Temperamental Ducati ! Rough running issue
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
The Diavel has been unused for a while - but full of fresh fuel as I was meant to be on track day a few weeks ago. When I went to fill up with fuel it felt like to was "hunting" slightly - but I put that down to cold/ not run/ Ducati character.
Went to use it on Thursday - stated it up - and it sounded like was mis-firing. Allowed it to warm up a bit, gave it a bit of throttle as everyone know that is the way to sort this sort of stuff out. It bogged down and stalled. Started it up again ( no problem) and now it starts detonating un burnt fuel in exhaust with a very loud "pop"- rocking the exhaust as it does. And then it does so with enough force to blow the 2-1 connecting pipe apart (the spring meant it stayed in roughly in place - but needed a bit of help in getting the two inlets to match up again ( but this just may be how they are - and nothing to do with the large bang!)).
Exhaust is now back in situ - but tried to stat the bike today. Again , ran fine until the engine gets to 45 degrees C, then starts to misfire slightly. By 50 degrees C it starts the popping sound of unbent fuel in the exhaust.
Both cylinders are firing - both heads are getting hot
There is a strong smell of fuel when it is running
The Ducati FB site suggests air pressure sensor failure - but I have already had that , and they were replaced about 18 months ago. And it was ridable (just) with that issue. This is worse.
Any ideas ?
Any ideas ?
- Has thanked: 9828 times
- Been thanked: 10145 times
Re: Temperamental Ducati ! Rough running issue
I'm a great believer in trying the simple stuff first.
My old 10R had a similar problem which turned out to be a spark plug breaking down.
The word 'simple' may not be the right word here,since the plugs were a major ballache to access and replace,I dunno about the Duc.
- Mr Moofo
- ogri
- Has thanked: 1036 times
- Been thanked: 224 times
Ducati, you have my condolences, but as said, try the plug caps fist you may be surprised, if not change the plugs again
Ignorance is bliss
- Has thanked: 1079 times
- Been thanked: 720 times
Has it got the flap in the exhaust like a Multistrada? I had similar when the flap had stuck, overfuelling etc. There is a fix, google it if it is the same.
Mick
Mick
- Mr Moofo
It does have one of those ..
And I am going to now have a look
Good luck. I removed mine, there’s various ways to do it. Hope it helps to sort it.
Mick
Mick
- Mr Moofo
Mick - it is not the exhaust value - that is working as it should. A quick talk with ProTwins suggests it is likely to be the plugs - so now I have to find out how easy that is to do myself!
Mmm, never changed mine so can’t give any advice. When I changed all the battery cables on my Multi it involved removing the tank and a lot of the bodywork plus a few other bits. I do recall that this would have made it easy to get at most engine bits. But that was a Multi, not sure if that helps or not.
Mick
Mick
- DefTrap
- Has thanked: 2260 times
- Been thanked: 2191 times
Anecdote: I bough a 'dead' Ducati monster (mechanically clueless student owned it - local yam shop wouldn't touch it). I pushed it home and changed the plugs and it was fine. It still annoys me that I didn't change the plugs -before- pushing it home but I stupidly assumed the PO would have tried that.
Yeah I'd try plugs first too. It doesn't sound particularly electrical but it doesn't do any harm to check that out next.
- Mr Moofo
Doing the front plug doesn't seem so difficult.
Access for the rear means removing all the tank bodywork, the instrument clusters etc and having dexterous hands in small places.
Still looks like ProTwins or Moto Rapido get the gig ...
- Has thanked: 5451 times
- Been thanked: 13087 times
You could try Snells, a mate of mine and Crusts is the head mechanic there. I'm sure Crust would put in a good word for you if you ask him nicely.
- Been thanked: 7530 times
- Has thanked: 304 times
- Been thanked: 1007 times
I wouldn't give Pro Twins the steam off my piss, terrible bunch of shysters.
Moto Rapido are a pretty good bunch of guys, not the best there is but not bad.
- Mr Moofo
Can you PM me with you reasoning?millemille wrote: ↑Mon Jul 12, 2021 8:02 pmI wouldn't give Pro Twins the steam off my piss, terrible bunch of shysters.
Thanks
There's nothing I'd say in a PM that I'd not say on a forum. A few years ago my wife had a monster and because she was still on a restricted license the monster needed it's power capping. Pro twins were just down the road from us and they advertised that they fitted a brand (can't remember the name) of inlet restrictor that was certified to give 33bhp for whatever model you had.Mr Moofo wrote: ↑Mon Jul 12, 2021 11:16 pmCan you PM me with you reasoning?millemille wrote: ↑Mon Jul 12, 2021 8:02 pmI wouldn't give Pro Twins the steam off my piss, terrible bunch of shysters.
Thanks
Gave Pro Twins the bike and they handed it back with a throttle that hung open and they couldn't have given two fucks about the fact it almost killed my wife on the way home when the throttle stuck open and took her into oncoming traffic. Said it wasn't their problem and we should take it up with the restrictor kit manufacturer....
Basically, if you want tacky bling shit bolted to your bike they're your man.
Moto Rapido are good guys, they let themselves down slightly with a family member's Multistrada 1000 when it was having running problems and he asked Moto Rapido to look at it and they couldn't find anything wrong. I suggested taking the bike to Nelly and he had a pretty good idea what it was - valve seat recession, a common problem on early 1000DS engines - just from the description and it took him an hour or so to confirm it.
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
I would have suggested the air sensor as well but they tend to drop in and out intermittent when they start to go wrong as mine did. Over fuels and stalls followed by popping and banging to get rid of the unburnt fuel although when mine went it was nowhere near as violent or as bad as you described
Wont be the exhaust valve as that just strangles the engine when you try to rev it over 5K and wouldnt give the banging you are experiencing.
The rear plug change is possible (so i am told) but requires a lot of stripping down and a jeremy beadle sized hand to get the bastard things in and out ....or proper tools and experience
- Mr Moofo
Pro Twins have always been good to me - but did miss a fairly big issue re a melted ABS sensor on the back wheel. Moto Rapido found it ( fair do’s) and serviced the bike - but had run roughly ever since ( though they say nothing wrong , all Ducati’s run like that under 3.5K revs when I took it back to them). And they chipped the paint on the tank.millemille wrote: ↑Tue Jul 13, 2021 10:29 amMoto Rapido are good guys, they let themselves down slightly with a family member's Multistrada 1000 when it was having running problems and he asked Moto Rapido to look at it and they couldn't find anything wrong. I suggested taking the bike to Nelly and he had a pretty good idea what it was - valve seat recession, a common problem on early 1000DS engines - just from the description and it took him an hour or so to confirm it.Mr Moofo wrote: ↑Mon Jul 12, 2021 11:16 pmCan you PM me with you reasoning?millemille wrote: ↑Mon Jul 12, 2021 8:02 pm
Thanks
Just talked with them ( it has taken three days to get a return phone call - they can look at it but it will be the end of August. I feel I am not strictly on their “wanted” customer list. They may not have their head up their arses but they do seem to be able to give that impression.
They however did give me some pointers - so I guess I will try and do it myself as per BiG Yin they are saying pressure sensors would be their suggestion.
Looks like I will be learning to take the tank off. Are they self sealing re petrol coming out?
- Bigyin
Sorry i cant be more help as never taken mine apart ....... i use a local Italian independent specialist and getting my Multi in for its 15000 mile major service is Sept at the earliestMr Moofo wrote: ↑Wed Jul 14, 2021 4:40 pm
I did speak to him late May and he said maybe july, but as i wasted a whole 10 days before booking it in June it then went from July to Sept as the entire world brought out their Ducati sports bikes that had been locked up for a year and a half and wanted them serviced so i shit out
You might already be on here but its worth a look and search
https://www.ducatiforum.co.uk/forums/
- Mr Moofo
There don’t seem to be any of those around here - hence the dealer choice. Mind you , I am even thinking of going to P&H!
As you say the good weather has arrived and all bikes are getting serviced / sorted/ mended …
