- 7F784B57-B2B9-4C74-861E-608B4A0C0DB0.jpeg (700.79 KiB) Viewed 631 times
Puncture repair kit recommendations
- MingtheMerciless
- Has thanked: 2942 times
- Been thanked: 1883 times
Arse, what’s peoples favourite repair kit?
- Ditchfinder
- Has thanked: 621 times
- Been thanked: 692 times
Re: Puncture repair kit recommendations
bit of info on here: viewtopic.php?f=12&t=3107
- MingtheMerciless
Ta
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
I've got this one
https://www.ebay.co.uk/itm/164032861711 ... beEALw_wcB
bought after a succesful repair using a friends kit mentioned in the other thread.
- Has thanked: 1746 times
- Been thanked: 2085 times
I've got that one aswel. ☝ I first heard about it from our @Trinity765 . I watched the tube vids and all looked doable and simple enough.
As for my personal experience of it... it comes in a old school pencil case size bag, with a nice working zip. Plastic with some nice colourful touches. Should be waterproof and fit's snug under the tracer seat, or would equally be suited to a tail bag or such like.
Recommended.
Recommended.
- Has thanked: 9828 times
- Been thanked: 10145 times
If you're at home take the wheel out and get a proper repair done somewhere you trust,the other stuff is probably a 'get you home' solution and thus meant as a temporary fix.
- Has thanked: 2870 times
- Been thanked: 554 times
Can’t remember if they’re marketed as a temporary solution but they’re definitely not as permanent as a plug put in from the inside of the tyre. Having said that, I did have 5 plugs in an Avon Storm on my TDM850 ten years ago, still got nearly 15k miles out of the tyre.
- Has thanked: 10265 times
- Been thanked: 6886 times
Who said the Sweaties were tight?Beancounter wrote: ↑Sat Jun 26, 2021 4:42 pmCan’t remember if they’re marketed as a temporary solution but they’re definitely not as permanent as a plug put in from the inside of the tyre. Having said that, I did have 5 plugs in an Avon Storm on my TDM850 ten years ago, still got nearly 15k miles out of the tyre.
Only changed the tyre when it needed a sixth plug.Yorick wrote: ↑Sat Jun 26, 2021 5:01 pmWho said the Sweaties were tight?Beancounter wrote: ↑Sat Jun 26, 2021 4:42 pmCan’t remember if they’re marketed as a temporary solution but they’re definitely not as permanent as a plug put in from the inside of the tyre. Having said that, I did have 5 plugs in an Avon Storm on my TDM850 ten years ago, still got nearly 15k miles out of the tyre.
That's some mileage out of a tyre! 15k is about 5 sets for me.Beancounter wrote: ↑Sat Jun 26, 2021 4:42 pmCan’t remember if they’re marketed as a temporary solution but they’re definitely not as permanent as a plug put in from the inside of the tyre. Having said that, I did have 5 plugs in an Avon Storm on my TDM850 ten years ago, still got nearly 15k miles out of the tyre.
He rides like a girlSkub wrote: ↑Sat Jun 26, 2021 5:37 pmThat's some mileage out of a tyre! 15k is about 5 sets for me.Beancounter wrote: ↑Sat Jun 26, 2021 4:42 pmCan’t remember if they’re marketed as a temporary solution but they’re definitely not as permanent as a plug put in from the inside of the tyre. Having said that, I did have 5 plugs in an Avon Storm on my TDM850 ten years ago, still got nearly 15k miles out of the tyre.
S’true, I do.
TBF, it was commuting mileage from Chatham to London. The only corners were in the Blackwall Tunnel. Tyre was properly goosed by then, should have been changed 5,000 miles/3 punctures earlier.
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
I have this one under the seat of the Multi ....its a foldable glued strip type plug
image uploading service
Used it a few weeks ago when i picked up this lovely addition that was all the way in to the head and had to be unscrewed out as it wouldnt pull out
Its holding pressure fine but will get a professional one done when i find a local place that will do it as i have tried 3 and all said no to bike tyres
- Has thanked: 2635 times
- Been thanked: 1523 times
There's a FortNine video on puncture repairs... worth watching.
I've had good success with sticky string. Very easy to work into the puncture and seals well. After a vulcanised repair on a newly new tyre, I got a second flat just a couple of weeks later (ruddy builders up the road!) so used sticky string as I needed the bike - I finally ditched the tyre with maybe 1k left in it.
- DefTrap
- Has thanked: 2260 times
- Been thanked: 2191 times
I think there's a reason the sticky string type is popular. It's easy and is ready immediately w/o taking the tyre off, 99% of the time it'll get you home and there's a higher than average chance it'll outlast the tyre without any further intervention.
The only time I ever asked 'a pro' to do it (wheel and tyre off job with a 'proper' plug) the time and expense to get it fixed really wasn't worth it. Plus I had to listen to some grease monkey give me a load of bollocks about how much better it was ...
The www.Craftyplugger.com kit has saved me a few times. Doesn't age like those that need glue and you just find an empty tube.
Would help if their website worked properly. I don't know what the issue is but images seem to be blocked.scottyuk wrote: ↑Sat Jul 24, 2021 12:26 pm The www.Craftyplugger.com kit has saved me a few times. Doesn't age like those that need glue and you just find an empty tube.
Interestingly, I just did a search and my own www.facebook.com/survivalskills page came up!
It seems I'd asked a question about the kit and whether anyone used it all the way back in 2012! Can't say I remember that
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
I use the proper patches that you get in garages, well these were the ones we used when I was a tyre fitter many years ago.
Relatively cheap and if doing yourself makes perfect sense, they’re a permanent repair and good for tyres rated to 150mph so in theory they’ll do any tyre so long as you don’t go daft, I kept it to 149 and never took the bike back on track until I had another rear to throw on.
