Mushroom Plugs
Ditchfinder
Has thanked: 621 times
Been thanked: 692 times
Mushroom Plugs
Post by Ditchfinder »
Managed to pick up a screw in the rear tyre yesterday - luckily only a small. Local mechanic thinks a mushroom plug repair should be OK. It's in the middle of the rear tyre ( which is only 200 miles old). :angry-cussingblack:
Any of you guys used mushroom plugs before? Do you trust them?
DefTrap
Has thanked: 2260 times
Been thanked: 2191 times
Re: Mushroom Plugs
Post by DefTrap »
I have to say I still use the old fashioned diy sticky strip stuff because it's easy.
I had a mech install a mushroom plug in the distant past though because (he said) it was better.
Has thanked: 1947 times
Been thanked: 1292 times
Re: Mushroom Plugs
Post by Jody »
Ditchfinder wrote: Thu Jun 10, 2021 10:47 am Managed to pick up a screw in the rear tyre yesterday - luckily only a small. Local mechanic thinks a mushroom plug repair should be OK. It's in the middle of the rear tyre ( which is only 200 miles old). :angry-cussingblack:
A mushroom plug fitted from the inside?
Then yes, no problem if the hole is in the middle and not at an acute angle.
Has thanked: 7817 times
Been thanked: 2528 times
Re: Mushroom Plugs
Fitted by a decent mech, yes, it'll outlast the tyre. I've had exactly the same happen and plugs fitted with no issues at all.
Has thanked: 9828 times
Been thanked: 10145 times
Re: Mushroom Plugs
I've carried one of these for a good while,good enough to get you out of a hole. (ha)
https://www.amazon.co.uk/Stop-Go-1000-P ... th=1&psc=1
After not having a puncture for years,I had two on a new bike,one at only 260 miles. I had the tyre repaired twice with no qualms.
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Re: Mushroom Plugs
Post by Bigjawa »
I got a puncture about half a mile from getting a new tyre fitted, limped back to the shop and they plugged it, lasted the life of the tyre.
Trinity765
Has thanked: 2442 times
Been thanked: 2398 times
Re: Mushroom Plugs
Post by Trinity765 »
The Stop & Go kit has got me out of trouble a couple of times though I have always got a proper job done after. Just as well as according to FortNine they're shit.
Ditchfinder
Re: Mushroom Plugs
I shall insist on an internal patch after watching that vid !
Has thanked: 1746 times
Been thanked: 2085 times
Re: Mushroom Plugs
In the real world, what scenario would push the plugs back into the tyre with that force. 🤷🏻‍♂️
Has thanked: 10265 times
Been thanked: 6886 times
Re: Mushroom Plugs
On the road maybe. But never on track.
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
Re: Mushroom Plugs
Post by GuzziPaul »
I had a puncture on the ferry in a brand new rear tyre, ridden from home to the port 80 ish miles. Fortunately a mate had a DIY mushroom kit and air cannisters with him which was enough to get to a French motorcyle tyre spot. I got a new tyre fitted. We were at the start of a 2000+ holiday including fast motorways and the length of the Pyrenees backwards and forward over the passes. I didn't want the thought of my roadside repair on my mind.
However last week I got a screw in a fairly new car tyre I had that done professionaly with in plug from the inside and thats been fine so far (about 200 miles).
Ditchfinder
Re: Mushroom Plugs
The guy did a tyre off big mushroom patch, glue on the patch and the stem. After 3 commutes to work I'm not dead yet :-)
