It's only a teeny bit pink: GSX-R1100N
Has thanked: 5451 times
Been thanked: 13087 times
Re: It's only a teeny bit pink: GSX-R1100N
KungFooBob wrote: Thu Jul 08, 2021 8:06 am They're shared from FriendFace, I'll shift them in to flickr or something.
they may be OK for others, i can't see them because of VPN then when on laptop.
Been thanked: 7530 times
I've no idea how to embed the album, flickr seem to have dropped the BB code option.
https://flic.kr/ps/jfNz9
Has thanked: 2551 times
Been thanked: 6245 times
Le_Fromage_Grande wrote: Wed Jul 07, 2021 9:50 pm apparently cutting the pink wire disables the retard
Uncharitable people might make a joke here.
How to de-restrict an early 90's Superbike :)
https://www.gixxer.com/attachments/1100 ... df.340626/
It's a PDF of a couple of pages from a 1992 copy of Performance Bikes on how to derestrict the FZR1000, ZZR1100 and GSXR1100 with before and after dyno charts/numbers.
lostboy
Has thanked: 2156 times
Been thanked: 426 times
Post by lostboy »
Potter wrote: Thu Jul 08, 2021 7:31 am None of the pictures on the first two pages work for me :(
Ditto.
I'm awful at everything.
God knows how I keep a job.
Has thanked: 10264 times
Been thanked: 6886 times
KungFooBob wrote: Thu Jul 08, 2021 11:52 am I'm awful at everything.
Ditto :(
Or stick a 16mm drill bit down the pipe.
Either way I assumed you'd need to rejet.
I might take it down the local dyno place for a run anyway, just to see what it's making.
The one I rode had a Vance and Hines and was very loud, it ran perfectly, but I think it had a dynojet kit as well
I've worked in IT since 1988, this afternoon I'm learning how to create a PowerPoint presentation, it's taking fucking ages
Remember to put as many slide transitions in as possible... and use a different effect for every single one.
Also animate every single paragraph reveal, again using as many different animations as possible, people love that!
And be sure to cover the slides in lots of text which you then read out.
lostboy
Post by lostboy »
Mr. Dazzle wrote: Thu Jul 08, 2021 2:58 pm And be sure to cover the slides in lots of text which you then read out.
Which you get up on the screen before you start reading it out - really engages the audience.
You lot can fuck right off, the company have bullied me into having the company blue stripe as a background on every page, it looks wank. The whole thing is a load of cut and pastes of Cisco diagrams, ducked if I'm drawing my own.
Has thanked: 15955 times
Been thanked: 10247 times
KungFooBob wrote: Thu Jul 08, 2021 8:19 am I've no idea how to embed the album, flickr seem to have dropped the BB code option.
Use imgbb.com, they give you the BB code option.
The bike didn't come with a tool kit, there's a spot for one under the pillion seat.... but there is this single Allen key in a special holder attacked to the underside of the riders seat. I've no idea what it's for.
Image211576730_3997024916999673_3091920171153641879_n_3997024900333008 by kungfoobob25, on Flickr
It's to take the pillion seat off so you can get to the toolkit
But the pillion seat cover has cross heads :)
You mean they're not original?
KungFooBob wrote: Fri Jul 09, 2021 10:22 am But the pillion seat cover has cross heads :)
That would appear to be the case
