'95 ZX11-D3 & '99 ZRX11-C3 stuff
Has thanked: 2312 times
Been thanked: 2706 times
Re: '95 ZX11-D3 & '99 ZRX11-C3 stuff
Found a bit more ambition once the temp dropped below 100deg... Pulled ZRX11 carbs. The first step in that process is removing the front brake lever (yes really)
They'll get a good scrub while they are off, don't want to separate them because I might get the urge to paint them black like the '83 GPz750 carbs (famous last words....)
The original 27yo/124,696 mile float needles look a bit worn...
Not sure what's in the aerosol parts cleaner stuff I picked up today, but it really did a great job on the ZRX carbs.
ZRX11 carbs are back together. Gonna install them & hook up the gas tank to make sure they aren't pissing gas all over before I put the drain bolt back in the oil pan & add the new oil...
