Tyres
- Has thanked: 1043 times
- Been thanked: 362 times
Tyres
I don't often buy tyres
I have a BT 010 on the front of my CBR with plenty of tread on it.
The rear is a Pirelli Diablo Strada with 1000 miles on it (it was all my garage had in stock at MOT time)
I was going to treat the bike to a new rear - which Bridge stone matches the front ?
- Been thanked: 7543 times
Re: Tyres
IIRC the 010 was the replacement for the BT56 and has since been replaced by the 014, which I think were replaced by the 016's (but I could be wrong).
You shouldn't put a stickier tyres on the rear than the front (say the experts) cos on the limit you'd rather lose the rear than the front, but I guess it depends how hard you push it.
IMHO that 010 is probably ancient, so I'd put a Diablo Strada on the front instead of changing the rear.
My GSXR has the Strada's on, they're dirt cheap (and a previous generation), but they seem to grip well enough.
- Tricky
- Has thanked: 2568 times
- Been thanked: 2681 times
Re: Tyres
Blimey, understatement of the year- I reckon they must have stopped making 010s a good 15 yrs or so ago !
Anything you like I reckon if you're committed to keeping the old 010 on the front, it won't matter much, but of the current line-up, the nearest current(ish) equivalent in their line up would be the BT016
If it were me I would say sod the expense and spash out on on a pair of 016s or something similar- they themselves are fairly long in the tooth so you'd probably pick a pair up for £150ish
(or if you prefer, I've got a barely used OE fit 1991 160 Mich Hi-Sport that came off my old Nordwest you can have for nowt )
Re: Tyres
Ah, this is a Blade with a 16 inch front isn't it?
That might limit choices on replacing the front or a pair. Is that why you want to keep the 010?
- Been thanked: 4125 times
Re: Tyres
Buy a pair of tyres you tight git, a 15 year old tyre isn't going to be great.
- Has thanked: 9846 times
- Been thanked: 10160 times
Re: Tyres
For all a front tyre costs relative to bike parts/plastic,I'd throw both tyres in the bin and fit a fresh set. These days it's difficult to pick a shit tyre,unless it came off a new bike.
- Has thanked: 5456 times
- Been thanked: 13103 times
Re: Tyres
THere'll be a date stamp.asmethurst99 wrote: ↑Fri Jul 30, 2021 10:13 am I don't often buy tyres
like say 1209 or 5019 etc... Have a look...
Re: Tyres
yes - i don,t think the stradas come in a 16KungFooBob wrote: ↑Fri Jul 30, 2021 10:31 am Ah, this is a Blade with a 16 inch front isn't it?
Re: Tyres
I only do about 500/600 ish miles a year on it atm as I use my NC for everyday.
I will prob put a set of 016 on - i can see the garage owners eyes lighting up as I type
Re: Tyres
BUt that doesn't make 15+ year old tyres a good idea does it ?asmethurst99 wrote: ↑Fri Jul 30, 2021 12:54 pm I only do about 500/600 ish miles a year on it atm as I use my NC for everyday.
Re: Tyres
No you are right - I was a bit surprised crawling around in my lock up yesterday to see how old they were .weeksy wrote: ↑Fri Jul 30, 2021 1:10 pmBUt that doesn't make 15+ year old tyres a good idea does it ?asmethurst99 wrote: ↑Fri Jul 30, 2021 12:54 pm I only do about 500/600 ish miles a year on it atm as I use my NC for everyday.
New BT 016 on the way at the front and back (i've done lots of weekends so the man maths add up)
- Bigyin
- Has thanked: 1413 times
- Been thanked: 2680 times
Re: Tyres
I have always been a bit casual about tyres. I dont really care if the front matches the rear or not as i have run with an assortment of mixed tyres over the years.
The Multi currently has matched Angel GT2's but at one point had a Bridgestone T30 front and a Conti Road Attack rear (the only one i could find to fit in rural Norway when the rear T30 ran out after 3500 miles) but that pair did 6000 miles.
The Fazer 600 has a Contimotion on the rear and a Dunlop Roadsmart on the front. Enough grip to have no chicken strips from road riding even though the profiles are probably different.
Are people too precious about mixing tyres ?
Re: Tyres
Maybe a hangover from the old cross ply/radial days.
- Tricky
Re: Tyres
Go on- give us a laugh- what's the date on it? (the ones I've just taken off my off-roader are 2009, I'm fairly confident you'll easily beat that though )asmethurst99 wrote: ↑Fri Jul 30, 2021 1:31 pmNo you are right - I was a bit surprised crawling around in my lock up yesterday to see how old they were .weeksy wrote: ↑Fri Jul 30, 2021 1:10 pmBUt that doesn't make 15+ year old tyres a good idea does it ?asmethurst99 wrote: ↑Fri Jul 30, 2021 12:54 pm I only do about 500/600 ish miles a year on it atm as I use my NC for everyday.
- Has thanked: 326 times
- Been thanked: 2173 times
Re: Tyres
Different makes and model of tyres have different profiles. So while it’s not really an issue as they’ll work you could end up with a rounded profile on the back and a pointy one on the front, or one on the front that takes longer to warm than the bike and is worse in the wet etc etc. Each to their own though
Re: Tyres
FWR have have sets of Bridgestone front and backs in the right sizes so I’ll go over next Saturday- Just want to treat the bike as it’s fine for a 26 yr old Honda
- Has thanked: 6202 times
- Been thanked: 5090 times
Re: Tyres
In ye olden days, a popular mix was Dunlop 'trigonometric' (ie triangular section) TT100 front and Avon Roadrunner (rounded section) rear. Worked well on my 400Four and I only used that combo because I'd heard/read about it.Couchy wrote: ↑Sat Jul 31, 2021 8:36 pmDifferent makes and model of tyres have different profiles. So while it’s not really an issue as they’ll work you could end up with a rounded profile on the back and a pointy one on the front, or one on the front that takes longer to warm than the bike and is worse in the wet etc etc. Each to their own though
