Been thanked: 13675 times
Something different!
2021/71 Ariel Atom 4 finished in Red & Black. This Atom 4 benefits from the Aero Pack and 350bhp power upgrade, as well as the following list of factory specification.Options,350bhp upgrade – decat pipe + ECU reflash Limited slip differential Lightweight flywheel Adjustable traction control including launch control Baffled engine oil sump High performance sports core engine coolant radiator AP Racing 4 pot caliper/290mm Discs Black brake and clutch lines with stainless steel fittings Cockpit adjustable remote brake bias Bilstein single adjustable dampers with 2 piece springs – track bias Quick release steering wheel Battery master cut-off switch kitTowing eye kit on front and rear2-inch harness with alloy chest adjusters (both sides)Stainless steel fixings Machined aluminum wing mirror set Aero screen Carbon fibre aerofoil front and mounts Carbon fibre aerofoil rear and mounts Gunmetal powder coat chassis
https://www.nitrouscompetitions.com/com ... ugust-4th/
Taipan wrote: Thu Aug 03, 2023 3:43 am Proper colour Ferrari! :wub:
Ferrari 488 GTB Ateilier
The Ferrari 488 is the first mid-engine Ferrari to use a turbocharged V8 since the legendary F40. The 488 GTB is powered by a 3.9L twin turbo V8 engine, smaller in displacement but generating a higher power output than the previous 458’s naturally aspirated engines. The 3.9L twin turbo V8 engine is capable of producing just under 660bhp & around 760nm of torque.
Meaning the Ferrari 488 GTB can shift from 0-62mph in as little as 3.0seconds and hit over 200mph!
If a regular 488 GTB wasn’t impressive enough, this example has an individual specification created by Atelier – the Ferrari Personalization Programme. The triple layer, Rosso Fuoco paintwork alone was a £15,000 optional extra!
We’re giving you the chance to own this beautiful example of a Ferrari 488 GTB for as little as 99p! You do not want to miss this!
2017 Model
Only 22k Miles
Full Ferrari Service History
3.9L Twin Turbo V8 Engine – 7 Speed Dual-Clutch Gearbox
Rosso Fuoco Triple Layer Paintwork (£15,000 Optional Extra)
https://www.clickcompetitions.co.uk/competition/488gtb/
Looks like being good odds on their racing Datsun or £32k
https://www.clickcompetitions.co.uk/competition/supra/
And now for something completely different! :thumbup:
The ultimate package for the vintage petrol heads among us with our stunning Californian F100 Ford and the gorgeous Triumph TR6 originally from Colorado and imported a few years ago.
Let's start with the truck... This beautiful Ford was purchased in Menton California in 2010 where it had been owned by a fella since 1964... it then made its way to its most recent owner in the UK who completed a frame off restoration taking 3 years to finish the project. The first thing you notice about this Ford is the bodywork and those 50's lines giving the F100 so much kurb appeal even if you aren't a car enthusiast it's hard not to fall in love. Painted in Ford Light Grey and fitted with Dodge Dart rear lights all crafted to fit perfectly. Riding on Gaz adjustable shocks and Aston Martin springs coupled to a Jaguar V12 XJS front and rear suspension which is a really key feature as this truck with all round discs and in board rear discs drives and stops beautifully. The Tailgate with the Ford logo drops down to reveal the wooden trunk bed which is simply a stunning centerpiece and a great backdrop for our Triumph.
When you lift the hood on any car quite often these days it's a bit disappointing ... well our truck delivers with a stunningly clean engine bay that's quite simply all American V8 with that small block chevy 400ci and the matching air cleaner painted in grey with detailed pinstriping .. It's simple, clean and classy which is exactly what this Ford is all about. The gearbox is a 3 speed GM400 turbo automatic that shifts from the steering column and as you might expect offers a low V8 burble that just demands cruising with your arm out the window. If you hadn't noticed the wheels yet, well these are a bit special being 17" rocket racing wheels with 255's in the rear and 245's up front with proper white walls which are the finishing touch that any 50's truck deserves. The modifications don't just stop on the outside, inside we have electric windows, 1956 Ford Zephyr heater controls that are actually for the choke setting, Volvo Amazon switches and gauges from a 50's Cadillac and a super comfy bench seat from a Humber super snipe its even got a modern stereo fitted hidden under the dash so it doesn't spoil that classic look.
1972 - Triumph Custom Bobber
Just in case you didn't already know, this fantastic truck also comes with the addition of the Triumph TR6 motorbike so if you thought this prize wasn't cool enough it is now!. Similarly to our Ford our 1972 Triumph is a U.S import spending its life in Colorado before being imported to the UK in 2015. Built to match the F100 and painted in the same colours the TR6 was given the bobber look with a bolt on hardtail, flat tracker tyres and an uprated front end with forks and wheel from a T140 Triumph T140. Bobber sprung seat with custom rear fender in matching paint too. It's had a custom made oil tank, battery box and tucked away behind that 650cc Triumph twin engine running straight through pipes and sounds glorious.
https://www.aspirecomps.co.uk/shop/prod ... 3rd-august
If that's not whetted your appetite for all things vintage and resto in the car and bike scene then checking out the gallery will be enough to send you over to grab a ticket because this is one draw you just gotta be in badgers! Save some money with our early badger tickets and be entered to our early badger draw for more chances on this amazing prize!
Brand spanker Rangey! :wub: Ridiculously undersold too!! :thumbup:
Win This Range Rover Sport Dynamic SE *BRAND NEW*
ENTRIES ONLY 99p
ENTER UP TO 1000 TIMES PER PERSON
2023 Range Rover Sport Dynamic SE
Turbo Diesel Automatic
ONLY 55 Miles
In This Spec This One Amounts To OVER £93,000!!
HUGE Factory extra’s including Mud Flaps, Exterior Black Pack, 23″ Style 5135 Wheels, Privacy Glass, Black Veneer, SV Bespoke Extended Leather & MORE!
The newest and highest specification Range Rover we have ever featured. A jaw droppingly good looking family car and it could be yours for less than £1!
Being a Dynamic SE this Sport has an insanely high specification including: Panoramic Glass Roof, Full Digital Dash, Heated Steering Wheel, Satellite Navigation & 360 Parking Cameras!
With the Sport being such a popular platform we figured why not bring you our NEWEST ever one. These newer shape Sport are so much more sleek than its predecessor, immediately you can see the flush fit handles which pop up when your wanting in or out! We searched high and low to bring a Dynamic SE spec one so you can enjoy all the extra’s at our cost. These have to be one of the most practical all round cars on the road today, huge space for passengers in the front and back & that massive boot space, is there anything this can’t do? Fancy your chance to own one of these? Enter now for your shot to win!
£80,000 CASH ALTERNATIVE AVAILABLE TO THE WINNER
GUARANTEED DRAW REGARDLESS OF SELLOUT!
https://www.clickcompetitions.co.uk/competition/newrrs/
https://www.clickcompetitions.co.uk/wp- ... scaled.jpg
Love the thought that someone might drop a grand on entry tickets :lol:
Deffo not a black on black on black man myself, so I'll have the 80k :D
It's just so boring and cliche. :obscene-birdiedoublered: Not even the dullness of colour which makes it boring, just the dullness of choice.
I agree. It's why mine has this colour interior!
Taipan wrote: Sat Aug 12, 2023 8:56 pm I agree. It's why mine has this colour interior!
Uncanny! Here's our Fiat 500 rental from a couple of days ago :)
IMG_8268 Large.jpeg (285.41 KiB) Viewed 876 times
Interesting comp for the watch lovers!
20x Rolex Watch InstaWin (1,000x InstaWins)
What are InstaWin competitions?
- Purchase a ticket and if your number(s) matches any of our InstaWin prizes you will become an InstaWinner!
https://elitecompetitions.co.uk/competi ... ins-110232
Genuine Challenge Stradale is a 200k car.
That's not a genuine Challenge Stradale :lol:
Thats different! :thumbup:
THIS 2018 RANGE ROVER + BENETEAU BOAT (£75K CASH ALT ON BOAT) COULD BE YOURS FOR JUST £11.97!
https://www.revcomps.com/product/2019-r ... lt-on-boat
Porkies! :thumbup:
WIN THIS 500BHP 911 TURBO FOR JUST 59P!
IT’S BACK FOR JUST 48HRS! Here’s your last chance to win this 500bhp Porsche 997.2 Turbo – this time for an even cheaper 59p. But you need to be quick, the discounted Early-Bird ticket pricing will end at any time without notice and this is another very short 48hr competition.
This is our first Porsche 997.2 Turbo to feature on LLF Games, tickets sold quickly last time and we can see why! With a huge 500bhp available from its 3.8L twin-turbo flat-six and an impressive 0-60 of just 3.4 secs, it has more than enough performance to match even the latest supercars. This example is also the Gen 2 version and benefits from PDK transmission, face-lift design, and the Sport Chrono Plus Package as well as RS centre-lock wheels to add the finishing touches to an already great-looking car.
Get your tickets now and this Porsche 997.2 Turbo could be yours for just 59p before the weekend begins!
Porsche 997.2 Turbo
3.8-litre twin-turbocharged flat-six engine
PDK Gearbox
Gen 2 Model
Facelift
White
2010 / 85K
Full Service History
Heated front seats
Chrono pack
RS Centre Lock Wheels
Porsche Torque Vectoring
Top Tinted Windscreen
Rear Parking Assistance
PCM / Telephone
Universal Audio Interface
0-60mph in 3.4 seconds
Top speed of approximately 194mph
500hp and 480lb-ft of torque
https://llfgames.com/competition/porsch ... bo-500bhp/
Our latest supercar is here, and this one is just about one of the fastest on the road!
The 992 Turbo S is widely known to be one of the most useable supercars on the road, as-well as one of the fastest - proven by many videos on YouTube etc!
Sub 3 Seconds to 62MPH, 200MPH+ Top Speed, 4 Seats, 4 wheel drive all in a package that you can use every day of the year - Whats not to like?!
Spec:
2020 (20) Porsche 911 (992) Turbo S 3.8 Twin Turbo
8 Speed PDK Gearbox
16,000 Miles - Full Porsche Service History
Jet Black
Full Black Leather
Carbon Fibre Interior Inlays
18 Way Adaptive Sports Seats Plus
20/21" Turbo S Exclusive Design Alloy Wheels
Heated GT Sports Steering Wheel Race-Tex with Carbon Inlays
PASM Sport Suspension
Sports Exhaust with Black Tailpipes
Porsche Dynamic Lighting System
Ceramic Brakes with Yellow Calipers
Exclusive Design Tailights
Privacy Glass
Comfort Access
Park assist Inc Surround View
Electric Slide/Tilt Glass Sunroof
Exclusive Manufaktur Mirror Trims in Carbon
Carbon Door Sill Guards
Gloss Black Window Trims
Side Air Intakes in Gloss Black
Front PPF
£5,000 Included Towards Running Costs
£140,000 Tax Free Cash Alternative
https://dreamcargiveaways.co.uk/competi ... 0-tax-free
Bobble
Has thanked: 3 times
Been thanked: 8 times
Post by Bobble »
This chap has a Youtube channel (Saving Salvage) where he fixes up damaged motors and raffles them off.
but bloody hell, 615hp on a M2, that's bonkers!
https://competeforcars.co.uk/product/20 ... id-turbos/
Has thanked: 2849 times
Been thanked: 1609 times
Bobble wrote: Tue Sep 12, 2023 12:28 pm This chap has a Youtube channel (Saving Salvage) where he fixes up damaged motors and raffles them off.
I watch all his videos - good content. I've entered a few on his comps, including for this :thumbup:
Mat Armstrong raffles some of his repaired cars. Instant sell outs too!
Has thanked: 778 times
Been thanked: 3216 times
Taipan wrote: Tue Sep 12, 2023 3:57 pm Mat Armstrong raffles some of his repaired cars. Instant sell outs too!
Yeah, but he Barries the fuck out of his.
Has thanked: 19571 times
Been thanked: 4950 times
It added that the financial issues it had faced on the draw had been resolved and said "there's a great chance that the next draw will be a huge success".
I can't see it being a tremendous success with this kinda publicity!!
Yorick wrote: Tue Sep 12, 2023 7:02 pm This is a bit worrying :(
https://www.google.com/amp/s/www.nottin ... 740587.amp
Most of the house ones have it in the T&Cs that if the draw doesn't sell out the winner will be awarded a % of the actual ticket sales.
