baths etc. Don't suppose they could do that sort of thing now. :hmmm: It's established that core temperature drop is pretty devastating - and often fatal (survival times in, not particularly cold, water are a bit :shock: ).
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Post by DefTrap »
Cold isn't too bad ( my house is largely unheated) but cold and long periods of immobility really sucks your core temperature down. Plus being cold seems to make you less likely to get up and do something.
I'm not convinced that being cold makes you more susceptible to virus, I don't think it's a big factor anyway. Sitting about in crowded, heated offices with colleagues sneezing over you is the best way to get a virus.
Count Steer wrote: Mon Nov 21, 2022 8:33 am
Count Steer wrote: Mon Nov 21, 2022 8:33 am Don't suppose they could do that sort of thing now. :hmmm:
Mengele did some 'research' too ...
Count Steer wrote: Mon Nov 21, 2022 8:33 am It's established that core temperature drop is pretty devastating
This was about brain function and more.
Count Steer wrote: Mon Nov 21, 2022 8:33 am Didn't someone (Japan?) do response to cold tests on PoWs? Stuck them in ice baths etc. Don't suppose they could do that sort of thing now. :hmmm: It's established that core temperature drop is pretty devastating - and often fatal (survival times in, not particularly cold, water are a bit :shock: ).
The Germans, and AFAIK the data is still used. There was an article about in the BMJ a decade or so ago.
cheb wrote: Mon Nov 21, 2022 8:46 am
Mengele's stuff on head injuries informed development of motorcycle helmets.
irie
Has thanked: 1482 times
Been thanked: 411 times
Post by irie »
DefTrap wrote: Mon Nov 21, 2022 8:36 am Cold isn't too bad ( my house is largely unheated) but cold and long periods of immobility really sucks your core temperature down. Plus being cold seems to make you less likely to get up and do something.
Going to A&E and waiting for hours with lots of other people to be seen is a more effective way to get a virus. ;)
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Post by Yambo »
Horse wrote: Mon Nov 21, 2022 7:29 am
the same article wrote: "Ten degrees is the average temperature that people will be living in, if they can't afford to heat their homes," said Prof Bailey.
The whole thing was to draw attention to the idea that people may not be able to heat their homes and may therefore suffer some physical consequences. Without showing that a couple of layers of clothing may well mitigate the effects they are simply scaremongering. Do the same tests with different amounts and different types of clothing, show the results and people will understand that even if they can't afford to heat their homes, they don't necessarily have to be cold or suffer the effects of cold.
As has been said, this is not new research and if it is going to be linked to cost of living and not keeping warm then why not explain how it can all be dealt with.
My house is unheated except for a log burner which I only light up when it's a miserable day and then, only in the evening. I don't get hypothermia. I once rode a motorbike out of the camp gates at -15°C spent two weeks playing soldiers, riding the bike most days and rode back into camp at -12°C. During the two weeks, I measured -26°C and my radio operators, stuck up on the rim of a quarry measured -32°C. We were living in tents or the cabs/backs of trucks. No-one got hypothermia, frostbite or hospitalised. I'll give you one guess why.
The article was an opportunity to explain to the masses that yes, cold can kill and does funny things to you but hey, you can do things to mitigate these things. The scientists and the reporter should have done a bit more thinking and done a proper job. They're all slackers or maybe suffering the effects of the cold. :dunno:
Yambo
Post by Yambo »
From the same page as that article
Listen to Inside Health podcast: How can a cool homes affect your health?
Whoever was hitting the keyboard is also a bit of a slacker and the proofreader too.
The BBC is shit.
Has thanked: 16206 times
Been thanked: 3922 times
Horse wrote: Mon Nov 21, 2022 8:23 am
Isn't that fairly obvious? :1
Hoonercat
Post by Hoonercat »
Yambo wrote: Mon Nov 21, 2022 10:41 am
From the article
In an ideal world we'd all heat the room we're in to at least 18C. When that is not possible, Prof Bailey says "it's like preparing for a mountaineering expedition".
His tips are:
focus on clothes that provide good insulation such as those made of wool
gloves and warm socks are more important than a hat (but a woolly hat will help too)
switch foods to a higher carbohydrate diet
generate more body heat by moving around and not just sitting in a chair and watching TV.
Bike Breaker
Has thanked: 5 times
Been thanked: 215 times
Post by Bike Breaker »
Perhaps not now but about 25 years ago, Professor Nancy Rothwell gave the Royal Institution Christmas lectures. One of them was about surviving in heat and cold, in which she did tests on one of her students by sitting him in a bath of cold water and taking temperatures of parts on his body. I don't think she got around to effects on thinking, though.
I know if I get very cold I fall asleep.
Has thanked: 261 times
Been thanked: 1265 times
Potter wrote: Mon Nov 21, 2022 12:36 pm
Yambo wrote: Mon Nov 21, 2022 10:41 am I once rode a motorbike out of the camp gates at -15°C spent two weeks playing soldiers, riding the bike most days and rode back into camp at -12°C. During the two weeks, I measured -26°C and my radio operators, stuck up on the rim of a quarry measured -32°C. We were living in tents or the cabs/backs of trucks. No-one got hypothermia, frostbite or hospitalised. I'll give you one guess why.
The rumour is that you spent two weeks bumming each other and the friction kept you warm.
Let’s just say “they huddled.”
Has thanked: 836 times
Been thanked: 1238 times
Horse wrote: Mon Nov 21, 2022 8:23 am No, it's about the effects that cold has on the brain and body.
Horse wrote: Mon Nov 21, 2022 7:29 am He's invited me to his laboratory to explore the impact of cold homes on our bodies
There's the problem, the BBC said it was the latter but they did the former. The experiment had very little to do with living in a cold home.
Yambo
Post by Yambo »
Yeah, just a rumour mate. It was that cold, everything had shrunk down to just a bit bigger than a Royal Signals big dick.
When I try to count the dancing angels on this pinhead, they keep moving. :(
It appears the experiments looked at the effects of being cold. In this instance they used a home as the test room. :roll:
irie
Post by irie »
Mussels wrote: Mon Nov 21, 2022 1:47 pm
The BBC has its own political agenda. It was BBC scaremongering which is targeted at creating enough hysteria to provoke changes in government policy that the BBC wants to see.
