gluing a plastic lug thing, what to use
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
So whilst doing some bits I've managed to brake this lug off , what's the best way to glue it/fix it back on that's nice and strong???
cheers
cheers
- 0425929C-347A-4F40-8F39-809832F0A94F.jpeg (217.6 KiB) Viewed 929 times
CBR650r
- Has thanked: 7817 times
- Been thanked: 2528 times
- formula400
- formula400
- Been thanked: 4124 times
Re: gluing a plastic lug thing, what to use
IME once those kind of lugs break, they're broken, the stress of pulling them in and out of the rubber will break any repair
- formula400
- Has thanked: 836 times
- Been thanked: 1238 times
I wouldn't trust trying to stick that, even with plastic weld. I think I'd bend a bit of metal to go right over and stick to the plastic either side. Then tap a hole (or drill it and use the existing clip) and it should be plenty strong enough.
The problem I see with that is the panel could be a couple of mm proud when I goes back on, some more careful forming of the metal will help with that.
- Has thanked: 498 times
- Been thanked: 650 times
Plastic welding is melting it back together with a hot thing like a soldering iron. I think you can get it professionally done.
Like LFG I think it's difficult to ever make a good repair. The most successful I ever managed involved drilling and wiring it together in several areas then covering with an epoxy putty. I was always careful with that panel after that and a good yank would have fucked it I suspect. Plastic welding is probably the most durable.
- formula400
Right cheers you lot, seems like a lot of sodding around that might not even work.
New one it is.
New one it is.
CBR650r
- Has thanked: 2551 times
- Been thanked: 6245 times
Thermoplastics, I.e. the sort of heat formed/injection moulded stuff you're looking at here, are notoriously hard to bond to...even with brand new materials going through all sorts of fancy surface treatments they're not great. So you're always gonna struggle with a used bike bit and DIY
I've had success with superglue and - wait for it - baking soda. Stick the parts with superglue. When set, make a leayer of superglue over the area and sprinkle with the baking soda while still liquid. It will set into a hard substance which is surprisingly strong. You can go on to add more layers.
I used this technique for the lugs on a Triumph Tiger side cover and it lasted well.
- Ditchfinder
- Has thanked: 621 times
- Been thanked: 692 times
Fixed a broken lug using a soldering iron and melting zip ties into the areas that needed toughening up. Lasted fine, was as strong as before. Watched a couple of tutorials on YT then practised on a bit of scrap first.
- Has thanked: 23 times
- Been thanked: 19 times
If you have a 3D printer I'd make another bracket and weld that to the panel, rather than the snapped part to the bracket. You could widen the base of the bracket to give it a bigger base to weld with.
- formula400
Got to love flowers triumph, order Wednesday night, here this morning.
- BBA34850-11F9-4DA5-BBD8-0AD5E6956B12.jpeg (169.88 KiB) Viewed 785 times
CBR650r
- formula400
