Copy files from PC to iPad
- Has thanked: 7820 times
- Been thanked: 2530 times
Before I spend the next 3 days searching the internet - is it actually possible to copy files from a PC to an Apple iPad without downloading and installing any extra software?
The PC I'm copying from is a work one, which I'm loathe to install possible malware onto (especially iTunes): so all I've got is the USB connection and File Explorer - which, maddeningly can SEE the iPad photo folder, but NOT write to it.
Similarly, the iPad is a gen1 Mini, which has v9.3.5 of the OS, which most apps now aren't compatible with.
All I'm trying to do is set the bloody iPad Mini up as a 'digital photo frame' using photos from Flickr. Currently, the only way I have to get the photos onto the thing is downloading them 1 by 1 from the Flickr website. The iPad won't even download a zip file (which Flickr can make for the album photos).
This is one of the reasons I think IT people hate Apple - they're walled garden systems make things maddeningly awkward to do sometimes.
- Has thanked: 6198 times
- Been thanked: 5088 times
Re: Copy files from PC to iPad
Could you use Dropbox to copy the zip?
Don't think I can get the Dropbox app onto the iPad.
Nope - not compatible.
- Has thanked: 2248 times
- Been thanked: 1242 times
Fella at work has what I can only describe as a double ended memory stick - 1 end is USB and the other Lightning. He uses that to transfer images across....
I can see that working.v8-powered wrote: ↑Wed Jan 20, 2021 3:55 pm Fella at work has what I can only describe as a double ended memory stick - 1 end is USB and the other Lightning. He uses that to transfer images across....
Bit overkill for this (extremely low budget) project.
[D Den]Rockburner wrote: ↑Wed Jan 20, 2021 3:44 pmDon't think I can get the Dropbox app onto the iPad.
"Because of that, I'm oot."
Sub 20 gold coins from memory.....Rockburner wrote: ↑Wed Jan 20, 2021 4:02 pmI can see that working.v8-powered wrote: ↑Wed Jan 20, 2021 3:55 pm Fella at work has what I can only describe as a double ended memory stick - 1 end is USB and the other Lightning. He uses that to transfer images across....
Low budget, eh?
Ok, get the laptop displaying pictures as a presentation. Then hold the tablet still and take pictures using the tablet's camera.
Sorted
Sorted
- Cousin Jack
- Has thanked: 2554 times
- Been thanked: 2287 times
Easy to find on Amazon, £20ish for 64Gigv8-powered wrote: ↑Wed Jan 20, 2021 3:55 pm Fella at work has what I can only describe as a double ended memory stick - 1 end is USB and the other Lightning. He uses that to transfer images across....
BUT seems to have major issues - read the reviews.
This article suggests you only need a Lighning/USB lead ie the charging lead.
https://www.howtogeek.com/345540/how-to ... e-to-a-pc/
That's going the other way.Cousin Jack wrote: ↑Wed Jan 20, 2021 8:35 pm
