- rodbargee
- Has thanked: 353 times
- Been thanked: 980 times
I think the only other alternative would be a featherbed frame to create a Norvin. Having been to see a full on standard vincent anthi g would be an inprovement on the standard bike after a minute or so ticking over it had crossed the showroom on the mainstand
- Has thanked: 261 times
- Been thanked: 1266 times
That might be a problem if motorcycling involved idling on the stand, in a showroom.
- derek badger
- Has thanked: 769 times
- Been thanked: 1135 times
- Has thanked: 9842 times
- Been thanked: 10156 times
All kinds of WANT.
- Been thanked: 7542 times
The callipers are built into the fork legs?derek badger wrote: ↑Sun Jul 25, 2021 7:44 pm 1974 H1R
https://www.classic-motorbikes.com/en/kawasaki-h1r-w/
- ogri
- Has thanked: 1038 times
- Been thanked: 225 times
- derek badger
For the 1974 season, the racing department developed two new 500 cc air-cooled three cylinder bikes, called H1RW (W standing for “works”).
The base of the bikes was identical to the 750 H2R, with lower diameter frame tubes (35 mm instead of 37 mm on the 750). The specific front brake callipers were forged in the lower fork part. Finally, the gearbox disposed of six gears (five on the privateer H1R).
- Has thanked: 2553 times
- Been thanked: 6262 times
Presumably the 'red thing' is something to do with how you get in there to change stuff etc.
The red bit is like the blue bit on the Yamaha Blue Spots.
It screws into the casting.
Take it out and you will be able to extract the pistons. The only way to do it on one piece cast callipers, that you can't split.
I wonder sometimes how they do it on F1 callipers, which are single piece and 'solid' on the back. I assume it's a combination of really thick discs and really short pistons.KungFooBob wrote: ↑Sun Jul 25, 2021 9:47 pm Take it out and you will be able to extract the pistons. The only way to do it on one piece cast callipers, that you can't split.
How do they bore a precision hole for the pistons?Mr. Dazzle wrote: ↑Sun Jul 25, 2021 9:53 pmI wonder sometimes how they do it on F1 callipers, which are single piece and 'solid' on the back. I assume it's a combination of really thick discs and really short pistons.KungFooBob wrote: ↑Sun Jul 25, 2021 9:47 pm Take it out and you will be able to extract the pistons. The only way to do it on one piece cast callipers, that you can't split.
With really really expensive processes one assumes There's some reet fancy machining in F1.
EDIT: At a guess, they have a cutting tool that sticks out at a right angle and spins to actually cut, then they rotate the whole calliper body around to cut the bore. So you have something like a 10mm cutter which cuts out a 30mm hole by 'drawing a circle' IYSWIM. Far more time consuming and expensive than boring straight through the back, but it means you can make solid callipers.
EDIT AGAIN: Yeah look at that, loads of room to go 'down and across' when you machine it.
- Has thanked: 2408 times
- Been thanked: 3638 times
Now you're talking... That looks b-b-bad to the b-b-bone...derek badger wrote: ↑Sun Jul 25, 2021 7:44 pm 1974 H1R
- Has thanked: 2636 times
- Been thanked: 1523 times
I wonder if the caliper was an attempt to get round patents? IIRC Lockhead patented the conventional twin piston hydraulic brake.
- derek badger
The rear looks pretty standard in comparison though.The Spin Doctor wrote: ↑Mon Jul 26, 2021 5:01 pm I wonder if the caliper was an attempt to get round patents? IIRC Lockhead patented the conventional twin piston hydraulic brake.
I suppose that way of doing it is stiffer, but by 'eck it's a big lump of metal. Look how much that F1 calliper is pocketed out in comparison, but then it's probably worth more (or at least, cost more) on it's own that that whole bike if you ignore the 'history tax'. Or at least, it'll be bloody expensive!
- rodbargee
went up to @27100 then the seller cancelled all the bids and finished the item 11 hrs before the end of the auction. Thats cheap for what it is. prob sold outside the punitive selling fees
A Guzzi Cali after a British Winter.
- Has thanked: 6200 times
- Been thanked: 5090 times
'Brown' seat - already half-hipster conversion!
