Getting Old Bar Grips Off?
Has thanked: 10265 times
Been thanked: 6886 times
It appears that the grips on the mighty Husky have been glued on. After 10 moments cursing and swearing, the buggers still won't come off.
Is there a secret way ?
Do I need to buy new tubes?
What's for tea?
Couchy
Has thanked: 326 times
Been thanked: 2173 times
Re: Getting Old Bar Grips Off?
Post by Couchy »
We sometimes use compressed air with a small hose attachment. Normally works well
Couchy wrote: Thu Jul 01, 2021 7:23 pm We sometimes use compressed air with a small hose attachment. Normally works well
These buggers have been put on with some good glue. No way to get air in.
Been thanked: 2617 times
What solvents do you have to hand, or can get? Any of those might be worth a try. Probably easier buying a new throttle tube.
Acetone would be one of the first I'd try, somewhere that sell fibreglass might have it.
DefTrap
Has thanked: 2260 times
Been thanked: 2191 times
Post by DefTrap »
Judicious use of the wife's hairdryer?
Been thanked: 7530 times
You need to buy new.
That bike is obviously well used, you need a newer one with nice new grips.
Cut them off with a Stanley knife, it's not like you're going to use them again
Le_Fromage_Grande wrote: Thu Jul 01, 2021 8:54 pm Cut them off with a Stanley knife, it's not like you're going to use them again
Tried that. Glued all over.
KungFooBob wrote: Thu Jul 01, 2021 8:50 pm You need to buy new.
New bike next year.
Has thanked: 7817 times
Been thanked: 2528 times
Yorick wrote: Thu Jul 01, 2021 6:39 pm It appears that the grips on the mighty Husky have been glued on. After 10 moments cursing and swearing, the buggers still won't come off.
What's for tea?
If it were mine, I'd buy a new throttle tube (or try to find a 2nd hand one), but cut the left side off as best as possible with a sharp knife. If they're as badly glued as they look then getting the new grip on the throttle tube is going to be awkward unless you get all the glue off cleanly, but with the left one you can be a bit more forceful when you put the new grip on.
Has thanked: 261 times
Been thanked: 1265 times
Heat gun and scraper.
Finally got them cleaned and new grips fitted.
Then my pal says they come as a set. :(
https://www.odigrips.com/collections/mo ... grips-2723
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Post by Screwdriver »
Integrated part. That's a one piece design. Probably not glued but solvent weld.
Screwdriver wrote: Fri Jul 09, 2021 10:51 pm Integrated part. That's a one piece design. Probably not glued but solvent weld.
I know that now :mrgreen:
Those bark busters have seen some action considering you don't have any trees :p
KungFooBob wrote: Sat Jul 10, 2021 11:29 am Those bark busters have seen some action considering you don't have any trees :p
I just chuck it at the scenery willy nilly.
