Car polishers?
Has thanked: 15955 times
Been thanked: 10248 times
Car polishers?
Are these sort of polishers any good? Not looking to spend a fortune as it'll probably only get used a few times.
https://www.ebay.co.uk/itm/16PCS-5-Car- ... 1196.m2219
https://www.ebay.co.uk/itm/Electric-Car ... Sw4a9gDD0I
Has thanked: 836 times
Been thanked: 1238 times
Re: Car polishers?
If you get one make sure it's random orbit, same as sanders to avoid swirls. I bought a cheap one to get rid of a gauge in my van, it did OK but was aggressive so I didn't like using it.
Maybe if I had more practice it would be fine.
Has thanked: 5451 times
Been thanked: 13087 times
Re: Car polishers?
DAS6 are great yes.
www.cleanyourcar.co.uk
Has thanked: 1746 times
Been thanked: 2085 times
Re: Car polishers?
Be careful where you put it down, if it picks up a bit of grit, oh dear, personally I'd stick with a hand job. ๐Ÿ‘
Re: Car polishers?
weeksy wrote: โ†‘Sat Mar 27, 2021 3:05 pm DAS6 are great yes.
That one?
https://www.cleanyourcar.co.uk/das-6-v2 ... n-polisher
Re: Car polishers?
Aye. You often get a set with various polish etc combined and a bag.
Has thanked: 1507 times
Been thanked: 1412 times
Re: Car polishers?
The kits that include the pads usually come with the cheapest pads made & are total crap. I rinsed a pad recently & discovered they used water based glue to attach the velcro...
ogri
Has thanked: 1036 times
Been thanked: 224 times
Re: Car polishers?
Post by ogri »
Dodgy knees wrote: โ†‘Sat Mar 27, 2021 3:22 pm Be careful where you put it down, if it picks up a bit of grit, oh dear, personally I'd stick with a hand job. ๐Ÿ‘
$10 and you can give me a hand job! :)
Unless you know what you are doing i would stick to traditional cleaning, less chance of damaging the paintwork!
Ignorance is bliss
Re: Car polishers?
ogri wrote: โ†‘Sat Mar 27, 2021 10:12 pm
You're about the 5th person to say that to me! I'm starting to bottle it a bit now. :? I suppose I do need the exercise... :lol:
Re: Car polishers?
Taipan wrote: โ†‘Sun Mar 28, 2021 11:30 am
You've got to be a proper spanner to fuck it up with a das6
Re: Car polishers?
weeksy wrote: โ†‘Sun Mar 28, 2021 12:34 pm
Me earlier! :banana-wrench:
Has thanked: 809 times
Been thanked: 4801 times
Re: Car polishers?
On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
https://www.eurocarparts.com/p/holts-he ... MREALw_wcB
Re: Car polishers?
gremlin wrote: โ†‘Mon Mar 29, 2021 2:40 pm On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
Solvol & a rag.
asmethurst99
Has thanked: 1042 times
Been thanked: 362 times
Re: Car polishers?
Post by asmethurst99 »
Toothpaste ?
Been thanked: 7530 times
Re: Car polishers?
I did the lights on my FTO with ever increasing numbered grades of wet and dry (with lots of wet). Then polished off with some cutting compound. They turned out brilliant.
Re: Car polishers?
ZRX61 wrote: โ†‘Mon Mar 29, 2021 4:36 pm
Solvol & a rag.
Tried that, as well as a glass polishing compound I have. No joy.
I think I need to get in with ever-decreasing coarseness W&D and then use the polishing stuff.
It's gonna get messy.
Re: Car polishers?
gremlin wrote: โ†‘Tue Mar 30, 2021 9:13 am
Solvol & a rag.
Are you sure the yellow is just on the surface and not all the way through?
Re: Car polishers?
Mussels wrote: โ†‘Tue Mar 30, 2021 11:28 am
Solvol & a rag.
You can feel it as you rub your finger over it, so assuming its surface. It's not actually that bad and you struggle to see it at any sort of distance. I only noticed it as I was tidying up the engine bay with the bonnet lifted.
Currently it's only on the top edges of one light, so not too bad, but if I can tackle it now, it's the proverbial stitch in time.
Re: Car polishers?
Well I suppose the logical approach is to try it by hand first and if it doesnโ€™t come out right, then try a polisher.
Re: Car polishers?
You've multiplied your efforts X 10
