Has thanked: 264 times
Been thanked: 1242 times
inewham wrote: Fri Jan 22, 2021 2:29 pm I don't like the tank, looks like someone's done a (very neat) cut and shut job on an old steel tank. Chopped off the rear quarters then welded them back on the other side (inside out).
I wonder if you could tuck your right knee into that cutout, without setting your boot on fire on the exhaust.
ogri wrote: Fri Jan 22, 2021 2:00 pm
JackyJoll wrote: Fri Jan 22, 2021 1:28 pm
rodbargee wrote: Thu Jan 21, 2021 7:27 pm Image
The go-faster holes in the brakes are a bit “Ogri’s friend Malcolm.”
Ahem, probably more to do with cooling them to help prevent fading?
I think it’ll help prevent brake fade about as much as farting helps to drown out thunder.
rodbargee
Has thanked: 352 times
Been thanked: 969 times
Post by rodbargee »
A Scott
Potter
Has thanked: 2216 times
Been thanked: 4611 times
Post by Potter »
Has thanked: 532 times
Been thanked: 7222 times
It's a Monster 900 'Restomod' by Rebellions motorworks.
Has thanked: 5503 times
Been thanked: 12760 times
Doesn't the fairing and clipons just make it a 900ss?
I like it though
Nah, the SS and the Monster have totally different frames/swingarms.
I think the Monster frame is more similar to the 851/888 frames.
Druid
Has thanked: 277 times
Been thanked: 868 times
Post by Druid »
KungFooBob wrote: Sat Jan 23, 2021 7:04 pm Nah, the SS and the Monster have totally different frames/swingarms.
The frames are both made from bits of straight tube welded welded into triangular shapes. I think most people couldn't tell the difference - including me, and I own a Monster :)
The rear suspension is very very different between the Monster and the SS. The SS is a driect link between the frame and swingarm, the Monster has a kind of rising rate linkage with a ride height adjuster.
The frames are very different if you look carefully. It's much much easier to change the belts on an SS.
Where's GP when you need him?
Older SS frame...
Monster 900...
Has thanked: 10113 times
Been thanked: 6649 times
The screen is as much use as a chocolate teapot.
Has thanked: 626 times
Been thanked: 4063 times
Early Monster frames are closer to 851 frames than 900AS frames, I think the Monster frame is the same as the ST2, dunno why they bothered though, still got a dumper truck engine coupled to a tractor gearbox.
Potter
Post by Potter »
KungFooBob wrote: Sat Jan 23, 2021 6:57 pm It's a Monster 900 'Restomod' by Rebellions motorworks.
I like the look of that, I think it looks as good as a standard one, but different.
Pgm
Has thanked: 6 times
Been thanked: 82 times
Post by Pgm »
First thing that came to mind was a trx 850 Yamaha when I saw this.
Nobby
Has thanked: 85 times
Been thanked: 430 times
Post by Nobby »
Pgm wrote: Sun Jan 24, 2021 5:41 am
Has thanked: 216 times
Been thanked: 666 times
rodbargee wrote: Fri Jan 22, 2021 3:22 pm Image
A Scott
A 1000cc north/south inline 3cyl. two stroke....with pressure oiling and a scavenge oil pump...in 1936!!!
Scotsrich
Has thanked: 71 times
Been thanked: 537 times
Post by Scotsrich »
Scuffmark wrote: Fri Jan 22, 2021 10:27 am
Skub wrote: Thu Jan 21, 2021 2:57 pm How about a lockdown restoration project? Would you hand over £3550 for this one?
https://www.ebay.co.uk/itm/1974-Kawasak ... 0009.m1982
Can't think why but I like that :wtf:
Maybe it reminds me of the bikes I grew up looking at as a pre-teenager?.... Don't think I'd want to pay £3.5k for it though.
Personally not because I haven't got the skills to restore it.
But...it looks 100% original and actually not in too bad nick so someone will buy that.
Has thanked: 9682 times
Been thanked: 9702 times
A bit of money splashed on this old Z.
Some old school schitt with a 'modern' twist.
Has thanked: 15606 times
Been thanked: 9849 times
Interesting and I keep looking at similar beasties. Fortunately, I'm a garage short of buying this!
https://www.ebay.co.uk/itm/Suzuki-GT250 ... Sw5Clf8b3J
Mad prices!
I had one of the ram air earlier versions,plus a Hustler which was earlier again.
