2010 ZX6R. The wifes trackbike.
Has thanked: 5451 times
Been thanked: 13092 times
Re: 2010 ZX6R. The wifes trackbike.
Indicators arrived which is nice, went on easily enough and then the back end was all put back together and tested.
NOCO genius battery charging cable removed.
Last was a final detailing, plenty of trim gel and carnauba wax to get it looking as nice as possible. I'll be shocked if he's unhappy with it considering its age.
SO as you'll have seen in the other thread.... the ZX6R is still here.
As it was in the van and we were close to MSG Racing, we had a decent chat about things and it was decided the ZX6R is staying for at least another year and was dropped at MSG Racing for a QuickShifter to be installed, along with an MOT, coolant and brake fluid swap.
Today is DYNO day.. The bike will get a few runs first to test and check the Quickshifter is working correctly.
It'll then get a power/fuelling run just out of interest.
So heading over there in a little while to stick the camera on record mode and see if i can get some decent footage :) along with a pretty dyno chart.
Bike has a shiny new MOT today which is done, along with some new brake fluid and coolant in it.
Has thanked: 1747 times
Been thanked: 2085 times
Whats stock power on them. ?
So the QS was installed up at MSG racing, then configured and set-up.
Image2021-02-06_05-14-30 by Steve Weeks, on Flickr
First vid is a quickshifter test,
Next is the power run.
On the dyno it made 110bhp, which is a nice healthy figure and power curve. All happy and good.
Imagezx6rdyno by Steve Weeks, on Flickr
Scuffmark
Has thanked: 264 times
Been thanked: 191 times
Post by Scuffmark »
Its a screamer alright :lol:
Sounds great... liking the quick shifter too .. Sounds like it operates better at higher rpm?
Has thanked: 9833 times
Been thanked: 10147 times
I thought they were a good 10-12 bhp up on 110?
Scuffmark wrote: Sat Feb 06, 2021 5:44 pm Its a screamer alright :lol:
Yeah we chatted about that, below 7000rpm the kill time is all screwy on 600s, so they work better when it's getting a beating. First one we tried was TERRIBLE, because the killtime needed adjusting and the other dyno guy was doing it at too low an rpm. I've made sure MRs Weeksy is aware.
It's not too disimilar with many other QSs i think, the KTM 790 works a lot better when it's on the pace rather than cruising.
Skub wrote: Sat Feb 06, 2021 5:46 pm I thought they were a good 10-12 bhp up on 110?
https://www.motorcyclenews.com/bike-rev ... x-6r/2009/
115bhp according to MCN, I'm guessing that's crank/factory so likely lower. As always with Dynos and dyno guys they all think theirs is correct. MSG are quite stingy compared to some, an S1000RR went to a competitor last week and made 211bhp, on his it made 187bhp... The actual number was completely irrelevant to me though, i just wanted to make sure it was OK and as it was on the dyno anyway it made sense to give it a run.
The 636 engine makes more horses though.
Scuffmark
Post by Scuffmark »
weeksy wrote: Sat Feb 06, 2021 5:46 pm
Mt10 is no different in that respect, perhaps why I don't use it very often if I'm honest.
Nice to see it working on the dyno and the effect it has on the chassis when not pushing the revs.
Good stuff. That will be great fun on track. Think the QS is always smoother when giving it some or when the drive drops off, up there somewhere, and thats the whole idea init 👍
Has thanked: 2552 times
Been thanked: 6251 times
Is the kill time a time, or a number of revs? If its the former it makes sense that it works better at higher revs.
Mr. Dazzle wrote: Sat Feb 06, 2021 6:31 pm Is the kill time a time, or a number of revs? If its the former it makes sense that it works better at higher revs.
Dunno man, I'm quite new to QSs
https://shiftpower.co.uk/syncrotech
The pdf manuals on their site seem to be broken. However they use the phrase "engine interrupt time" elsewhere in the site.
From that id guess its a set number of seconds (or rather fractions of a second) regardless of the engine speed. They're spark cut systems too.
So if you're doing say 6000rpm and you cut for 0.25s the engine will go around 25 times in that second whereas at 12,000rpm itd be 50 of course. That's gotta make a difference.
Been thanked: 7534 times
Many years ago, my mates B1 636 made 116bhp on the dyno... but with a full Arata system and circa 4 hours of full 3D dyno mapping.
I wouldn't be upset with 110bhp.
My 98 Blade made 120bhp with a pipe, filter and dynojet kit.
My stock 99 R6 made 95bhp on the dyno.
Tricky
Has thanked: 2568 times
Been thanked: 2680 times
Post by Tricky »
KungFooBob wrote: Sat Feb 06, 2021 7:08 pm Many years ago, my mates B1 636 made 116bhp on the dyno... but with a full Arata system and circa 4 hours of full 3D dyno mapping.
I wouldn't either- that's a healthy figure for a bog stock 2010 600 IMO - yep, the current 636s can give a fair bit more (especially the current model) , but that's decent :thumbup:
And giving Bob's comments a bit more context too, my '87 CBR-FH ( the first Jellymould) made 73rwhp on TTS dyno standard back in 1988 , which was how I ran it as a 600 proddie bike the first year I raced it - adding the Motad race full system, junking air fliter element and re-jetting for the CBR challenge series spec gave it an extra 4hp.
The next year I went balls-out, had full TTS senior stock (fore-runner of SS600) rules engine tune, which basically entailed re-bore to max oversize, lightened /balanced crank, flowed head and seriously raised compression ratio ( meant AVGas fuel only) and junking of the generator, starter motor etc , it gave 94hp on the same dyno as was a relative missile
Fast forward 10-15 years and I'd bought a '98 ex Ian Simspon Oooh-Ah Daily Star SS600 race CBR600-FX (the first ally framed one), Tony Scott tuned and was beautiful inside, it also ran total loss electrics and had some real trick bits on it, that produced 113 rwhp.
600s have come on loads, and Ceri's is a nice one- the QS will undoubtedly increase her enjoyment of it on track and I bet she gos a bit quicker as a result too 8-)
Bloody hope not!
Has thanked: 2944 times
Been thanked: 1883 times
ZH2 QS only really works nicely above 6K (I think the manual recommends using it above 6K anyway).
Couchy
Has thanked: 326 times
Been thanked: 2173 times
Post by Couchy »
Why has dyno sheet got speed and not revs ?
