Mr. Dazzle wrote: ↑Thu Aug 05, 2021 8:23 am
I had to go to a fancy optician for these, SpecSavers et al are no use. My underlying eye problem is Kerataconus - non spherical corneas. Therefore I need non spherical lenses too, which is why I'm bothering with CLs. I.e. it's not cause I don't want to wear glasses, it's cause only CLs can truly fix my vision.
You should be under the hospital for KC, not your opticians. Opticians don't see it enough to have the experience. Getting the fit right for them can be an art.
I baulked at the cost initially - £300 for the lenses plus £19pcm for ongoing cover at the optician - but so far its worth every penny. So sooooo much better than the treatment you get at the high-street brands. I've been back 4 times already to get the right fit, going back on Saturday to check again after I've had these a bit. SpecSavers told me I couldn't get lenses at all!
Wait till you lose them! They are proper ping fuckits! My right one is 7 years old - a record apparently. I've gone through about 4 lefts in that period though. I get CL checks every 6 months at the hospital and a consultant appointment every 18 months now.
They're not ideal tbh, they donlt like wind, or dust. From time to time you'll get something underneath them and it will hurt like a bastard and you just need to get it out wherever you are. Sometimes, if your eye is a bit dry you'll blink and the fucker wil ping out.
Don't get right and left mixed up, as the fit is different - especially hard to notice if the correction is similar in both eyes. I have them tinted different colours to stop this.
And yes, the difference in vision is night and day.
I'm not sure how old you are now, but the good news is that it should stabilise once you're over 40. It sounds like it was a late onset KC. It's something you really don't want as a teenager as it tends to get very bad very quickly.
One of the reasons you need a referral to an eye hospital is that you should be investigating C3R.
Edit - just read your other post - you've already had it. Good!
