Honda 2018 sp2 world superbike CBR1000RR SP
- Has thanked: 5453 times
- Been thanked: 13102 times
https://www.ebay.co.uk/itm/Honda-2018-s ... SwYFpf3J03
I know we've been doing classics, cafe racers, Bobbers and scramblers lately, so thought we'd mix it up with some superbike.
-2018 Honda fireblade sp2 Triple M WSBK
-Ohlin's Wskb rvp25 gas forks
- sp gas Ohlin's shock
-factory Ohlin's steering damper
- Suter underslung swingarm arm
- Bonamici yokes
- Spider rear sets, Clip on’s and Engine case covers
-Magneti Marelli WSBK Electronics ( dash , ecu and Custom built harness with quick release connectors, data logging and suspension pots)
-Ten Kate WSBK spec engine consisting of nova kit box, dlc coated billet cams, cnc sp2 head, stm clutch, hrv valves and springs, kit sump, Sp2 pistons, Pankl rods carbon fibre oil pick up ( spare refreshed motor is the same spec) . Bike produces in excess of 215 hp at the wheel) kit sump
-Brembo clutch lever
- Taleo Water & Oil cooler
- OZ wheels
- Yutaka Factory Discs
- Factory Nissin billet Calipers front and rear
-quick action throttle
-nissin billet Master Cylinders and span adjuster
- Carbon Fairings
- Aluminium large tank tank, with internal pump (2018 spec)
- Motoholders subframe and battery box
- Billet shock linkage
- billet mode buttons For traction, launch and throttle position
- front billet clock bracket
- SC full Titanium exhaust system
- Ten Kate quick release brackets etc
- Super B lightweight battery
- Titanium bolts and fasteners throughout
- Adjustable swingarm pivots, quick release rear axle
-Bike #51 has an aluminium braced frame and later style front Fairing
- Bonamici yokes
- OZ wheels
- Carbon Fairings
- Mr Moofo
- Has thanked: 1829 times
- Been thanked: 1469 times
Re: Honda 2018 sp2 world superbike CBR1000RR SP
Very nice ....
But I would rather have road going one ....
- Has thanked: 9836 times
- Been thanked: 10149 times
Now that's a bit more special than a Pro-bolt kit.
- Has thanked: 10276 times
- Been thanked: 6891 times
Very nice but I'd have expected a bit more than 215 gee gees.
- Been thanked: 7539 times
I wonder how durable a WSBK engine is?
I know your average trackday punter isn't going to stress it much, but it's got to have a finite life?
The engine life is probably rated in hours before a refresh is needed. Maybe at 215 it isn't in a super high state of tune.KungFooBob wrote: ↑Sat Jan 16, 2021 1:03 pm I wonder how durable a WSBK engine is?
I'd be embarrassed to take that to a track day,for me it would be like playing an EVH guitar at an open mike night.
- Has thanked: 2552 times
- Been thanked: 6260 times
215bhp at the wheel though....compared to a claimed 189bhp at the crank for a stock 2018 bike. So a sizeable uplift. Probably about 35-40bhp more than stock isn't it?
P.S. I hate it when people use the word "billet" as if that's some magical reason it's better
- Tricky
- Has thanked: 2568 times
- Been thanked: 2680 times
THat's truly beautiful- I don't like that era BLade, but I love that, gorgeous
P.S. I know you're probably going to say your Gixxer has 200 hp, but it really doesn't in the real world, on BSD's dyno at least anyway- when I was there getting my H2 flashed, they had just done one exactly like yours, it was supposedly it fit one and standard they are ~180 at the wheel, which is a fuck load, but it ain't 200
You're a dreamer then- standard this model blade would be 160s on most peoples dyno- 215 is a BIG increase
What does the flashed H2 punt out,Tricky?Tricky wrote: ↑Sat Jan 16, 2021 1:31 pm THat's truly beautiful- I don't like that era BLade, but I love that, gorgeous
- Has thanked: 2407 times
- Been thanked: 3637 times
Liking the spider on the paddock stand mounts (or whatever they're called...)
- Tricky
Mine gave 235, that's completely standard apart from the flash- if you fit Akra front pipes, which loses the cat, its an instant extra 15hp and 1k rpm, with no extra work.Skub wrote: ↑Sat Jan 16, 2021 1:58 pmWhat does the flashed H2 punt out,Tricky?Tricky wrote: ↑Sat Jan 16, 2021 1:31 pm THat's truly beautiful- I don't like that era BLade, but I love that, gorgeous
Fitting the H2R supercharger gears ups the boost and adds approx another 30hp, which is all a bit daft really TBH- a standard 2015/16 one (200-205 on BSD dyno) , or any current litre bike is mad enough, as you know, and she's a heavy old girl so it is a real handful
In the flash they disabled the PAIR/ emissions stuff, corrected the massively rich top end (which, along with never fully opening the butterflies is deliberate by Kawasaki I think to artificially restrict it ), and they re-map throttle openings which is key IMO
It made it just so much nicer and massively more civilized in the mid-range - turned it into a real pussycat if you wanted it to be , but even more completely batshit when you wind it open too
Crazy numbers!Tricky wrote: ↑Sat Jan 16, 2021 6:13 pm
I plan to get my Zed flashed,maybe next year when it's got a few more miles,not for any more horses,just that smoother operation/fuelling and rideability.
- Has thanked: 2870 times
- Been thanked: 554 times
Daft questions:
What is the translucent tube running between the clip ons?
What are all the coloured buttons for on the left hand clip on?
To alter the brake lever span as pads wearBeancounter wrote: ↑Sun Jan 17, 2021 5:44 pm Daft questions:
Guessing the coloured buttons are for different ECU modes, shift settings etc.
Buttons are, turbo boost, super presuit and chaff/flares.
You're not allowed to swing chains any more are you?
I'd never seen one of these before - superbikes are not something I look at much - so I was puzzling over how it works.
The colour of the tube mislead me. I was thinking it was something to do with adding/removing fluid, but then I was thinking "well that won't change the span". Turns out it's much simpler than that It just 'moves' the standard screw adjuster over to the other side, so you can twiddle it without letting go of the the throttle. The tube is more like a brake cable, it's just a fancier version of the standard span adjustment nearly every bike has.
Every day is a school day.
As I understand it though, it's more about fade than wear. Disc brakes are self adjusting, so the lever pull distance should be the same regardless of how much the pads are worn - that's why you need the little reservoir of fluid, it takes up the 'slack' in the system as the pads wear by adding more fluid. But as they heat up you'll need more pull force for the same braking effect, which is what you'd want to adjust out.
Net result for the rider is the same really though.
EDIT: Having pondered a little more over my afternoon coffee, I suppose you might also need to adjust the span to account for thermal expansion of the callipers. Aluminium grows quite a lot when it's hot, so the pads would move away from the disc (which also grows though...) as they get hot. You'd also need slightly more fluid in the system to account for the slightly bigger internal volume of a hot calliper. But then most of that should adjust itself out automatically. Hmm...
Gotta be honest, it's not gonna impact my riding any time soon.
