Dropper Seat Posts
- Has thanked: 1947 times
- Been thanked: 1292 times
Re: Dropper Seat Posts
I have one on my Zesty, it is handy and I wouldn't be without one having had it. Next time I'd spend the extra £££ and have the stealth one as the cable annoys my eyes (more than it should).
- Has thanked: 5456 times
- Been thanked: 13103 times
That's the best thing about the Vyron, it's that stealthy it has NO cables at all
That is cool as, but nearly 3x what I paid for mine !!!
Agree, but the great thing is also it's interchangability, especially for the small boy, his next bike i can swap it to as he's growing, then the next, till he stops growing etc.
It also stops all the faffing with cables, hydraulics, tension, bleeding etc..
- Been thanked: 4125 times
Following some months of procrastination I've ordered a dropper seat post, I haven't spent a lot because I want to see how I get on with it, if I really like it I'll order an expensive one when this one breaks
WHat's wrong in the reivews, i've run several KS droppers as has Crust, they've worked really well.
Reviews on Amazon said that one wasn't very good so I've bought this one instead
https://www.wiggle.co.uk/brand-x-ascend ... seatpost-1
which gets better reviews - and I'll probably live to regret getting instead of the KS one, though I wouldn't be surprised if it's the same one in a different packet
And you've got to be impressed with my impulsive ordering, changing my mind and ordering something slightly different - it's like I've learned from the master, Sensei Weeksy
- Ditchfinder
- Has thanked: 622 times
- Been thanked: 693 times
Can wholeheartedly recommend Brand x Ascend droppers - Got them on all the bikes never had a problem and easy to service. The remotes aren't perfect if your bars are cluttered with e-bike controls but lots of cheap remote levers on ebay.
*edit - yours has got the new remote - much better!
My Brand X post has developed a bit of side to side play, ie; the seat rotates slightly, is this normal, it doesn't affect riding, it's just a little annoying, I don't remember it doing this when I fitted it. It also might just be at the top of the seat travel.
And yes, I have checked everything is tight.
Aye, very common on all dropper posts.Le_Fromage_Grande wrote: ↑Mon May 03, 2021 8:06 pm My Brand X post has developed a bit of side to side play, ie; the seat rotates slightly, is this normal, it doesn't affect riding, it's just a little annoying, I don't remember it doing this when I fitted it. It also might just be at the top of the seat travel.
Thanks, I won't spend hours trying to fix it if it's normal.weeksy wrote: ↑Mon May 03, 2021 8:30 pmAye, very common on all dropper posts.Le_Fromage_Grande wrote: ↑Mon May 03, 2021 8:06 pm My Brand X post has developed a bit of side to side play, ie; the seat rotates slightly, is this normal, it doesn't affect riding, it's just a little annoying, I don't remember it doing this when I fitted it. It also might just be at the top of the seat travel.
- Has thanked: 498 times
- Been thanked: 650 times
I'd like one of these. They sound good for bollocking along on the open bits and lowering it for better control in the tighter bits.
My bike is fairly basic, a 2014 Charge Cooker and I don't use it a huge amount. Is there an ok budgety option which might suit my needs?
If you want cable operated about £150, lever under the seat about £80
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
TBH all dropper posts seem to wobble slightly - I used to worry about mine but no longer do ( two Reverbs, two Brand Xs ...)
