I know, we have a little bit of a laugh with the CBT first timers and tell them they WILL look at their hands and feet and they all say they wont as they agree there is no need ....... 5 minutes later they hear a shouted "why are you looking down, look where you want to go" again and again
New rider advice
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
Re: New rider advice
Okay, I'm certainly not at the stage were I'm looking down at my feet. I'm not riding along struggling with every change, but aware I need to change something. I don't think I need to go back to the training school. I'll take some of the points above and work on them.
- Bigyin
I wasnt implying you were looking down while riding but the change in bike has changed where your foot and lever are which might be why you are having some issues. By starting from scratch on foot position it might solve thosetricol wrote: ↑Thu Mar 25, 2021 5:40 pm Okay, I'm certainly not at the stage were I'm looking down at my feet. I'm not riding along struggling with every change, but aware I need to change something. I don't think I need to go back to the training school. I'll take some of the points above and work on them.
- Been thanked: 4124 times
Buy a geared restricted moped, 5 gear changes to 30mph will quickly reach you to perfect gear changes
Perfect. I'll get her traded in prontoLe_Fromage_Grande wrote: ↑Thu Mar 25, 2021 8:52 pm Buy a geared restricted moped, 5 gear changes to 30mph will quickly reach you to perfect gear changes
- Been thanked: 7530 times
You'll need to perfect that 2nd to 3rd change, if you want to pull mile long mingers.
I was going to try and give advice about changing gear, then remembered I learned 38 years ago on a TS50 and it's become so natural I don't think about it.
But adjusting the gear lever to the right place helps a lot, yours might be a bit high for you.
- Has thanked: 2635 times
- Been thanked: 1523 times
I'm right here
Re the gear shifts... if it's a brand-new bike the gearbox will be a bit stiff anyway. So it'll bed in and get easier with time.tricol wrote: ↑Thu Mar 25, 2021 11:49 am Morning all,
So, I am just 100 miles into motorbike ownership/riding. It's been a real thrill so far, not being hooked up to an earpiece being reminded of those lifesavers every 2 seconds. Lots of what I learnt has stuck thankfully, and I feel (quietly) confident on the new Trident. Last night I got out for another quick spin as the roads were dry and the sun was out, although not very warm yet. I found that I was fluffing quite a few of my gear changes. Now, I'm sure it will come good with more and more miles, but on a few occasions I was missing changes altogether, rather than just not being smooth. I learnt on an SV650 mostly (about an hour on a Z650, too) and I didn't seem to have as many issues with that changing on that. It feels like the gear shifter is much closer to the footpeg on the Trident that on the SV. Or maybe not and I need to work on my foot position.
- Does anyone have good tips for smoother gear changes?
- Anything else to start working on now I'm in the puppy stage of learning?
I'm sure the fountain of knowledge on here will help!
Some other thoughts...
Are you wearing the same boots you were during your training course? Lots of riders get the pass under their belts THEN buy their riding kit, so if you've changed it's possible the boot is an issue.
The other thing I noticed looking at the Trident is that it has a reversed gear lever - that is, it points back towards the foot from the pivot point. I can't recall what it was but I rode a bike like this years ago and found gear shifting difficult because the lever doesn't rock naturally with the foot. What I found helped was a liberal coating of dubbin on the top of the boot, to help the rubber on the shift lever slide over the boot. Give that a try and see what happens.
Make sure you are getting the lever ALL the way back to the bar when you pull it in. Some bikes you can change gear easily just by pulling the clutch lever part way in. But not with all bikes. I haven't ridden the Trident, but whilst a little dip of the clutch is enough for my Honda to shift, it won't work with my Yamaha - the lever has to come all the way back.
And don't RUSH the gear shift - there's no need. Many new riders try to get the clutch in and out as quickly as possible (especially if they have ridden a 125 before taking the test). Pull the lever in smoothly, THEN shift (and remember to take your foot away from the lever) and then release the clutch smoothly again.
Last edited by The Spin Doctor on Thu Mar 25, 2021 9:31 pm, edited 1 time in total.
Although there's no span adjuster on the lever, you CAN adjust it by using the cable adjuster.
The reversed gear lever is interesting, my Kawasaki was like this and the gear change was heavy, rearsets have made it the normal way round and it's better.
Now you have reminded me, I think it was the ER-5. That had a reversed linkage. We had some at the bike school.Le_Fromage_Grande wrote: ↑Thu Mar 25, 2021 9:41 pm The reversed gear lever is interesting, my Kawasaki was like this and the gear change was heavy, rearsets have made it the normal way round and it's better.
- Has thanked: 705 times
- Been thanked: 701 times
I think Spin has probably hit the nail on the head (as usual). When I picked up my brand new Speed Twin in June the gearbox was very stiff and notchy for the first couple of hundred miles- it may be a Triumph thing. More time in the saddle will likely be the answer
- Has thanked: 6191 times
- Been thanked: 5087 times
Make gearchanges like a jazz improv drummer.
123432123454321234543212354321232123 ...
OK, so rule out boots and point finger at gear shift.
There's no linkage on the Triumph, that's my point... it's bolted directly to the gear change shaft by the look of the photos, so points 'backwards' and that means it pivots the other way round too rather than moving the same as your foot is moving around your ankle. What that means is that as you change up a gear, the rubber actually has to slide across your boot.
The SV has a rearset linkage:
https://www.globalsuzuki.com/motorcycle ... 3806982464
Try a bit of dubbin on the boot, and with a bit of luck that and more miles is that answer.
I think there's a rod from the lever to somewhere high on the engine, which also tends to say that the selector drum is quite high in the engine, which might also have a ne effect on gear changes.
- Has thanked: 4361 times
- Been thanked: 2851 times
On my 690 Duke I had a fair few false naturals and the odd missed shift when I first got it. Cures were
1. Adjust the lever. As standard the 690 comes with an almost off road bike very high lever, once lowered it was miles better.
2. Being positive with shifts. Even now it doesn't like lazy shifts at times, the gear box prefers to have the engine under load and a positive foot.
3. Miles. Over the course of the first 600 miles the gearbox got a lot better.
- Has thanked: 7817 times
- Been thanked: 2528 times
Re the clutch lever - when you're on the bike, are your lower arms-wrists-back-fo-hands all 'inline' ? if you have to cock your wrist 'up' to get fingers on the levers then you're losing mechanical advantage. Should be simple enough to loosen the lever mount and rotate them slightly around the bar so that the back your hand, when your fingers are resting on the levers, is inline with your wrist and lower arm.
Definitely worth trying although there may be a pin in the mount which precludes this. I discovered that problem when meeting a trainee who was collecting his brand-new Ducati SS ready for a Confidence: BUILDER one-day course. They were set for a 'flat on the tank' riding position and awkwardly cocked up. The dealer's mechanic tried to move them for him after I'd pointed it, and couldn't, thanks to the pin.Rockburner wrote: ↑Fri Mar 26, 2021 2:26 pm Re the clutch lever - when you're on the bike, are your lower arms-wrists-back-fo-hands all 'inline' ? if you have to cock your wrist 'up' to get fingers on the levers then you're losing mechanical advantage. Should be simple enough to loosen the lever mount and rotate them slightly around the bar so that the back your hand, when your fingers are resting on the levers, is inline with your wrist and lower arm.
