- Has thanked: 1448 times
- Been thanked: 1333 times
Discovered that I have disparaged oiks of questionable morals in error. Went to AAA (US version of AA) as they do DMV (DVLC) stuff without having to actually deal with the DMV.
Imagine my surprise when I discovered that I wasn't going to be paying $23 for a replacement tag, but had actually neglected to renew the tags last April & the fuckers were going to bend me over for $188
Oh well, all up to date now.. until April when I have to buy '22 tags AND get a fucking smog test (another $50, every two years)
- Bigyin
- Has thanked: 1418 times
- Been thanked: 2620 times
Today i went into work for the first time in over a month so we could check over the bikes, sort out emails from DVSA and look at new recording practises as well as some training for the newer instructors (me and 1 other)
All the bikes brought out, fired up, ridden to test brakes and check tyre pressures. Some refresh stuff on lessons for training pad work then everything away and bugger off home again.
- Has thanked: 16272 times
- Been thanked: 3747 times
I just wrote out all my physio exercises (he seems to add a couple more every appointment!) -
I now have an A4 page full of exercises!! ok - some lines empty, but it's 25 exercises x 10 each I thought it took me a long time!! LOL
- Has thanked: 2611 times
- Been thanked: 6015 times
Check the temperature you're cooking at, oil that is too cold will often make things greasy. You can make grease free, nice and dry, crispy stuff in a deep frier can't you so its generally not the AMOUNT of oil that matters.
- MingtheMerciless
- Has thanked: 2917 times
- Been thanked: 1847 times
Not fu*king slept again, ended up binge watching Battlestar Galactica till 0500 and then raging at the BBC for cutting it.
- Has thanked: 1054 times
- Been thanked: 354 times
Just been to my lock up and re fitted fire blade battery .asmethurst99 wrote: ↑Thu Jan 28, 2021 9:46 pm Had a day off after 2 days of re deployment ...bit weary after doing two 13 hour days .
Went to LIDL with a rather low in mood son ( lockdown isn't doing children any good surprisingly) and bought a soldering iron as he's started fiddling around with old IPODS etc .
Long day am - Saturday Tabun fit battery to 900 .
Was looking forward to some time off next week but our re deployment has been cancelled after only a week so a tiny pin prick of light at the end of the Tunnel perhaps .
My magnetic pick tool arrived and I tried to see if poking it down the exhaust would find what's rattling in the header pipes but no joy .
- DefTrap
- Has thanked: 2269 times
- Been thanked: 2088 times
The missus and I have got the 'ordinance' (prescription) for our covid jab. Now it's just a question of getting a booking to have it. And the small matter of vaccine being available.
Stoopid system.
Stoopid system.
- Potter
- Has thanked: 2216 times
- Been thanked: 4613 times
Did my first proper solo offshore (i.e. no land in sight) sail yesterday.
This morning I had jobs to do that I'd noticed so I got them done, tidied the boat up, moored up nicely then went shopping, came home skyped parents, now BBQ time.
Yesterday was the equivalent of driving to the bottom of your street in preparation for a Land End to John O'Groats run - but I didn't sink and if I just keep doing bigger and bigger trips I'll eventually make it around the world via sailboat.
I've only sailed out of sight of land (other than on a ferry etc.) once before....it's certainly a lot more 'real' and you get a sense of just how very big the ocean is when you're in a little boat, even just a few miles out.
I suspect you are right. But the fat fryer I have is no better - I set to the temperature but the spring rolls were 'really' full of oilMr. Dazzle wrote: ↑Sat Jan 30, 2021 9:07 amCheck the temperature you're cooking at, oil that is too cold will often make things greasy. You can make grease free, nice and dry, crispy stuff in a deep frier can't you so its generally not the AMOUNT of oil that matters.
I did the toast in a pan and am always a bit wary when there's lots of oil in a pan, so probably wussed out on the temps
Awesome. Crossing fingers for a booking and supplies!
I'm pretty sure I'm way down the list - but I guess that if they have vaccine up here and the French in the area are reluctant, I'll move up a bit!! LOL
I refitted some shelf brackets, cut a piece of wood in half lengthways and fixed the two bits to the brackets. Finally got my kitchen/sitting room back after a few days of stuff being off the shelf and waiting for someone else to cut the wood for me!! LOL
Off out in a mo to stand in the falling snow at a distance from some friends! Might try and make another snow angel to compare the arm range I have now!! LOL
Tomorrow is forecast to be a bit nice in the morning so I'll be getting the touring skis ready to go early!!
- Potter
When you're far enough out that the mobile phone loses it's signal and the VHF is only good for 20-odd miles, but there was nothing within that distance, it does make you think a bit.Mr. Dazzle wrote: ↑Sat Jan 30, 2021 12:22 pm I've only sailed out of sight of land (other than on a ferry etc.) once before....it's certainly a lot more 'real' and you get a sense of just how very big the ocean is when you're in a little boat, even just a few miles out.
If I'd had an issue yesterday there was no way of contacting anyone, I was on my own.
I was out miles from anywhere and a coalition aircraft put a call out giving some information. I think at their sort of altitude they can reach around 200-300 miles, so it could have been flying out in the Gulf of Oman looking for pirates but there was no way they'd have been able to hear me if I replied. If I was in trouble it would be maddening to hear that perfect queens English and not be able to shout for help.
- Been thanked: 2501 times
Potter wrote: ↑Sat Jan 30, 2021 12:09 pm Did my first proper solo offshore (i.e. no land in sight) sail yesterday.
I'll add: Chuck a good fog to that and suddenly it all becomes very real. And you realise why the accurate marine chronometer was such a desired thing.Mr. Dazzle wrote: ↑Sat Jan 30, 2021 12:22 pm I've only sailed out of sight of land (other than on a ferry etc.) once before....it's certainly a lot more 'real' and you get a sense of just how very big the ocean is when you're in a little boat, even just a few miles out.
When deep diving in murky water and you can't see the surface and you can't see the bottom is fun too.
- Has thanked: 10117 times
- Been thanked: 6649 times
Pop in here for a cuppaPotter wrote: ↑Sat Jan 30, 2021 12:09 pm Did my first proper solo offshore (i.e. no land in sight) sail yesterday.
Today we did a 5 hour enduro and I didn't fall off 9once
I fell off 4 times Thursday
So tired I can barely get off the sofa. Them lads push me hard.
Thats why knowing how to use a compass etc. is still probably worthwhilePotter wrote: ↑Sat Jan 30, 2021 1:47 pmWhen you're far enough out that the mobile phone loses it's signal and the VHF is only good for 20-odd miles, but there was nothing within that distance, it does make you think a bit.Mr. Dazzle wrote: ↑Sat Jan 30, 2021 12:22 pm I've only sailed out of sight of land (other than on a ferry etc.) once before....it's certainly a lot more 'real' and you get a sense of just how very big the ocean is when you're in a little boat, even just a few miles out.
I worked a couple of Summers taking emmets out of Looe harbor on mackerel fishing trips, we'd make a HUGE circle & just barely get over the horizon. Damn near every trip there would be some idiot who asked if we going to land in France & would he need a passport as Blighty came back into view.Mr. Dazzle wrote: ↑Sat Jan 30, 2021 12:22 pm I've only sailed out of sight of land (other than on a ferry etc.) once before....it's certainly a lot more 'real' and you get a sense of just how very big the ocean is when you're in a little boat, even just a few miles out.
- Has thanked: 5945 times
- Been thanked: 4933 times
^ That. 3 a.m., middle of the English Channel, Lymington to Cherbourg, crossing the shipping lanes at 90°. We heard two ships' engines, felt the wash from one of them. Our 'defences' were one of those interlocked panel radar reflectors on the mast and a tin trumpet to blow.cheb wrote: ↑Sat Jan 30, 2021 1:47 pmI'll add: Chuck a good fog to that and suddenly it all becomes very real.Mr. Dazzle wrote: ↑Sat Jan 30, 2021 12:22 pm I've only sailed out of sight of land (other than on a ferry etc.) once before....it's certainly a lot more 'real' and you get a sense of just how very big the ocean is when you're in a little boat, even just a few miles out.
Mind you, two days later we sailed west to Aldernay. And missed.
- Has thanked: 532 times
- Been thanked: 7241 times
Watched four men, a boxer dog, a mini digger and a couple of dumper trucks turn this...
into this...
On Monday it's being block paved... all 45sqr/mtrs of it.
into this...
Didn't even know mini did a digger version. Can't see the scoop in that pic?
