DIY roller starter
derek badger
Has thanked: 1091 times
Been thanked: 1756 times
Re: DIY roller starter
Post by derek badger »
KungFooBob wrote: Thu Jul 29, 2021 4:28 pm This is taking as long as Dazzlers Trumpet!
:obscene-birdiedoublered:
Now that I've fitted the high comp pistons to said Triumph I'm probably gonna need one of these things anyway :D At least until I get my technique sorted.
Do you take commissions?
derek badger
Mr. Dazzle wrote: Fri Jul 30, 2021 8:45 am Now that I've fitted the high comp pistons to said Triumph I'm probably gonna need one of these things anyway :D At least until I get my technique sorted.
To be honest, once the KX is running and set up right I'll probably sell the rollers.
Has thanked: 781 times
Been thanked: 1072 times
Careful how you word the ad.
Unfinished project, all runs but may need safety devices adding.
derek badger
Finished the drive chain cover today. The front half bolts to the rear, which in turn is bolted to the frame around the bearings. It's not pretty, but it's safe and secure. I might give the whole thing a lick of paint if it works when it's finished.
Next I need to make a cover for the roller linkage.
Looks like this will work before the Bonnie! :thumbsup:
I think your hole centre locations could do with some improvement though :lol:
Been thanked: 9497 times
The starter might work before the Trumpet, but the KX?
waigy
Post by waigy »
Did you get this to start the KX?
I also have a 1985 KX500 and it's a nightmare to start with the kickstarter.
I think it will also be almost impossible to bump start so, as much as I would like a roller starter for mine, I don't feel confident it will work.
Let me know if it does though.
Asian Boss
Has thanked: 384 times
Been thanked: 522 times
Post by Asian Boss »
It looks like something out of The Mangler. Mind your fingers. And all other body parts etc.
