It's only a teeny bit pink: GSX-R1100N
Re: It's only a teeny bit pink: GSX-R1100N
They were considered garish in 1992, fuck knows what Suzuki were thinking
Been thanked: 7530 times
I was on my knees scrubbing the rear wheel last night, the tail was right in my eyeline, man the top of that 'R' decal is really really pink!
Has thanked: 10265 times
Been thanked: 6886 times
inewham wrote: Tue Jul 06, 2021 3:55 pm
KungFooBob wrote: Tue Jul 06, 2021 12:32 pm I was on my knees scrubbing the rear wheel last night, the tail was right in my eyeline, man the top of that 'R' decal is really really pink!
Just think of it as Hi-vis, its a safety feature :thumbup:
It could hide in Bigyin's kitchen :banana-dance:
Has thanked: 1874 times
Been thanked: 2170 times
I like that. Old School fun and still fast enough to have proper fun. Looks very clean and smart. Hope you can sort the brakes out soon.
Less than 30 seconds after parking up...
Has thanked: 5451 times
Been thanked: 13087 times
in his defence, the options were fairly limited.
He spent a good two minutes checking it out... Then rode off on his Duke 2.
KungFooBob wrote: Wed Jul 07, 2021 3:42 pm He spent a good two minutes checking it out... Then rode off on his Duke 2.
Probably wondering were you kept the bumming hat
Has thanked: 9828 times
Been thanked: 10145 times
It's a baldy dude magnet. :thumbup:
Le_Fromage_Grande wrote: Wed Jul 07, 2021 4:13 pm
Probably wondering were you kept the pink bumming hat
Ftfy.
Bah, two miles from home the heavens open!
Managed to get almost 120 miles from a tank.... the light started to come on around 75 miles, but didn't stay on solid until 100, I gave in at 117 and put some fuel in.
Ramping up the rear pre-load seems to have help a lot, it's a bit sharper on the turn in.
I can't for the life of me get it to power up in 2nd, I hoped it would clutch up but I couldn't manage that either. The Blade would pop straight up in 2nd if you pinged the clutch. I guess it's the weight and longer gearing (the Blade had 6 gears, so 2nd would have been shorter?).
asmethurst99
Has thanked: 1042 times
Been thanked: 362 times
Post by asmethurst99 »
KungFooBob wrote: Wed Jul 07, 2021 5:43 pm Bah, two miles from home the heavens open!
My 95 blade seems to have really long gears to me esp 2nd .
Do you think it might have a wheely cut out gizmo in 2nd ?
Has thanked: 2551 times
Been thanked: 6245 times
The GSX is what...100mm longer and 30kg heavier than the blade?
Nah, I don't think it has any gizmos of any kind.
My 98 Blade made a SAE/DIN 120 RWBHP. I could clutch it up easy in 2nd.
The 1100 was rated by Suzuki at 140bhp or something silly, but in stock form makes 110-120 at the rear wheel.
I weighed the blade using car corner scales and with half a tank of fuel, it was 186kg. Suzuki claim 230kg dry!!!!
It's quite easy to get the GSXR up to a real life 140bhp. Loud pipes add 10bhp alone.
I'm enjoying the bike, easy wheelies are a nice to have, but only a small factor to overall enjoyment.
A couple of teeth extra on the rear will get you where you want to go.
Good point. My Blade was one tooth down on the front.
It probably retards the ignition in first and second to reduce power, lots of Suzukis that age did, apparently cutting the pink wire disables the retard, but I don't know if this is true
Le_Fromage_Grande wrote: Wed Jul 07, 2021 9:50 pm It probably retards the ignition in first and second to reduce power, lots of Suzukis that age did, apparently cutting the pink wire disables the retard, but I don't know if this is true
No,no,the pink wire takes power to the R decal. :o
Potter wrote: Thu Jul 08, 2021 7:31 am None of the pictures on the first two pages work for me :(
same here. THey're a very weird URL though, so i don't know where they're hosted as to whether they should still be working.
They're shared from FriendFace, I'll shift them in to flickr or something.
