YAMAHA YZ/RD350 SUPERMOTO BY SPOKEN MOTO
Has thanked: 5504 times
Been thanked: 12760 times
https://www.bikebound.com/2018/02/16/ya ... supermoto/
As the days pass and we see more bikes, it's getting harder and harder to find things to provoke either interest or discussion. But we'll keep plodding on and seeing what you fellas think.
Has thanked: 10117 times
Been thanked: 6649 times
Re: YAMAHA YZ/RD350 SUPERMOTO BY SPOKEN MOTO
The spannies look cool.
Has thanked: 1326 times
Been thanked: 1652 times
Well, its different anyway.
The gold cylinder head fins look a bit John McCriricks watch, dunno why on earth anyone would get a gold anodised cylinderhead* and the styling is a bit Mad Max.
I never knew Banshees only had one carb though. The expansion chambers look like a bit of work unless they are off something else (maybe a Banshee? But obviously I've never even seen one of those so I dunno) and not much work needed? Unless I missed it they didn't say much about the spannies.
By the two filler caps it looks like they kept the autolube so thats a massive plus from me cos premix is a pain in the fucking arse on any bike you have to fill up at a filling station.
*You'll see the jokes on me when an item lands through the post.
Yeah, just checked and the spannies look like they might have been off a Banshee, these aren't exactly the same but they're not a kick in the arse off the same style.
Has thanked: 9688 times
Been thanked: 9704 times
Loads of work gone into that. The writeup is interesting.
A stroker with a nitrous button.... :shock:
I keeping thinking I'd rather have a nicely sorted TDR,but I can appreciate the engineering gone into this bike. The visuals might grow on me.
demographic wrote: Sun Mar 14, 2021 12:31 pm
Once we modified the frame to accommodate the RD motor, we really wanted to run the chambers up high and tight to the cylinders. That required running a single carb — banshee style. My tuner gave me crap about sacrificing top end so I thought a shot of nitrous would keep him quiet.
The chambers are actually FMF Fatty Banshee pipes that we cut into pieces and rebuilt to fit.
Skub wrote: Sun Mar 14, 2021 1:10 pm
Ah, 2/10 for my reading comprehension then.
To be fair, that article did have a shitload of filler to make up the wordcount.
Ideally they talk less about the people and more about the bike.
demographic wrote: Sun Mar 14, 2021 2:18 pm Ideally they talk less about the people and more about the bike.
You sound like me there,demo. :lol:
Having said that,they do sound like interesting company.
G.P
Has thanked: 2113 times
Been thanked: 1310 times
Post by G.P »
Its bonkers, I love it, but having ridden a YZ490, i'd rather it had a 490 unit in it.
Still, most interesting "custom" posted for a while.
Ya can't just cut and chop expansion chambers. They're designed to an exact spec. Otherwise you'll lose power.
Yorick wrote: Sun Mar 14, 2021 3:05 pm Ya can't just cut and chop expansion chambers. They're designed to an exact spec. Otherwise you'll lose power.
You can however cut them at the welds and rotate them to another angle which may or may not help the fit without changing the cone dimensions as far as the engine is concerned.
demographic wrote: Sun Mar 14, 2021 3:15 pm
Ooooooooo. Get her...
Yorick wrote: Sun Mar 14, 2021 3:16 pm Ooooooooo. Get her...
There's a reason I know that trick and its possible I might have to do it myself before too long.
I used to be a coded welder a long time ago and as long as I scrounge a welder up I'll give it a bash.
I have other spannies I can use but theres one tank I would rather use on the bike and that one has clearance issues with the standard spannie.
The one I might end up adjusting never really fit but I suspect was badly jigged when manufactured.
Or put it this way, its buggerall use as it is and with luck I'll be able to salvage it.
Potter
Has thanked: 2216 times
Been thanked: 4612 times
Post by Potter »
That's the bit that killed my pig really, he deliberately built in a fault, then added something else to try and mitigate it.
I don't like how it looks, but I'd have given him kudos for the build, but designing in faults and adding bolt-on NOS to make up for it just says poor designer to me.
I come from an era when custom bikes were done to make them better than the mass produced standard stuff, but he's deliberately made it a fundamentally more flawed bike than anything that left the factory.
