Solar trickle charger?
- Has thanked: 2249 times
- Been thanked: 1243 times
Anyone tried one?
Our garage is remote to the house with no power and have been thinking about mounting a solar charger on the garage roof - views, recommendations?
- Has thanked: 599 times
- Been thanked: 2451 times
Re: Solar trickle charger?
Off grid BiL is looking at a bike with an alarm so needs something, else muggins here get the job of cutting the alarm out.
I did buy a small solar panel along with a charge controller, haven't got round to fitting it to the garage yet though.....
Reviews of it were good but no first hand data yet.
- Has thanked: 164 times
- Been thanked: 308 times
I've generally found the solar trickle chargers poorly made and very low power.
My electrical shed (where I do most of my leccy repairs), funnily enough, isn't connected to the mains.
So....have a 'proper' sized panel with a solar charge controller connected to a big 12V leisure battery and then run lights 12V plus a 1kW inverter for any mains devices, which could include a trickle charger, although the charge could be provided straight from the controller if it is suitable for connecting to cranking batteries.
When I say a small panel, it's about 30cm X 30cm. They reckon high enough output to charge a car battery but until I can get my lazy arse in gear and install it, I have no evidence.
- Has thanked: 10276 times
- Been thanked: 6891 times
Ditto, but BiL is off grid, no drains, no water, no gas, no leccy, no nothing except for woodland, so is looking at alternatives
- MingtheMerciless
- Has thanked: 2947 times
- Been thanked: 1884 times
I’ve got the optimate 80W solar charger on the roof of the bike shed. Even on dull winter days the plastic brain tells me it’s generating charge. It’s charging a 12V 80AH Telecoms standby battery which is linked to the motorbikes battery. All seems to work ok.
- chutzpah
- Has thanked: 21 times
- Been thanked: 96 times
I used the Optimate (https://www.optimate.co.uk/products/optimate-solar) for the first time last winter. Alternated it between my wife's and my bike, seemed to work well enough. Even in murky conditions as @MingtheMerciless says.
If he's not in an immediate rush it's worth setting up an ebay and facebook marketplace alert. I got mine for about £65.
