weeksy wrote: ↑Mon Apr 05, 2021 3:12 pm
Hot_Air wrote: ↑Mon Apr 05, 2021 2:59 pm
So, should we slow down on our approach to junctions because it gives drivers the extra cognitive time to react to being startled by a bike?
Probably. But then I wouldn't own a fast motorbike if being 100% safe was a priority. I accept I do things differently on bikes than I would out in a car. Just how it is.
We're not talking creep along to the junction, but it's no coincidence that in London, the riders killed at junctions were more often speeding than not, and that includes in 20s... drivers tend to overestimate distance / underestimate speed and think they have more time to pull out anyway, and when bikes are moving faster than the traffic around them it just makes it more difficult. And it's also worth remembering that if you double your speed, you quadruple your stopping distance... relatively minor increases in speed have surprising impacts on lengthening stopping distances... but the physics works the other way - if you halve your speed, your stopping distance is ONE QUARTER of what it was... which means that relatively minor reductions in speed have surprising benefits in reducing stopping distances. From 25 mph, I can stop the bike in three bike lengths. That should avoid just about every urban SMIDSY.
The lack of width of a bike makes it easy to hide, but it also confers the opposite benefit - we can usually get out from behind things to SEE and BE SEEN - but a surprising number of riders make absolutely zero effort either to see what's about to wipe them out or to help the driver spot them before he / she pulls out.
I can honestly say that in 16 years and 500,000 miles of despatching, most of which was in London, I never once had a SMIDSY. I had a few near-misses including some butt-puckerers in the early years but I learned to look for the clues. The trick is to listen to Spidey Sense... there are many times you look at the developing situation and alarm bells go off... or should do. In my experience, the times to worry are:
CANNOT BE SEEN
- if the driver's looking the wrong way / bike's hidden behind an obstacle
LOOKED, BUT FAILED TO SEE
- when there's a fair-sized gap between you and the car ahead and a car relatively close behind
- when there's empty space ahead and a gap in a stream of traffic coming the other way
- when the vehicle that's about to turn will get to the junction just about the same time as you do
- when the second vehicle is following another vehicle into the manoeuvre
LOOKED, SAW BUT MISJUDGED
- when you're on a faster road, or riding faster than the traffic around you
And don't forget... SMIDSYs happen when vehicles turn across the bike's path from the opposite direction - this one's actually the killer crash in urban areas. Most riders are totally unaware of that little factoid.
