- Has thanked: 97 times
- Been thanked: 107 times
Guess the donor bike
(Should be an easy one)
- 144907525_10158535555606154_7340885702300496174_n.jpg (70.31 KiB) Viewed 1005 times
- Has thanked: 626 times
- Been thanked: 4063 times
This is a Sachs rotary
That Hercules appears to have a weird two stroke engine that is intriguing
- DefTrap
- Has thanked: 2269 times
- Been thanked: 2086 times
Still my favourite bike on this thread.
A lot of them (XVs) have been done, few are as good.
- rodbargee
- Has thanked: 352 times
- Been thanked: 969 times
the discussion about the hercules was that the reed valve inlet and odd exhaust positioning was a rotary. I I get that its not like the other one pictured, I would love more info on it. if thE chamber was 90deg putting it inline? and finned without that huge air intake.
- Has thanked: 5945 times
- Been thanked: 4932 times
The DKW is a rotary like the Norton F1. 'Triangular' piston.
That is a Wankel, and very interesting, I wonder how they've geared the rotor to the clutch.rodbargee wrote: ↑Mon Feb 01, 2021 3:52 pm Here....https://motocrossactionmag.com/bikes-yo ... 02-rotary/
So is the Hercules MX bike, the rotor is vertically above the crankcases.
Ah, ok, apologies. First glance it just looks like a normal 2t barrel at an angle.
- Has thanked: 1326 times
- Been thanked: 1652 times
- Has thanked: 532 times
- Been thanked: 7222 times
- Has thanked: 5503 times
- Been thanked: 12760 times
Stolen off the Benelli website...
754cc Bore x Stroke - 88x62mm Engine layout - Parallel twin Engine details - 4-stroke, liquid cooled, 4 valves per cylinder, dohc Power - 80bhp Torque - 50lb-ft Top speed Est - 135mph Transmission - 6 speed, chain drive Tank size - 15 litres Frame - Steel Trellis Front suspension - 50mm USD hydraulic forks Front suspension - adjustment Compression, rebound and pre-load Rear suspension - Single Hydraulic Shock Rear suspension - adjustment Preload and rebound Front brake - 2 x 320mm discs, mono block Brembo 4 pot calipers Rear brake - 1 x 260mm disc, twin pot caliper Kerb weight - 220kg
I saw another picture of it side on, the tank is quite an odd shape.
- Has thanked: 15606 times
- Been thanked: 9849 times
The Dispatchers hack, the plastic maggot. Looks interesting and well done from that pic. Got any more pics?
- Has thanked: 9682 times
- Been thanked: 9702 times
That power and weight equates pretty much to a Z1 in 1973.Druid wrote: ↑Mon Feb 01, 2021 7:59 pm750 parallel twin, 80bhp, 220kg
https://www.bennetts.co.uk/bikesocial/n ... 0-new-spec
Everything weighs 220kg these days, it's almost like most modern bikes are built to that as a target weight.
