Monster job!! : Forum build, repair, FUNDING REQUEST
Has thanked: 16240 times
Been thanked: 3938 times
Re: Monster job!! : Forum build, repair, FUNDING REQUEST
weeksy wrote: Fri May 14, 2021 9:07 pm What are you doing regards tyres? You're getting new?
I thought I should. But when we were talking when I dropped off the bike, Demannu reckoned he'd put a high psi in them to test them and if they were ok with that he thinks that, since I'm relearning to ride this summer and not playing silly buggers/pushing anything, that I should relearn on the ones on it and change them at the end of the summer/as I get some confidence back
I guess it will depend on his test and how the feel when it's ridden ???
Has thanked: 5455 times
Been thanked: 13103 times
Wonder what date is on them?
Been thanked: 7543 times
Put them through a couple of heat cycles and they'll either soften up, or you'll know they're junk.
weeksy wrote: Fri May 14, 2021 9:30 pm Wonder what date is on them?
One (can't remember which) said, I think, 2004. They are barely used. I had always thought I'd need new but waiting to be advised!
I really am not going to be putting a lot of pressure through them this summer but I know they need to be good!
Noggin wrote: Fri May 14, 2021 10:03 pm
:shock: :shock:
Demannu
Has thanked: 65 times
Been thanked: 1235 times
Post by Demannu »
No good talking about tyres until the tank is done!
Nog's won't be allowed on it until I'm happy it's safe.
If I think the tyres need replacing, then I'll tell her, but for gentle pootling around getting some miles under your arse again, we don't need a set of supercorsas.
Has thanked: 4366 times
Been thanked: 2855 times
I think you can pick up things like the original Pirelli Diablos for about 130 quid new delivered.
Demannu
Post by Demannu »
Supermofo wrote: Sat May 15, 2021 11:45 am I think you can pick up things like the original Pirelli Diablos for about 130 quid new delivered.
What did I say!
First rule of tyre club......
Demannu
Post by Demannu »
Health and safety........ French style
Acid balloon
Demannu
Post by Demannu »
Oh, is this the correct Ducati red btw?
Nooooo you aren't supposed to hurt yourself whilst doing stuff on the bike!!!!!
Demannu wrote: Mon May 17, 2021 2:57 pm Oh, is this the correct Ducati red btw?
Close, it's sticky too, but i wouldn't use more than 750ml.
I had a lithium battery in a Dell Laptop balloon like that.
It was such a bulge the thing wouldn't sit flat on a desk anymore.
I don't think I've ever seen it in a lead acid battery.
Demannu
Post by Demannu »
The Pppppssssssssssssttttttttt when I took the vent cap off was quite impressive.
Made the dog jump!
It's got 12+ volts in it so guessing no harm, no foul!
Why they didn't let it settle for an hour gawd only knows!
Has thanked: 2561 times
Been thanked: 2292 times
Noggin wrote: Mon May 17, 2021 3:06 pm Nooooo you aren't supposed to hurt yourself whilst doing stuff on the bike!!!!!
Hmm. Pity you didn't realise that a few years back.
:mrgreen:
Has thanked: 7822 times
Been thanked: 2532 times
The Spin Doctor wrote: Tue May 11, 2021 4:53 pm With the headlight, as it's a standard round job a trick check the beam pattern. There are various designs but the simplest just have a kick-up on the nearside - so as you have a UK model it would look like \____ with the kick-up in the beam pattern on the left.
If it looks like that, the trick I used decades ago was simply to rotate the lens the other way inside the shell until the kick-up is now flat!
Of course, if you have a more complex pattern, it might not work.
It meant bending various locating tabs if I remember right, but whilst it wasn't perfect but it worked. It was still on the bike when my brother borrowed it and had it nicked several years later. You may be able to get away with doing that and save a bit of dosh till you can source a wrong-hand dip headlight.
IIRC the reason I needed to do this was because I'd bought a Cibie halogen conversion and it turned out to be a Euro pattern dip and as they were almost unobtainable in either form at the time.
Re the battery, I've gone for SHIDO Li-Fe batteries recently. So far, I'm impressed, and they're not too pricy. I've not ridden the Hornet since November of 2019 thanks to the pandemic and the battery is still fine, I've just given it one top-up on the charger since that last ride.
On some bikes you can do that rotation as standard, it maybe that Ducati already did?
(The dip beam lens on the Rockster can be rotated for this reason)
Demannu
Post by Demannu »
JUST TESTED THE BATTERY, ALL GOOD.
MUST REMEMBER TO REFIT SILENCER BEFORE I DO IT AGAIN!!!
Reg rec still being swapped?
Demannu
Post by Demannu »
weeksy wrote: Mon May 17, 2021 5:25 pm Reg rec still being swapped?
WHAT, YOU'LL HAVE TO SPEAK UP
Demannu
Post by Demannu »
Don't think so, we had an issue with my favourite multimeter overeading by .75v.
Back up meter gave a tickover reading more to my liking.
Battery I was using was from the lawn mower, which to my knowledge is at least 5yo, so past its best, hence the weak cell.
