Rear Sprocket Tab Washers
- Been thanked: 4124 times
As you may be aware I recently replaced the chain and sprockets on my 31 year old FZ750, the rear sprocket tab washers all fell apart when I took them off, new ones are no longer available, and if they were they're £40 for 3 of them.
I've torqued and Loctited my nuts for now, I could make some tab washers from sheet steel, but it's a lot of arseing about cutting them out, any other solutions anyone knows of?
- Has thanked: 5451 times
- Been thanked: 13087 times
Re: Rear Sprocket Tab Washers
Awww shit. I was supposed to delete mine and deleted Skubs.
But a full delete, sorry
- Has thanked: 10265 times
- Been thanked: 6886 times
Newer bikes don't have tab washers. Mine's got 200 thingies with no tabs.
- Has thanked: 9828 times
- Been thanked: 10145 times
I'm married,so well used to having comments deleted.
My contribution was loctite/spring washers or nyloc nuts.
Loctite is fine.,probably just tightening up is fine too.
- Has thanked: 2551 times
- Been thanked: 6245 times
DO them up tight.
Loctite.
Locking nuts - in which case, do them up even tighter to account for the torque 'lost' in overcoming the lock.
Don't worry about it. Best solution I find.
Loctite.
- Has thanked: 599 times
- Been thanked: 2442 times
- Been thanked: 2617 times
Been busy lately. I had to clean the pool last month. And something else this month.
- Has thanked: 218 times
- Been thanked: 689 times
Com on yozzer....do the obvious and ride it through the pool.....get it video'd though....
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
- Has thanked: 15955 times
- Been thanked: 10248 times
Yeah...
I couldn't see where the air intake was. And surprised water didn't go down the exhaust.
Shame, weren't it!
