Turntable
maccecht
Has thanked: 24 times
Been thanked: 156 times
Re: Turntable
Post by maccecht »
6mm steel plate tek screwed the Lazy Susan to the plate added a rope handle for ease of transport also handy to stand on and stop the plate spinning when putting the bike on the plate. Safe links
https://www.dropbox.com/s/dbrhcd7jomfdk ... 3.jpg?dl=0
https://www.dropbox.com/s/di5d3dtnaxyft ... 9.jpg?dl=0
Has thanked: 6191 times
Been thanked: 5087 times
Re: Turntable
Just thinking about my old K75/100s - you needed a hefty shove and hold on the seat to get the front wheel off the ground
Might be something for OP to consider?
iansoady
Has thanked: 59 times
Been thanked: 169 times
Re: Turntable
Post by iansoady »
Look forward to the pics!
maccecht
Re: Turntable
Post by maccecht »
iansoady wrote: Sun Jul 04, 2021 1:57 pm Look forward to the pics!
See my post above dropbox links. Mate turns his FJR 1300 on it and Beancounter turns his Caponard and 1150Gs on it without any issues
iansoady
Re: Turntable
Post by iansoady »
Missed the pics as replies coming thick & fast. Do I take it that the bottom race of the lazy susan just sits on the deck?
iansoady
Re: Turntable
Post by iansoady »
Horse wrote: Sun Jul 04, 2021 1:32 pm Just thinking about my old K75/100s - you needed a hefty shove and hold on the seat to get the front wheel off the ground
The xmax is quite well balanced front to rear on the centre stand although with a slight (perhaps 5kg or so) bias to the front wheel.
maccecht
Re: Turntable
Post by maccecht »
iansoady wrote: Sun Jul 04, 2021 4:50 pm Missed the pics as replies coming thick & fast. Do I take it that the bottom race of the lazy susan just sits on the deck?
Yes the idea is to keep it as low as possible or you will struggle to get the bike up on the stand
iansoady
Re: Turntable
Post by iansoady »
It's not too hard to get the xmax up on a 1" thick plank so I could probably sandwich the lazy susan between 2 bits of chequer plate or similar to make it a bit more stable.
Has thanked: 7817 times
Been thanked: 2528 times
Re: Turntable
Cousin Jack wrote: Sat Jul 03, 2021 3:51 pm https://www.ebay.co.uk/itm/391969687426 ... dc417a6255
Not too far above your budget.
I've got one of them, it's useless unless the floor surface is utterly flat (think polished marble)
iansoady
Re: Turntable
Post by iansoady »
Won't work on my Axminster then. I've ordered a lazy susan from Simply Bearings so let the rumpus begin.....
Has thanked: 1874 times
Been thanked: 2170 times
Re: Turntable
Makes it look so easy that. I like the cheerful thumbs up!
maccecht
Re: Turntable
Post by maccecht »
the_priest wrote: Wed Jul 07, 2021 10:31 am Makes it look so easy that. I like the cheerful thumbs up!
:obscene-drinkingcheers:
Man of your size could probably pick it up and turn it around no need for the turntable
iansoady
Re: Turntable
Post by iansoady »
Well I've made one. Lazy susan from simply bearings and some 5mm ply from a local skip (2 rectangles glued together to make 10mm), and 4 1/4" BSCy nuts & bolts. It works very well although getting the bike onto it requires a fair bit of effort - it may be worth running the back wheel onto a suitable plant to make life easier. Or maybe Mk II will have aplate made of 5mm alloy.
The strips of gaffer tape are to help locate the centre stand feet.
Has thanked: 1264 times
Been thanked: 1188 times
Re: Turntable
Post by slowsider »
Have you considered using a board long enough to go under both wheels?
iansoady
Re: Turntable
Post by iansoady »
But then it would go under the turntable as well and defeat the object. Unless I misunderstand?
Re: Turntable
iansoady wrote: Sat Jul 10, 2021 2:03 pm But then it would go under the turntable as well and defeat the object. Unless I misunderstand?
I think he means just the turney bit, so both front and rear wheels are off the ground.
Think of it as as like se-saw, with a fixed centre.
But instead of uppey downey, it's roundey roundey.
If you made the top a long 'T' shape: _____!____ then could you leave the bike on the sidestand?
Re: Turntable
Post by slowsider »
Does the board or the bearing go on the floor in your design? I assumed it was the bearing :eh:
Re: Turntable
slowsider wrote: Sat Jul 10, 2021 2:46 pm
If the strips of tape are to help locate the stand, they wouldn't be too helpful if facing down :)
iansoady
Re: Turntable
Post by iansoady »
Yes, the bearing faces down. I was going to add a plate but it seems quite stable as it is (300mm / 1ft diameter and flat) so won't bother.
The T shape would probably be an "advanced" design but actually I'm pretty happy with it as it is. Till I and the bike end up in an undignified heap.....
Oh, and when I say "locate" that's just visually although I was contemplating a length of 2x1 just in front of the centre point to act as a stop. But it doesn't seem to need it.
Re: Turntable
iansoady wrote: Sat Jul 10, 2021 3:00 pm I was contemplating a length of 2x1 just in front of the centre point to act as a stop
Would have worked well when you tried to ride away ;)
