Car - air con
Beancounter
Has thanked: 2870 times
Been thanked: 554 times
Car - air con
Post by Beancounter »
Ford Fiesta mk7, 2012. Air con no longer blows cold air.
I tried recharging the system without any success. It's been suggested to me that I need to change the pollen filter - could that really be the cause?
The car is due a service at the end of the month and the pollen filter is due to be changed as part of that but I'm curious to know why the filter would stop just cold air blowing through the vents.
Has thanked: 5451 times
Been thanked: 13087 times
Re: Car - air con
hmmmm how did you recharge it ? Didn't they test it there ?
Has thanked: 599 times
Been thanked: 2442 times
Re: Car - air con
Only if it were so old to be totally blocked and or freezing over.
Get it running, locate the AC clutch and see if it clicks in and out, i fit doesn't carefully (whilst it's all a spinning) give it a poke with a screwdriver, did I mention carefully? if that forces it to operate it's likely your magnets need shimming out.
Of course I'm assuming you've checked the obvious such as fuses and relays, that you haven't overcharged it and that you don;t have a massive leak
Beancounter
Re: Car - air con
weeksy wrote: Tue Jun 01, 2021 12:50 pm hmmmm how did you recharge it ? Didn't they test it there ?
I recharged it. Looked simple enough on the Youtube video.
MrLongbeard wrote: Tue Jun 01, 2021 12:52 pm Only if it were so old to be totally blocked and or freezing over.
Haven't checked fuses or relays yet, my car doesn't get used that often and it was only really yesterday that I wanted the air con (sat in traffic on the motorway).
I'm assuming I didn't overcharge it, the pressure needle didn't go into the red/over charge zone if that makes sense. I could have a leak tbf but I'm guessing that would need a garage to pressure test.
Has thanked: 836 times
Been thanked: 1238 times
Re: Car - air con
Does the aircon have it's own pollen filter, if not then why would that affect air temperature?
It's been a few years since I had aircon issues but what I do remember is there were a lot of mechanics around that didn't have a clue and would say any rubbish instead of admitting they were clueless, might be worth finding a mobile aircon specialist as the one I used in the end wasn't expensive.
The refrigerant changed around that time too and the new one was several times the price, dunno if that's changed but it could hurt.
Re: Car - air con
Beancounter wrote: Tue Jun 01, 2021 12:57 pm
They use a luminous spray/liquid thing.
Has thanked: 10265 times
Been thanked: 6886 times
Re: Car - air con
Do you need aircon in the UK?
Re: Car - air con
Yorick wrote: Tue Jun 01, 2021 1:02 pm Do you need aircon in the UK?
Summer started 3 days ago, it is too hot now.
Beancounter
Re: Car - air con
Mussels wrote: Tue Jun 01, 2021 12:59 pm Does the aircon have it's own pollen filter, if not then why would that affect air temperature?
Never thought of mobile air con specialist - thanks, I'll have a trawl.
Not usually but my Scottish blood doesn't like it when the mercury goes above 20oC.
Re: Car - air con
Beancounter wrote: Tue Jun 01, 2021 2:05 pm
It might start making Sweaties be generous, then where would we be?
Beancounter
Re: Car - air con
Yorick wrote: Tue Jun 01, 2021 2:18 pm It might start making Sweaties be generous, then where would we be?
That would be a very confused world.
