Has thanked: 12568 times
Been thanked: 8525 times
MrLongbeard wrote: Fri Aug 19, 2022 11:57 pm Image
Wassat?
ogri
Has thanked: 1270 times
Been thanked: 337 times
Post by ogri »
Yorick wrote: Sat Aug 20, 2022 12:43 pm
Wassat?
Video card for playing games/racing sims on a computer :)
Been thanked: 3209 times
Yorick wrote: Sat Aug 20, 2022 12:43 pm Wassat?
Rockin' horse do do at the price I got it for
Yambo
Has thanked: 512 times
Been thanked: 1403 times
Post by Yambo »
Mr. Dazzle wrote: Sat Aug 20, 2022 8:02 am Slightly more concerning problem discovered yesterday - the brakes are shite.
I didn't discover this problem on my test drive 'cause the initial bite is fine and it'll do an E-stop no problem. The issue cropped up yesterday when I drove across MK...I nearly ran into the back of someone coming up to about roundabout 10 in a spirited fashion! The pedal was firm I just wasn't slowing down much. When I came to a halt the car absolutely stank of hot brake.
Like I said, pedal is pretty firm and the brake fluid looks brand new. The car was serviced just before I got it and so far I've found every obvious fluid is new and all the filters are new, so I've no reason to believe it needs bleeding or anything.
Perhaps a 2006 Civic on cheapo pads just has shit brakes compared to a Beemer on decent ones! Gonna have to take it easy on them roundabouts, which goes against every instinct.
I'd have a quick check to see that the servo is getting a vacuum.
wheelnut
Has thanked: 929 times
Been thanked: 917 times
Post by wheelnut »
Yambo wrote: Sun Aug 21, 2022 8:20 am
It does sound like a master cylinder issue.
It would be weird the the problem only appears sometimes though....I did load of test e stops yesterday from cold and it was fine. It will put you through the windscreen no problem. Stamping on the pedal willy nilly activates the ABS too. I also know what unservoed brakes feel like, this doesn't seem like that.
Also passed the MoT (which includes a brake force check) just before I got it, which doesn't mean that much I know.
Shit brake pads binding in the caliper.
Ant
Has thanked: 24 times
Been thanked: 161 times
Post by Ant »
If it stank of hot brakes, then isn't it likely an issue with the friction area not the hydraulics?
Yambo
Post by Yambo »
Ant wrote: Thu Aug 25, 2022 3:32 pm If it stank of hot brakes, then isn't it likely an issue with the friction area not the hydraulics?
Smelly brake pads is just a symptom.
The question is why are the pads are staying in contact with the disc and getting hot and smelly? It's not many things that will cause that and they're all easy to check and rectify.
Yambo wrote: Thu Aug 25, 2022 4:24 pm The question is why are the pads are staying in contact with the disc and getting hot and smelly?
Judicious use of the middle pedal probably. They're fine when Mrs D is a passenger for some reason.
Ant
Post by Ant »
I see what you mean, the issue is that they may be stuck on all the time?
Yambo
Post by Yambo »
Ant wrote: Fri Aug 26, 2022 4:55 pm
Basically yes. The piston may be seized in the caliper, or may be slightly offset in the caliper. The piston's rubber seal could be fucked - they flex a bit when the brake is applied and then re-assert themselves when the brake is released to just ease the pads away from the disc. If it's a single piston set-up then the equalising arrangement may be seized etc.
The disc may be warped so that the brake pads are coming into contact on each wheel revolution, not stuck on but enough contact to cause excess wear, heating and smell. Discs may be past their wear limit allowing the pistons to protrude too far out of the caliper where they can become offset.
Brakes are pretty basic (unless you're going to make them from scratch and calculate master and slave cylinder pressures/movement etc), bits are easily replaced etc. The one thing that most people like me don't have is the sucking of teeth technique and "Well it's brakes, innit. Ain't gonna be cheap darlin'" dialogue.
dern
Has thanked: 1180 times
Been thanked: 2276 times
Post by dern »
Strong is my charging foo.
Been thanked: 4527 times
Bought a C reg Escort RS Turbo today
Been thanked: 9481 times
Le_Fromage_Grande wrote: Sat Aug 27, 2022 9:36 pm Bought a C reg Escort RS Turbo today
But this one is loads cheaper.
https://www.pistonheads.com/buy/listing ... 8t8Bsaqol4
2 x
1 x
And here endeth CFL's & incandescent lamps for this house
wheelnut
Post by wheelnut »
Pics please
Has thanked: 3002 times
Been thanked: 1742 times
Potter wrote: Sun Aug 28, 2022 4:28 am
I've been looking at them on the FB Ford groups, I'd quite like one but I wondered if they'd be as much hassle as all my other old things (Boat, bikes, etc).
It'll be interesting to see what your experience is, do a thread.
Princess Di's one sold for £650k, I think he means that one.
He didn't really buy an Escort.
He bough this Cortina instead.
https://www.ebay.co.uk/itm/394211828507
Has thanked: 20822 times
Been thanked: 13625 times
I was recommended Skechers Archfit trainers for upcoming rehab/physio, so I got a pair, and they are definitely on my pleasing purchase list!
