Weird motorcycle things you remember
- Has thanked: 626 times
- Been thanked: 4070 times
Prompted by Weeksy's heated grip trauma, I remember an article in a motorcycle magazine in the 80s where someone decided to heat their handlebars by rerouting the water cooling hosing so that the hot water flowed in one end of the handlebars and out the other, I tried to find pictures of this wondrous piece of engineering but sadly, I couldn't find any.
What other weird and wonderful things do you remember?
- Has thanked: 5503 times
- Been thanked: 12760 times
- Has thanked: 532 times
- Been thanked: 7238 times
Re: Weird motorcycle things you remember
That helmet attachment that worked like a windscreen wiper.
The Norton Nemesis.
Carlos Checa having a BT1100 as his road bike.
The Norton Nemesis.
- Been thanked: 2501 times
Jock Kerr's solution in making 250cc bikes legal for learners, who could only ride up to 125cc bikes.
Tilting sidecars for similar reasons.
The French dogturd cleanerupper, based on an XT500.
Paired brake discs. Two discs running next to each but with one caliper and three pads.
Inboard disc brakes by Honda.
It's Friday afternoon, I'm clock watching, waiting to go home
- Has thanked: 264 times
- Been thanked: 1242 times
- Has thanked: 7727 times
- Been thanked: 2401 times
Sounds like Malcom's Patent Winter 'Keep-U-Warm' Exhaust Extension - that wound around the rider's body before feeding back into the carb.....Le_Fromage_Grande wrote: ↑Fri Feb 12, 2021 3:07 pm Prompted by Weeksy's heated grip trauma, I remember an article in a motorcycle magazine in the 80s where someone decided to heat their handlebars by rerouting the water cooling hosing so that the hot water flowed in one end of the handlebars and out the other, I tried to find pictures of this wondrous piece of engineering but sadly, I couldn't find any.
- Has thanked: 223 times
- Been thanked: 842 times
Bar snake, was like a solid rubber hose that you fed through your bars to kill vibration, you got a liquid version too that poured in and set.
Then there was Slik Move, a bike racing board game.....
Was that the one with Grand Scratch as the track?
- Has thanked: 2632 times
- Been thanked: 1498 times
I knew the guy. Complete lunatic. His kit was for the courier favourite - the CX500.Le_Fromage_Grande wrote: ↑Fri Feb 12, 2021 3:07 pm Prompted by Weeksy's heated grip trauma, I remember an article in a motorcycle magazine in the 80s where someone decided to heat their handlebars by rerouting the water cooling hosing so that the hot water flowed in one end of the handlebars and out the other, I tried to find pictures of this wondrous piece of engineering but sadly, I couldn't find any.
Hardley Worthit sold a kit that used engine oil to heat the grips.Le_Fromage_Grande wrote: ↑Fri Feb 12, 2021 3:07 pm Prompted by Weeksy's heated grip trauma, I remember an article in a motorcycle magazine in the 80s where someone decided to heat their handlebars by rerouting the water cooling hosing so that the hot water flowed in one end of the handlebars and out the other, I tried to find pictures of this wondrous piece of engineering but sadly, I couldn't find any.
I absolutely shit you not.
Alister ? early 70's exhaust silencing valve.
Think of a throttle valve with holes in the flap, operated by a lever on the handle bar.
open out of town, closedish in town.
Weird that the RD200 came with electric start but none of its brothers did. Also the RD125 came with a sort of steering damper ie a knob that you turned on the head stock to tighten the stem bearings.
- Potter
- Has thanked: 2216 times
- Been thanked: 4612 times
Going to the bike show and seeing the NR750 concept bike, none of us had heard of carbon fibre and we were all talking in the pub afterwards about this weird matt like stuff under varnish.
- Has thanked: 216 times
- Been thanked: 666 times
iirc the RD200 alternator and starter motor were the same component - feed power to it to start the engine, then let the engine turn it to generate electricity.
The YDS7 and YR5 also used a friction steering damper, as did my Suzuki T500
- Has thanked: 2611 times
- Been thanked: 6015 times
Integrated Starter Generator. Only now becoming common (on cars) again.
